Got them today Scott, excellent job you have done for all of us, Thank You! Now the hard part, which one of the many lights i have in pieces is deserving of the first LD-2……. :~
Mine are here too, thanks again.
The drivers absolutely blow me away. They’re beautiful!!!
I bet the ones in pieces are the Jax X6 host that are still waiting on Banggood to send the non broken replacement parts.
Haha yep you’d win that bet! Back ordered Forever! Got some Surefire weapon lights and M3CB lights I have bored out, with my D36 custom copper extra large pills and my D36 custom made reflectors, a couple of theses drivers are going to be kick ass in!!!
Stop worrying, Rufusbduck! You got it right … and no damage or mis-delivery by the Post Office.
Thanks again!
Now I need some time off, visual magnification, and helping hands for the soldering!
Woo-Hoo! Got it! Wow, those NTC’s really ARE small!
GOT IT! Thanks again for doing this Scott
Got mine today, thanks.
Going to be fun trying to solder wires to the ntc. My guess is that soldering the wires should come before gluing it in place if access is tight.
Updated the op to indicate who has RCD their sets.
Package arrived yesterday. Can’t wait to try them out, although I’m not looking forward to those microscopic resistors! Thanks again for all the work that went into this for us!
Received.
Thanks!
…………does not apply to the USPS. Only one state over……but not yet.
Afaict there’s no rhyme or reason to usps shipping times. Thanks for letting me know when they arrive, I’m just as anxious as all of you.
Got my package, haven’t yet opened to check out the goods. Trying to hold off playing with the new toys till I finish a couple of builds.
I felt inspired to use my first LD-2 in a build, so I rebuilt a new Sunwayman T40CS. Putting the moon components on wasn’t horrible, used my standard 2.5mm wedge tip and did it by eye. But then getting the NTS resistor and the fine wires for it and the e-switch and getting all that together was sort of a challenge.
Initially, I saw low lumens output. Realized a few things simultaneously… my HE-4 was down to 3.93V and I didn’t put spring bypasses on the stock springs. So, once I got all that taken care of this baby SHINES! (I should disclose that I ground off the top edges of the pill area and put a 32mm Noctigon on the now flat surface.) With an XP-L V5 1A in place this baby does…
03.86 lumens in moon
61.55 in low
523.37 in Med
1752.6 in High or Turbo
I got 5.86A at the tail once I got a decent dummy cell made for single cell operation in this twin tube light. (I cut a 3/4” thick G10 square, 65mm long, bored it out with a 3/16” bit and hammered a 3/16” brass rod into the middle for the dummy cell. Had to grind off the corners of the 3/4 x 3/4” square piece so now it works beautifully!)
I like having a cut off tail switch that totally kills power AND an e-switch on the side for modes. I got this $120 Sunwayman on sale through touch of modern for $53, now it’s a very nice light that makes loads of output and is very efficient at the same time.
One down, 9 to go…
They arrived. Thanks for the careful and well-thought-out packaging.
Fun and games tonight….The soldering iron is already heating up.
Hope everybody else got theirs.
A Toast to you Rufus B!
I got mine too. Thanks. Now I just need something to build with them…
Still have several in limbo.
