Banggood's Daily Deals -3.20th Updated, Astrolux® EA09 69.99$+Astrolux® BL04 29.99$+Astrolux® EP05 21.99$+Astrolux® EC07G 66.78$
of course
code:FDDNCR price:$17.5
Finally i buy 2 pcs. Thank you :slight_smile:
Deal 21/7
Shadow JM35 CREE MT-G2/XHP-50 1900LM LED Flashlight 2x26650
code:5902fe price:$38
two 26650 and longer runtime than JM35 single battery
coupons free for flashlights,e-cigarette,lasers
Can this new JM35 use a single 26650?
no, it need two 26650 battery
Errm, I don’t think this is correct! I understand it still operates with a single cell, just like the previous short version. Else why would this new revision come with an optional extention tube, and not just a single long battery tube?!
Also is photographed in its short form without the extension being used. Would be a pretty rubbish backward step of it needed two cells at all times!
Hirsh
I think so, but the manufacturer make the driver it is.
I think it need yours to give suggestions
2 series batteries, but use only un-protected batteries!
Why cannot use only 1 battery? Can’t the extension tube taken out?
MTG2 needs 2 cells, XML2 only 1.
Marc.
only a rule of thumb…
there are also boost driver (mtg 1 cell)
and buck with 2 ( or more) for xml
I guess BG wants us to order to find out! Personally I don’t think it would work with a single cell even if it should being an “updated version”, I don’t see shadow developing such boost/buck driver for a $39 light.
But then what’s attractive about this version? It’s the ability to power a 6V Led from a single cell that made it interesting in the first place.
Banggood can you just simply put some batteries and try it? Thanks.
This model light (Shadow JM35) has always worked in the SINGLE CELL configuration. It was first launched without any extension tube option as a Single cell ONLY version for both MTG2, then XHP-50 , options. It uses a boost driver and has been reviewed and discussed extensively here on BLF. (see M4D M4X's review).
I see no reason why the new revision of the same model (just now has dual-switch and extension tube) should be any different...
Hirsh
why do you say this new offering has an ‘extension’ tube? Maybe it is only 1 piece and thus has to run on (2) cells. The specs don’t list an extension tube?
EDIT: Bizarrely the listing does state "Note: Please do not use protective 26650 battery for this flashlight.Can not use 1x 26650 battery."
So I don't know if they're mistaken or this is now a just badly designed light compared to the previous JM35 version!
Hirsh
works for me :wink:
EDIT: Bizarrely, despite the photos (and logic!), the listing does state "Note: Please do not use protective 26650 battery for this flashlight. Can not use 1x 26650 battery."
Suppose we just need to get one to be sure...
Deal 22/7
2PCS NCR 18650B 3400mAH unprotected
code:NCR146 price:$12
2PCS NCR 18650B 3.7V 3400mAh Protected
CODE:bgf182 PRICE:$13
Bangood have you tried this with only one cell?
Has anyone got this “new version” 2-cell JM35 in MTG-2?
I would like to know if it really only runs on 2 cells or will it also run on one?
Trying to decide which version to get
http://www.banggood.com/buy/Jm35.html
Dead thread? Almost 3 months and no new deals here?
or is there a new banggood deals thread?
