[WIP] 22mm DD+single-7135 driver / single sided / Dual-PWM / Zener
36 posts / 0 new
wight
I threw in the kitchen sink.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Edited by: wight on 01/22/2015 - 22:53
wight
Reserved.
cnrffl1
Last seen: 2 days 12 hours ago
Wight, this is great. Can the pads for the Attiny be a little longer (wider footprint), so the larger Attiny will fit? I assume the pins are compatible.
netprince
Last seen: 1 day 18 hours ago
Nice, I’m looking forward to this one… Thanks for your efforts!
wight
Thanks! Good suggestion, I don’t see why not.
Thanks, me too.
wight
https://oshpark.com/shared_projects/0vrfkFpR
  • The center via is 3mm in diameter.
  • Inner spring guides (4 small curved areas of resist) are 6mm inner diameter.
  • Mid-spring pad is 9mm in diameter.
  • Outer spring pads are ~12mm diameter. (for an 11mm spring)
  • Full BAT+ copper pour is 15mm in diameter.
  • R4/R5 are a voltage divider between BAT+ and GND for use with temp measurement.
  • R-OTC is a pulldown resistor for the OTC in case offtime takes too long to save modes.
DB Custom
DB Custom's picture
Last seen: 7 hours 22 min ago
I have 3 of these coming, plan to use one in a BTU Shocker… anything I should know before I build it?
seben
seben's picture
Last seen: 3 years 1 month ago
Great work. In my short time here i really came to love the stuff you do.
The 7135 is for high efficiency in the lower modes – right?
Does this make for significant gains in 2+S Zener lights, since we are burning 50-100mW all the time trough Zenner and 200R?
pyro1son
pyro1son's picture
Last seen: 6 months 4 weeks ago
Sweet! This should work in a F13, DD XM-L2 and cut the trace and get 7135 powering some red locator leds :bigsmile:
Pastebin                                      &nbs
DB Custom
DB Custom's picture
They look really neat! Smile
It’s cool having multiple variants of Wights boards, I got 3 different ones today and they all look so professional. :bigsmile:
Now to put em to work…
DB Custom
DB Custom's picture
Just want you to know that this driver, loaded with ToyKeepers A6 firmware, works beautifully in a BTU Shocker with 3 XP-L V5 1A emitters. I rearranged the cell carrier to run in parallel and bypassed springs, used my last 2 of djozz’s phosphor bronze springs for the main contact points, and it does 4095 lumens OTF.
Pretty intense strobe in the hidden loop. Wink
Thanks again Alex, nicely done! Perfect fit for the BTU Shocker.
DB Custom
DB Custom's picture
Built a second version of this driver tonight. Zener modified with an extra 10uF cap on the Zener, it’s running 12.6V from 3 series LG HE-2 cells to 3 of the 9V MT-G2 emitters. OTF lumens is 8742. And this one get’s hot after about 60 seconds!
The beam profile is a fat hot spot with nice spill, putting a whopping amount of nice creamy white light out. And these MT-G2’s look really good in the big tri-reflector as well! Smile
I’ve got the Toshiba dual sided MOSFET with a nice coil of copper soldered to the top side, I’m thinking this one’s pulling in the 15-18A range, but haven’t measured it yet. Judging from the heat flowing into the massive head on this light, it’s definitely making some power.
Thanks Alex! :bigsmile:
pyro1son
pyro1son's picture
I think we need some photos of this driver built. Wink
Pastebin                                      &nbs
DB Custom
DB Custom's picture
Essentially simple when you’re not using the kitchen sink stuff…
This one was in the BTU Shocker with triple XP-L emitters in parallel, hence the triple 18ga wires at each LED terminal. I replaced it with a Zener modified version to run 9V MT-G2 emitters.
pyro1son
pyro1son's picture
Thanks for the photo!
Looks pretty sweet. Need to get some of these ordered in the next couple of weeks.
Pastebin                                      &nbs
pilotdog68
pilotdog68's picture
I just ordered some to use in a Roche LS01. Hopefully they’ll trim down to 21mm just fine.
I was initially thrown off by all the extra resistor pads; it didn’t cross my mind that they didn’t all need to be populated.
DB Custom
DB Custom's picture
Those extra pads are the kitchen sink spoken of earlier. For thermal and such. I don’t really understand that aspect of it, but as a normal driver it works just fine. Maybe I’ll figure out just what the kitchen sink has to do with lighting and implement some good “clean” fun. Silly
pilotdog68
Has anyone used the pulldown resistor for the OTC? What resistor-value range are we talking about? My cap is taking too long to drain.
I remember seeing a discussion about it somewhere, but now I can’t find it.
pyro1son
pyro1son's picture
Does this look right? I can’t get it to work properly, no matter what firmware I use it gets stuck on turbo. I’ve used a zener and replaced the diode with a 200ohm resistor.
I’m using it for a MT-G2 build.
Pastebin                                      &nbs
pilotdog68
Stuck on turbo? as if it is going DD and bypassing the driver?
pyro1son
pyro1son's picture
As in, I can cycle through modes but when I get into turbo I can’t get out
Pastebin                                      &nbs
pilotdog68
wow. That’s very strange. My gut tells me it has to be something with the firmware, but you’ve already tried different ones so I’m stumped. Hopefully somebody else can chime in.
pyro1son
pyro1son's picture
Think I’ll try another firmware tonight. Does C1 need to move?
Pastebin                                      &nbs
pyro1son
pyro1son's picture
Managed to get this working in a Nitecore MT40 Smile
Still not 100% happy with the firmware but I’m always adjusting the modes anyway.
Pastebin                                      &nbs
Tom E
Tom E's picture
Last seen: 16 min 59 sec ago
pyro1son wrote:
Managed to get this working in a Nitecore MT40 Smile Still not 100% happy with the firmware but I'm always adjusting the modes anyway.
Any trick to get it working? Did you move the C1 cap? I'm about to convert one to a zener.
I'm surprised there hasn't been more posts on this driver - seems awesome. I'm gonna try a zener mod version to go in a Roche LS01 w/XHP-70.
pyro1son
pyro1son's picture
Nope just left the board with the same layout as above the trick seems to be getting the firmware right.
Pastebin                                      &nbs
Tom E
Tom E's picture
Without the zener (went into a SupFire F3-L2 with BLF-A6 firmware):
finges
Last seen: 1 day 10 hours ago
Why are you using a 47k resistor for R1?
mattlward
mattlward's picture
Last seen: 13 hours 11 min ago
Will the NXP PSMN3R0-30YLDX N-Channel MOSFET – LFPAK56 work on this driver? I do not have the FET in the photo above…
matt
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Tom E
Tom E's picture
Yes - think that was the original one on the parts list? Anyway it would work fine, accept not the best for high amps with triple LED's in parallel for example. I use the SIR800DP pretty much all the time now though. Probably no noticeable difference for single LED applications.
pilotdog68
Is there really a noticeable difference for any set up? Or is it just a measurable difference?
