Thank you
Please, could I have number 99 in both lists?
Thank you
A couple things:
ToyKeeper has been added to the design team. Her firmware will be used on these lights, and her expertise is sorely needed. Welcome TK to the team!
Wight has given us his blessing on using his driver design. Woot! Thanks wight!!!
Sample hosts are mostly complete! We should see samples shipping to the team, hopefully within the next few weeks! Manker is FAST!!! I will try to get some pics out as soon as available.
Cheers,
kronos
(Updated in OP)
Great!! Canāt wait for the photos! !!!
Shame on that big, bad camera! Attacking that poor little defenseless flashlight!
Oh My... .Dale has been bitten by the Wallbuys craze.... you know, those Rubiks cubes!
sorry, can`t see any flashlights, just an old camera, dusty strobes, and a wooden tripod.
****now taking cover before dale reads this message****
Dale, I`m HERE!!!!
Now I`m HERE!!!
NO, behind you!
bannggggg... OUCH!
Iāll have you know thatās an original Rubikās cube! Been around for many many years (and never solved, :P)
My tripod is disguised as wood, itās really zirconiumcarbonitride-fiberbamboo-alloynium.
(stealth ninjaās deployed)
Aluminum
73. Richnpc Al NW.
Could I please change this to CW
Origional 1D, or 1DS? Also nice slide plate.
1DsMkII full frame sensor. Really Right Stuff quick release bracket, macro focusing rail, flash bracket, and tripod ball head. Tripod is a Slik carbon fiber. 100mm Macro Hybrid IS lens.
One thing I like about the older 1DsMkII is that itās dedicated to photoās, no live view no video whatsoever, just excellent clean files at 16.7MP that rivaled medium format when it first came out. Just because a few years has taken cameraās in a new direction doesnāt mean this old camera doesnāt take fantastic pictures, because it does! Back in itās dayās of glory, it was Canonās most expensive camera, costing more new than even todays top offerings. (I got it used with a new shutter, and have since replaced that shutter twice. Thousands upon thousands of beautiful pictures. :laughing:
Usually, these days, I use a 20D with the macro lens, or a 60mm EF-S macro, for the flashlight pictures. Plenty big enough and sharp enough without being overkill.
LOL, OCD working overtime much? Thatās not a gap, itās a shadow. The fins protrude from the bezel/head for cooling purposes, which allows that first one to cast a shadow on the bezel with the light coming from upper right.
Believe me, RBD left nothing to chanceā¦ (RBD being RufusBDuck for those that are confused)
Edit: Double checking the light, the shadow is enhanced by the fact that MagLight put a slight bevel on the outer edge of the bezel such that there is a slight inset at the junction of bezel/copper fin which makes that shadow even darker. Itās present so there wonāt be a sharp edge on a part consumers are likely to handle, it could be filed or sanded down for a finer edge there but itās really of no consequence.
Phew talk about a load off my mind, it was giving me nightmares :bigsmile: Yeah my OCD is working but I knew there was some explanation for it. Sorry for the trouble.
Not a problemā¦ glad you can sleep now.
Iām planning on taking a pretty extensive set of photoās of these samples when they arrive, showing close-up detail inside and out as well as the usual beam shots and current/output tests. So there will be plenty to occupy your obsessions keen interest pretty soon.
Please, is it possible?
Yes dodo. Totally missed your postā¦seems we both posted at the same time and I missed yours. Iāll update the list.
I believe my post, #359 was missed which was for one AL/CW.
Thanks!
Hey Krono, with Bugsyās A6 and your D80 fast approaching production, soon these will be all we have to look forward to! What will we do with ourselves?!
When you get a second spare, please would you be so kind as to update the list with these approved positions swaps. All done and transposed, just need copy/paste from below into your listā¦
CuSS
20. Sarge930 NW
57. jealous57 SS/Cu WW
AL
7. djozz Al ?
13. ahirshy Al ?
15. ReManG Al NW
31. ahirshy Al ?
32. nguyen Al NW
34. Iron potato Al NW
39. Tinn44 Al NW
80. tizzo Al NW
81. Nguyen Al WW
All the various approval posts are noted together here .
That will bring them all up-to-date and I will continue logging and tracking any more for you if it helps.
Thank you very much, but if you want to complete the action, please delete me from position 30 in the first list and 84 in the second.
Ciao
