Please put me down for :
1 SS/Cu NW
1 Al WW
Thanks,
Mike
1 SS/Cu NW
1 Al WW
Thanks,
Mike
So your spot is you serial number? I have #20… could I request #57, or if you have #57 would you be willing to swap spots for #20?
1 SS/Cu nw
1 Al nw
Please and thank you!
I'll take 2 sets of Al
cw and nw
thanks
FTR, I’ve hit 103Kcd before in a X6 with de-domed XP-G2. manxbuggy1 has that light.
Yeah, I’m actually kind of wondering what I did wrong to get only ~50 kcd. It might just need better focus, but I doubt that’s the whole story.
Regardless, it’s smaller and nicer than my C8 and it throws farther, so it’s a win.
one set of each.
spot #55 for each
NW for each
please include my name
1 ss/cu - NW
1 ss/cu - CW
thank you
If the first set doesn’t make 200, put me down for CW on the second set (that needs a minimum of 100)
1 HAIII Aluminum Set WW may change to NW later.
Watch the engineering specs on the 14500`s the new keepowers are getting fat and long
I have a few lights that they will not even start into the tube.
Krono: think you missed my signup for one alu set in post #93
Why not both? You know you want to .
All kidding aside - no way these lights do not make the minimums ,,,, and then some.
Kronos, Dale and JM put a lot of thought into these lights. It would be very difficult to find ways to improve them :) As a matter of fact if one were to buy the internals alone it would be more than the HAIII set......and when you consider the SS/Cu.....well, just try and buy Stainless or Copper hosts for $20 each - just not possible.
I’m thinking that the 14500 light will have to be an “IMR” only light, because of the amp draw.
IMRs come without protection, so Not fat.
The typical protected 14500 will only allow for about half of the draw for the FET driver.
Thanks,
-Chuck
1 SS/Cu set in NW, please.
Great!!
List updated in post 164
Keep em coming ! :)
Sounds awesome!
Count me in for 1 for SS/Cu NW please. Thanks!
Chuck post 169
so the 14500 driver needs low voltage protection ?
The 14500 light will have the same driver as the 18650 light, the LVP will be built in like all of these drivers from Wight and ToyKeeper.
And yes, as an FET direct drive driver it will be highly beneficial to use a non-protected IMR 14500 such as the AW IMR14500 in a red package. To wit, there are no better 14500’s at this time but I could be mistaken (it’s happened before!)
I dunno, because I don’t yet have any, but RMM seems to really like these:
Thanks,
-Chuck
L I B! I actually have some of those! :bigsmile:
Time to do some testing, I’d forgotten all about em… pulled my little Rook just yesterday and topped off the cells and it had these in it. I didn’t even think about it.
I’ll do a couple of checks on a chopped MiniMag triple to see how output is with the AW Red IMR vs. these Windyfires…. be back…
Edit: I also have a SS Maxtoch 14500 light with a 15mm FET driver and XP-L V6 3D, will test that with 3 cells and see how they stack up, should be very relevant to this little proposed copper light. I have an Efest IMR 14500, AW IMR14500, and the Windyfire 14500. They’re all on the charger, same XTAR charger, so we’ll soon see. Will still do the triple for the difference in demand…
