DQG designer's thread (George): Official website back online
Good Day George aka yishenger,
Great to have you here, WELCOME!!
Could you Please give us some info on the upgraded Tiny 26650 V3.0, or?
Btw, love your flashlights.
Thank you Very Much,
Best Regards,
George
Hi, does considering of using XHP-70 to instead Tiny 26650, but the core of XHP-70 is too large, the optics system cannot help to make a Tiny light if you also want to have a acceptable hot spot and flood. as you know all I doing is to make a flashlight as small as could and same time can reach good efficiently, and have a acceptable hot spot and flood. so, to the high output light as my plan now will be replaced by the upgrade 26650 in later. 7 XPG2 have nearly same output compare to XHP-70, right? even more if you can source top performance XPG2. :slight_smile:
Hi, its happy that you like it and thank you too.
Is it possible to fit a TIR optic over the XHP70 ?
Thread title changed: DQG site is back online. This should be George’s thread now!
Please kindly keep feedback polite and upbeat as he is new to these forums. George is a very small independent designer, working mostly out of passion, not a huge manufacturer.
Very interesting piece of history there. Thanks!
Like others here, I will be watching for your new designs.
whats new with georger mystery brand?no news??hes missing:)))
ah i see some news:
http://www.duqingang.com/
but mini 18650 with double and three clickes seems not to be very practical change:))
I am looking forward to his headlamp!
Yep me too, that is if he is still working on it. I’m pretty happy with my moddednitefighter L1A, but I’m intersted to see what his looks like
You can put me down for the headlamp and the new 26650. Sounds really awesome!
First Convoy headlamp talks, now DQG headlamp that eats all small battery sizes everything between 16340 and 14500, interesting :D!
Me like!
whats the difference between this two?:
https://www.fasttech.com/products/0/10018289/3778202-d-q-g-tiny-18650-led-flashlight
https://www.fasttech.com/products/0/10018289/3778203-d-q-g-tiny-18650-led-flashlight
hm…cant found the difference…sure it will be big:))
The cheaper one is Cool White, the other is Neutral White
Any updates on the headlamp?
hallo.i have a question-is dqg registered brand or just georges hobby?:slight_smile:
as i know,there only new 26650 model upgraded.and finished.but still no news:))) i only dont understand-is he brand or just hobby?
I really like the DQG 18650 Tiny IV. Each version just keeps getting better and better.
I noticed you finally added the shortcut to turbo from off. Well done. However, the shortcut still isn’t quite right. It’s hold the button down for 2 seconds from off. This is too long. I suggest reducing that to 1 second for the next version.
It would also be nice to have a a single click from turbo turn the light off if you used the above shortcut to turn the light on. As-is, a single-click from turbo turns the light to low, and you have to double-click to get to off.
A sort of STAR momentary firmware would be perfect
aas i know,new 26650 and DQG SPY SS are in production…but you are right-tiny model should be upgraded.i self dont like the 3 clicks system…etc.so i will change the driver…i mean,the flashlites should be really very simple to use.not to study as a eagletac etc…
