1. rechargeable
2. 18650
3. Cree XM-L2
4. 1000 lm
5. Rotary brightness control
6. No
Hello, Halo,
Review is not a must, even you have the ability to do review, but if you don’t want and you are the lucky one we chose, this is also ok for us.
Therefore, this is a totally game, but also a way for us to know more people who have review experience and we do hope the lucky ones can share our new models with their friends with pictures or videos, but again, this is not a must. Just do as you wish.
Thanks for your advice and support on our activity.
Best regards,
Shellen
IMALENT team
Check the following pictures and answer questions:
1. Rechargeable
2. li ion, likely 18650
3. Cree, looks like XM-L2
4. According to the datasheet the U3 chip can output 1040 lumens at 3A/85ºC junction temp (use a direct thermal path mcpcb for an extra 100 lumens) , minus reflector, lens and bezel losses
5. Adjustable brightness
6. Not interested
Edit, are you saying to answer the questions about the light in the pictures or questions about upcoming lights?
For light in the picture
- If the flashlight is rechargeable or un-rechargeable? RECHARGEABLE
- What kind of battery does it use? 18650
- What kind of LED does it use? XM-L2
- What would be the lumen output? 1000+ LUMENS
- What features would this flashlight have, as you know IMALENT flashlights always have innovative feature for each flashlight? USB programmable modes
For upcoming lights
- What kind of LED does it use? XHP70
- What would be the lumen output? 4000+ LUMENS
- What features would this flashlight have, as you know IMALENT flashlights always have innovative feature for each flashlight? LIKE THE DD4R features
The flashlight in the pictures, IMALENT new model.
Thanks for your details.
Shellen
1. MicroUSB rechargeable
2. Battery: 18650
3. LED: XM-L2
4. Output Claimed: 1200 lumen approximately
5. Touch button, and wheel selction for modes
1. Micro USB rechargeable
2. Single 18650 battery
3. Cree XML-2
4. 950 lumens
5. Forward clicky, water proof, rotating switch for different output modes, voltage check, multi strobes with extra everything and cream
6. I own a camera
Entry:
- Rechargeable
- Lithium Ion: 1 X 18650/2 X 16340
3.Cree XML-2 - 1050 lumens
- waterproof, tail ring for infinite output adjustment, auto on mode.
- No reviews.
1. USB rechargeable
2. 18650
3. XM-L2 U2
4. 1100 lumens
5. Forward switch with rotary mode selector wheel.
6. Can take picture and beamshots
Hello,
We still have 5 days left. Make your guess here to take your chance.
Best regards,
Shellen
1. Rechargeable through the microUSB port hidden by a rubber cover on the tailside.
2. 1x18650, 2xCR123
3. XM-L2/XP-L
4. 1111 lumens
5. Capacitive touch switch, rotary mode/brightness change knob, battery indicator/location beacon in the tailcap, remote control via bluetooth. Oh, and a slot for a clip (clip not included).
6. I’ve done some reviews a while ago, got a better camera since. 1, 2, 3, 4
WOW!! I like the usb charge-ability! All flashlights should have usb charging function!
I promise to do a extensive review if I win one!
1.RECHARGEABLE
2.18650 LI-ION
3.CREE LED XML2 or XP-L (I can not see very well the photo showing the led XP)
4.ABOUT 1100 LUMEN?
5.USB RECHARGING FUNCTION… BATTERY LEVEL INDICATOR…
6. YES. I HAVE DONE SEVERAL ( and now I have a better camera, so I can take better photos!) I.e Review: Crelant V21A .... Premium U3 version - Multiple AA / 14500 Flashlights - BudgetLightForum.com
Hope to win!. Thanks!!!
1. Rechargeable
2. Single 18650
3. Cree XM-L2
4. 1050 lumens
5. Rotary brightness control, battery indicator
6. Can take pictures.
3. Cree XML-2
4. 1060 lumens
5. Rotary control
6. Can take pictures and give an opinion and impressions, but not a formal review.
1. If the flashlight is rechargeable or un-rechargeable? Not un-rechargeable.
2. What kind of battery does it use? A tube shaped one with pretty, shiney ends.
3. What kind of LED does it use? One that glows when electricity is applied.
4. What would be the lumen output? It would depend on the mode.
5. What features would this flashlight have, as you know IMALENT flashlights always have innovative feature for each flashlight? An automatic nose-picker.
6. If you can do flashlight reviews or you have time to take some good pictures or videos, let us know several of your history reviews or videos, you will have priority to get the chance. Sure. Check out my siggie.
1. Rechargeable or un-rechargeable? Rechargeable via micro-USB under rubber-cover. (Would prefer concealed under twist like XTAR RC1)
2. Battery? Single 18650 li-ion or two CR123A primaries. (Would prefer swappable tubes/included extensions for ultimate support from 16340/18650/14500/18650)
3. LED? Cree XM-L2. (Would prefer XP-L HI)
4. Lumen output? ~1000 - 1200 Lm
5. Features? Electronic tail switch with soft-press (capacitive?). Twist tail-cap for mode selection/rotate step-less dimming.
6. Reviews or good pictures or videos? Can take nice pictures and efficient at dismantling, assessing and re-assembling all forms of electronics. I have provided some critical feedback, pictures and narrative commentary here amongst other threads, but not yet a full-on review. I do not have any specific light diagnostic or testing equipment, so would not be confident doing a technical review. Basic breakdown only at the moment.
Thanks! hope to win… please! luck please! :_(
1. rechargeable using Micro USB port
2. Single 18650 Li-ion battery
3. Cree XML-2 or Cree XP-L
4. 1200 lumens
5. Infinite variable brightness (ramping mode).
6. Yes, Can do a review with video and pictures.
Good luck everybody!
1. MicroUSB onboard charging
2. 18650 with 2xCR123 as a backup
3. XM-L2
4. Around 1000lm
5. Infinitely variable brightness controlled by a knob, like a Nitecore SRT but with the knob in a much better place
6. I can do written reviews with photos, and will be doing one for an online flashlight store next month, but I have not done any yet.
If that knob has a stop or detent at low and a stop or detent at high, I might be replacing my Nitecore SRT5.
Hi BLF!
I want to thank Imalent for such a nice offer…
My guesses are:
1. It is rechargeable using the most common USB conector (microUSB)
2. It seems to use one 18650 battery
3. It seems to have a XML-2 from Cree
4. It is possible that it can produce up to 1100 lumens
5. I think it has a electronic tailcap switch button. And many other things. It seems to have a battery level indicator (green led) at the tailcap. Or maybe it is just a beacon LED. Idont know…
6. I can do a review if neccesary.
Now… I am anxious! I need one!.
Hi…
This is what I think after watching the pictures…
1. Rechargeable (USB… very nice!)
2. 18650 battery
3. XM-L2 LED
4. 900-1300 lumens
5. Electronic tailcap switch. With battery gauge?? That would be nice too…
6. I will be very happy if I win, so I promise to make a full review with photos and comparison to others…
Thanks to Imalent and also to BLF website.
Always giving us chances to win something (despite I never won…)
Good luck folks…
Hello Shellen,
1. Rechargeable is fine but lenghtens this flashlight. For bigger lights no problem, for EDC not ideal.
2. 18650 + CR123A (if no 18650 is available or for newbies)
3. LED: Cree XP-L (Hi)/XM-L2, available in neutral + cool white, not too greenish/blueish/yellow tint
4. output: 1200 lm Turbo for max 1 minute + stepdown to 800-900 lumens
5. features: low battery indicator + discharge-protection at 3.0V, hidden blinky modes, constant brightness without depending on voltage, tailstand
best regards, Markus
