A charger/discharger that can discharge as low as 2.5V and charge up to 4.35V - do it exist?
What are you really needing to test ?i thought all your batteries were new unused Oem and japanese or korean
But I want to be sure…
When you need this level of control, you are getting into the realms of a hobby charger.
Plenty of threads discussing them here. I am very happy with my iCharger 106B+.
I think you'd still be limited to one at a time for discharge testing though.
After my disappointment with the C3100 v2.2 I decided to make a custom 1-6S battery tray to use with my Icharge 106B+… A hobby charger is really the best choice for your needs.
Are you sure that Lii500 gives you wrong test results, please could you present some data or extensive table to detail the extent? HKJ has ordered the Lii500 too but his reviews of LCD chargers never detailed the accuracy of mAh readings.
Can’t be sure. But most of the battery types I test has the right actual mAh. But Samsung 32A, that can be charged up to 4.35 gave me a very low result, 2600-2800mAh max.
Yesterday I got a package with Sanyo NCR18650BF batteries, with 3400mAh rating, and I got 3186 - 3214 - 3300 - 3203 - 3229 - 3259 - 3319mah on the first 8 batteries, but their specs from the factory says that they have a cutoff power at 2.5V, and the Lii500, has a cutoff power at 3V. So with the extra 0.5V I’m sure I had seen 3400mAh on all batteries.
that's only 7 numbers, were's the eighth? the variation between the cells (3186 < 3319) is too high imho. we can't be sure why the 7 batteries have so different capacities. maybe fake Chinese.
Samsung pdf says Nominal Capacity 3200 mAh (0.2 C, 2.75 V discharge) Minimum Capacity 3100 mAh (0.2 C, 2.75 V discharge) Charging Voltage 4.35 ±0.03 V. 2600 < 2800 is about 400mAh short. i don't think that there is 400mAh between 3.0V and 2.75V.
maybe also fake Chinese.
While this remains true…I guess your 106B+ cannot go up to 4.35V but just 4.30V. Have you tried? Still, I think it could go down to 2.5V
Sorry about only 7 not 8 batteries, had one other batteries on a 500mAh test that I did not want to cancel, so then it was room for only 7 batteries. If they are fake, I would be disappointed. I have used some money at this seller… but then he would not get any more business from me.
About Samsung, if they are fake, Gearbest.com sells fake China batteries with real brand names on it.
Got my new and real Opus BT-C3100 v2.2 today, will run the batteries one more time on that to see the results.
Thanks for your tests! Please post the 8 results here :)
errhm…. i don’t think they are fake… fake batteries won’t hit the 3Ah value, they would rarely hit the 1Ah value…so they are legit, the fluctuation could be caused by many things….none the less the electronics of charger …may I suggest that you test multiple times the same battery and see what’s the consistency of the results?
Will take time, since it only take 4 batteries at the time. So maybe tomorrow it will be ready. If not the second BT-C3100 charger I order is in the postal office now, has three packages laying there, going to fetch them now soon.
Don’t forget new cells may take a few charges to get up to full capacity.
Marc
That was new info for me (make sense since I know it so for phone batteries etc, and they also are Li-ion)
Cheers TheBo
Not owning any 4.35 cells I've never had a reason to check but you are right. The manual says 4.30V.
Perhaps there are other hobby chargers that might though.
[/quote]
Cheers TheBo
[/quote]
I've an Accucel 6 and it doesn't go past 4.20 volts charging, or below 3.0 volts discharging.
An SP1 does fine for my laptop pulls that require 4.30 volts or 4.35 volts as it goes to 4.31 on the 4.35 setting.
I'd say the OP is expecting too much precision from batteries as they all vary from their specs, and all the capacities he quotes look good to me.
[quote=myhken] Have LiitoKala L500 chargers, and soon a new BT-C3100 v2.2. But I have discovered a issue when testing batteries. The Lii500s cut the discharging at 3V, and it do not charge to more then 4.2V (same with my charge only Nitecore D4). But it's giving me wrong test results on different batteries. I know the BT-C3100 can charge up to 4.35 (if you open it and switch the switch inside. But who can discharge down to 2.5V? I need testers that can take four batteries, and I need at least two. Somebody that know what to buy? [/quote]
the devise shold be able to use these batteries to full capacvity.
i too have opus and a lot of icr-30h batteries ..
looking for 4.3 v charger ... cutoff at 2.7 is good..
any mod to tp4056 board ?
They are clearly good, but little “sad” to not see the 3500 mark, or 3400 mark on batteries that have that rating. But thats life. I have paid $40 per charger/discharger so can’t expect the world. But if the result gets really low, there has to be something wrong with the batteries. (not in this case)
Isn’t expecting the capacity of the battery from your own measurements to be the same as Sanyo, etc similar to expecting the mpg driving your car to be the same as the manufacturer’s stated mpg? Too many variable in your own measurements and how do you know how the battery companies are actually testing for capacity? (*fire batteries excluded since none of them are based on real testing).
I’m also guessing that Sanyo’s equipment is much more accurate than anything most of us have.
So if the spec calls for 2.5V you are admitting that “So with the extra 0.5V I’m sure I had seen 3400mAh on all batteries.” if this is the case the tester worked just fine in verifying for your that the batteries are legit. So the remaing question is if the spec termination voltage is X are you also confident that the batteries are legit?
