Hey Chuck, with a proper length of paracord through those perfectly sized lanyard holes, the weight of a SS X6 would be quite easy to manage.
Besides, it would assist in ridding heat when you twirl it around …… if you know what I mean.
Bugsy36, Please can you correct my item in the Aluminium list is somehow listed as SS/Cu instead of Al. Please also note the confirmation by Nguyen below which should make the position swap (which happened only since MaleNurse was added) an easy one too. Ta buddy!
As of this moment - no. Although cool I am not sure what they will have to do to accomplish that logistically. As far as dealing with Neal "I" am concentrating on getting the samples (including the 14500 light) produced ASAP so that we do not have the same frustration that we had to endure with the BLF A6......and still dealing with it. The other thing that I am pushing for is metal switch covers.
The other stuff I will leave up to Kronos and company to lead and help any way I can.
I’d imagine the metal switch covers might actually be harder to do than changing the material on an existing component. It usually takes some minor form of magic (or at least some hardware redesign) to make a metal button without losing the waterproof properties.
