LUMINTOP SD75 XHP70 4000 Lumens great price with GearBest -----------CLOSED -------------------
Interesting - PM sent.
Thank you!! Someone will have to help me add resistors because my soldering skills is really bad and I will destroy the pcb :frowning: That’s means I will have to ship the pcb out! I will include native snacks with the shipment! :wink:
Interested depending on price
Interested!
Yep, I’m interested! Interested also in seeing some distant beam shots, with that smooth reflector? It might be a challenge to contend with the K60 at the price jmpaul stated and also the K60 reflector
Interested depend on the price but it has rechargeable feature?
I hope not as bad as *ce*be*m
Will pm for price, is that a smooth reflector? I wonder how it compares to the K60…
Built in charging ! there should not be a problem because this is the system we have seen many times already with 2S2P 18650
Other then DTP on copper mcpcb is not even considered. Also I have ask them for confirmation that the driver will deliver at least 5A to the LED,because previous version of this light was with MT G2 and stated for 2100 lumens. They told me that new version
will have new driver with much more power !!!
Here is some video of this light with old version driver and MT G2 Q0 2100 lumen vs Fenix TK75 2900 lumen, so you can imagine 2X more light,and see the beam from that reflector……
I’ve seen the video and got a question,do i need to access the swith on the tail to turn it on?
Or just enough from the side switch?
Tail switch is only for powerbank function, and battery status. Side switch is the main for light, so tail switch can be turned on or off, doesent effect the light output.
Pm me
NEW!! XHP70 Flashlight - 4000 Lumens-Lumintop SD75 from Lumintop
The “Cree XHP70 3C N4 5000K Neutral White” is now availible.
Where? Maby I can request from Lumintop,to get that bin!??
I like 3D better myself. 3A would work too.
Special optional group buy tint, that would be cool. Plus driven harder, I would have a hard time passing on this as long as the price is right.
Hmmm, this light seems real interesting. I would take it over the K60 because most magnetic control ring drivers are not mod friendly.
In the video above, the TK75 seems to beat this light, but it has a cooler tint. Question is, how much more can the current be increased in this light. Probably not much if it's 2S2P. Modding the battery carrier to 4S would probably result in loss of functionality of the tail, which is a real cool feature. Decisions, decisions. Need to get more info on this light first. It's probably above, but I don't have time to read right now. Need to crash.
Just post the price here, and we can go from there. We are talking directly to them, so no map problems....
Why PM?
Might be interested.......might
