You're right, it just doesn't show that in the Advanced editor, or using the HTML code view - if the users prefs are set to use the 'Advanced editor' for comments.
This Advanced editor also prevents viewing the missing tags in the offending post, and fixing it by manually inserting 'rogue' unmatched closing tags into the HTML.
So I switched my prefs to test the 'Simple editor' and what do you know... It shows the tags and lets me add them manually.
Also lets me see the opening 'strong' tag and missing tag in the original offending post, which the Advanced editor does not - even in HTML view!
Problem solved and found out why some can fix and some can't. Many thanks.
EDC-Light is a fairly new site by Ric, who also runs CnQualityGoods ("CNQG"). As of tonight both sites are up, online and still trading separately.
CNQG an online Chinese retailer run by Ric, not to be confused with DQG a band of flashlight designed by George. There is also a flashlight brand called CQG (eg. CQG Bullet), which are not designed by George and may or may not be affiliated with CNQG. It just so happens that CNQG stock DQG and CQG flashlights. You still with me?!
Sometimes the prices are a little different between CnQualityGoods & EDC-Light, so it's worth checking both. And CNQG has a slightly lower than 'market' price for 'members' (aka simply registered users).
There was a 20% discount code given to new sign-ups on EDC-Light a couple of months back when it first opened, but I think he has stopped doing that now.
Also, Ric is on these forums, although he is often painfully slow at responding. He is nonetheless very friendly, professional and helpful. It is worth dropping him a PM @ http://budgetlightforum.com/user/406 and/or email to ThomasRic <cnqualitygoods@hotmail.com>.
Perhaps kindly request a code for whatever light you're after and I'm sure he will consider some offer or deal.
this is George, the designer and producer of DQG’s products, it’s my first comment of this forum, just try to test forum function is normal or not. many thanks to those friends own DQG products, and shame to all shortcoming on those products.
Welcome to the forum George! Its great to have you here. Ive had several DQG’s. Your latest 26650 EDC Triple XPG2 has been an absolute masterpiece for the price! Well done sir, and thank you. :bigsmile:
Please stop by to visit us more often and we can give you some great advice on the type of flashlights we would like to buy. Have you considered a high output light with Cree XHP-70 emitter?
yes, this picture based an early Tiny AAA model that raised by a friend before DQG 10180 series come out. Final I do not accept it due the drivers are not fit to 4.2V li-ion battery in that time; and even now the newest drivers can take 4.2V but slightly PWM flicks can be observed (of cause no PWM flicks drivers can be done if the size of driver and whole light is not limited); and to reach as small as could of a light, and more, the shape of 10180 on the picture is not so good as I think, so, so, a new design of 10180 series is came out as current.
Hi, does considering of using XHP-70 to instead Tiny 26650, but the core of XHP-70 is too large, the optics system cannot help to make a Tiny light if you also want to have a acceptable hot spot and flood. as you know all I doing is to make a flashlight as small as could and same time can reach good efficiently, and have a acceptable hot spot and flood. so, to the high output light as my plan now will be replaced by the upgrade 26650 in later. 7 XPG2 have nearly same output compare to XHP-70, right? even more if you can source top performance XPG2.
Thread title changed: DQG site is back online. This should be George’s thread now!
Please kindly keep feedback polite and upbeat as he is new to these forums. George is a very small independent designer, working mostly out of passion, not a huge manufacturer.
whats new with georger mystery brand?no news??hes missing:)))
ah i see some news: http://www.duqingang.com/
but mini 18650 with double and three clickes seems not to be very practical change:))
