We’re lucky here in Australia, anything under $1000 doesn’t attract any duty
Has anyone had issues when adding 7135s to these you loose the modes or did I just get a bad batch of drivers from KD they are 105c?
If they worked before adding 7135s, it's more likely you produced a short circuit. Check with a multimeter.
Thanks Tido I must be shorting something I just removed the 7135s put it back to stock and the modes work again. Sucks getting old.
I've just received three of this http://kaidomain.com/ProductDetails.aspx?ProductId=10995#
Nanjg 105C
$4.52 each
I took some photos.
I recently ordered additional 2 but KD will be processing/shipping orders by Next week. Longer waiting but its worth it.
Nanjg 105C
That is great news I thought KD might be out of these I have been waiting over a month for mine.
Does this driver have a low battery warning?
By Brted on KD : "Starts blinking if battery is below 3 volts."
Read the review http://www.kaidomain.com/ProductDetails.aspx?ProductID=10995
Is it true. I have this driver on a XML and when battery is low, it starts blinking.
Hikelite:By Brted on KD : "Starts blinking if battery is below 3 volts."
On the newer version of this driver the 105c it kicks down to The lowest mode when the battery gets low. I am not sure if it starts to flash eventually but when mine kicks to low for the second or third time I change it out. I don't like to push my batteries and I always carry a spare battery so it might start flashing in low but I am not sure.
Changed this to a Manafont XM-L dropin, very pleased. PWM is non-existent, takes solid 2,78A on High.
On med, quite loud whining but thats not a problem for me. Low is weak enough.
Hi guys i have a 105c i would like to make it a 3 mode, so by bridging star #2 from the right should be ok if ive read correct, im not a fan of flashy modes.
Yes second star from right to left, 3 modes no strobe.
The first star is also strobe-less, 2 modes.
awsome thanks.
what modes is the first star high low i would guess i have read the thread but i must of missed it
first- 2 modes (100%-20%)
second - 3 modes (100%-35%-4%)
The percentages are according to the OP.
However I've seen several taobao sellers saying,
100%-10%
100%-30%-5%
They could be referring to the older 105A. Pretty close specs anyway.
Is anyone selling these? KD links always seem to give me errors and i cant seem to find it myself.
It's available at Shiningbeam, KD, Intl-Outdoor, Lightmalls.
100%-10%
100%-30%-5%
Thank you, two modes sounds even better to me
Hikelite:first- 2 modes (100%-20%)
100%-10%
100%-30%-5%
Glad to help. Same here, two modes appreciated, especially with that percentage difference.
