Hello, Rolz,
You can send us email at sales@imalent.com. Anyone join us can have chance, we would choose 10 by random. Hope you will be the lucky one.
Best regards,
Shellen
Hello, Rolz,
Best regards,
Shellen
1. If the flashlight is rechargeable or un-rechargeable?
Rechargeable
2. What kind of battery does it use?
18650
3. What kind of LED does it use?
XML-L2
4. What would be the lumen output?
10-1000 lumens!
5. What features would this flashlight have, as you know IMALENT flashlights always have innovative feature for each flashlight?
Touch control?
6. If you can do flashlight reviews or you have time to take some good pictures or videos, let us know several of your history reviews or videos, you will have priority to get the chance.
Bike headlight review on MTBR.
It’s a battery review with photos: Discharge Capacity Tests on Soshine 18650 2900mAh Protected, cells courtesy of Louis Huang of T-mart. NCR-PF/Soshine graph added
- rechargeable
- 18650
- Cree XML-2
- 1000 lumens or more, with time based stepdown
- Stepless brightness adjustment by rotating the tail, capacitive momentary switch at the tail, locator led at the tail, micro usb port for recharging, and hopefully programmable UI
- Possibility to take some pictures.
Thanks, Blinky1,
if possible, post one or two pictures.
Best regards,
Shellen
-Olight style dock charging
–18650
-xml2
–980
-tailcap rotary dimmer
-I’m a newbie in flashlight review but I can try
Rechargeable through micro usb in the tailcap
18650 LiION
CREE XM-L2
950-1050 lumen
In flashlight charging via micro usb, momentary on switch, which is lockable through rotation and/or freely adjustable brightness including moonlight.
Yes i can take pictures: https://picasaweb.google.com/ulibaer
Also from flashlights: **CLOSED**WTB Solarforce L2 Stainless/Aluminum finish
1. Rechargeable
2.18650
3. Xml2
4.1000ish lumens
5. Magnetic dimming knob.
6. Yea I have done reviews. I reviewed two of your lights… The ddt40 and the SA04. My other reviews can be found in my signature. I do video reviews only.
Enjoy the videos and music you love, upload original content, and share it all with friends, family, and the world on YouTube.
And another two I did earlier this year.
1. If the flashlight is rechargeable or un-rechargeable? It’s USB rechargeable.
2. What kind of battery does it use? 18650
3. What kind of LED does it use? Looks like an XP-G2, maybe XM-L2
4. What would be the lumen output? If it’s XP-G2 it could be 600 to 850. If it’s XM-L2 it could be 900 to 1200.
5. What features would this flashlight have, as you know IMALENT flashlights always have innovative feature for each flashlight? It looks like capacitive touch on the tailcap with a rotary control for brightness level.
6. If you can do flashlight reviews or you have time to take some good pictures or videos, let us know several of your history reviews or videos, you will have priority to get the chance. I don’t have any really deep reviews but I’ve posted beamshot comparisons. I can definitely take pictures and do video reviews. Here’s a few links…
Olight SR52vn vs Eagletac M25C2vn
Thanks IMALENT for this guessing, and nice giveaway
1.Yes its micro USB rechargable
2.Single 18650
3.NW XM-L2
4.860 - 1000 lumens on HI mode
5.Some kind of special pressure sensitive electronic switch ,momentary on,and preadjusted modes ….
6.I have done only picture reviews here on BLF for moded lights, and video for opening packages,but will do my best to do a nice review of your new flashlight if you chose me ……
Unfortunately currently do not own a good camera, pictures are taken with a cheap Olympus VR 340, and I bet it would look 5 times better that I took pictures with some better camera. weather conditions were not ideal, because of the low cloud cover and weak drizzle. Also street lighting reduces the effective range of a flashlight. This is a well known resistor removed mode , I am using 20 AWG silicone wires,all springs are bridged,and my own made copper pill is inside. Dedomed XM-L2 U3 1A on 2…
Rechargeable with micro USB.
18650 or 2x CR123s or 2x16340
Cree XM-L2
Moonlight till 900 - 1250 lumens
Infinitelying variable brightness with the tail knob, touch button instead of physical mechanical or electronic button.
I have taken beam shots but not a full flashlight review. Beamshots
Why the “game” if you are just looking for reviewers?
+1
Also since you fell so short on your last big release...
4. What would be the lumen output? - Your claimed theoretical output, 1400. Actual output? 1000 lumens at best.
Edit, are you saying to answer the questions about the light in the pictures or questions about upcoming lights?
For light in the picture
For upcoming lights
Rechargeable
18650
Xml2
1050 lumens
Fancy switch like the others
Never reviewed just comments
- If the flashlight is rechargeable or un-rechargeable?
- What kind of battery does it use?
- What kind of LED does it use?
- What would be the lumen output?
- What features would this flashlight have, as you know IMALENT flashlights always have innovative feature for each flashlight?
- If you can do flashlight reviews or you have time to take some good pictures or videos, let us know several of your history reviews or videos, you will have priority to get the chance.
1. there are no “rechargeable flashlights” only rechargeable batteries, you probably wanted to ask if the battery can be recharged while it is in the particular flashlight from your pictures, answer is YES.
2. battery kind -> lithium ion, if you asked about the size, then 1x18650 and probably 2xCR123
3. Cree XM-L2
4. 1600 chinese lumens just kidding, 800-900 lumens would be realistic assumption
5. Look like the tailcap switch has an extra short activation travel, maybe it even rotates to change modes!
6. I have done several reviews, for videos I do not have proper camera but that is going to change very soon thanks to GB I can send you some links if you wish!
thanks for the chance to participate!
So the “game” is just interviewing potential reviewers?
Will any inexperienced reviewer or those not interested in doing a review even be considered?
Will the winners be randomly selected? If, in the end, no people who are not interested in doing a review “win” then this does not belong in Giveaways and Contests.
Please move this thread to ” Commercial Sellers’ Spot.“:http://budgetlightforum.com/forum/marketplace/commercial ”How to move a thread.“:How to move a thread Read the ”Commercial Sellers Rules.“:Commercial Sellers - BudgetLightForum.com
If you want to do a completely free giveaway, please post in the Giveaways and Contest category.
Giving out flashlights in exchange for a review is not a completely free giveaway.
While I’m posting, here is my entry for the “game”.
1. USB rechargeable.
2. Single 18650.
3. CREE XM-L2.
4. 900 - 1100 lumen
5. dimming by tailcap dial, led tail, usb programing
6. Yes, I can take some nice pictures.
I'm not interested in doing a review either, just playing the game for getting a free flashlight ;)
I can take some pics though, if I still have my camera equipment when I have moved back.
- Rechargeable
2.18650- Xml2
4.1000ish lumens- Magnetic dimming knob.
- Yea I have done reviews. I reviewed two of your lights… The ddt40 and the SA04. My many reviews can be found in my signature. I do video reviews only.
I see a trit in the tail cap, I decidate this find to credit mhanlen and besides who else makes mini movies about your product?
1. If the flashlight is rechargeable or un-rechargeable? Rechargeable
3. What kind of LED does it use? Cree XML-2
4. What would be the lumen output? 900-1000
5. What features would this flashlight have, as you know IMALENT flashlights always have innovative feature for each flashlight? *_Possibly rotary dial for brightness and maybe a thumb print reader (you said innovative)
_*
6. No reviews yet but I would be happy to do one. I love flashlights in this form/shape.
