I am sorry if I am judging too soon but it looks to me like you work for that shop!
Anyway those prices are lowest I saw and that makes this cells a bit suspicious to me,
BG or GB or FT sales thousands and thousands of this cells (so they should have lowest
possible price) opposite to this seller that only has 159 sold items.
i agree this is the 1st time i am buying a BRAND name item made in Japan from China
i will be glad to post my finding when everything comes (could be weeks) BTW that amazing amazon deal i got must be all real ones in my use the NCR18650B @ 3400mAh really last 2x as long as the used laptop pulls of 2200mAh to 2600mAh used Sony Samsung LG and Sanyos
BTW i have about a 75% success rate with Ali about 15% the cheap stuff i buy is just that too cheap
and at least 10% are total lairs cheats and worse but all in all i do on with Ali E
and i never lost a claim yet and i usually get to keep the junk 1 time i needed to return the items (the LED lights i bought were very YELLOW and not Warm White
to start with all of the NCR18650BF have a charge of 3.66v
i am doing a long “NORM” test of the cells if i understand the ENGRISH instructions this mode charges discharges and then charges to give me the full mAh rating (i know that Li-ion do not need to be conditioned RIGHT??)
it also have a “FAST” testing mode
i am doing
1 300mAh 15mR 1 500mAh 16mR
1 700mAh 16mR 1 1000mAh 17mR & at 4.00v the mR was 15 it went from 3.66v - 4.24v in 1:40min and now its discharging
all 4 together are pulling only 16w on my power meter (seems like not a lot 2 cells in my i4 use 10w
OH and all the NCR18650BF have a mR (internal resistance aka iR) of 15-17
the charger and the 1000mAh 700mAh cells get warm but so does my Nitecore i4
so far the only thing i really do not like is that the Liitokala lii-500 charger while its got a great BIG screen it can only display info on 1 battery at a time there is no indication that bank #2 is done if its displaying another bank
the sale just ended they were $5.40 each
to each there own i prefer the NCR18650BF and get those for ~$3.86 for 20pcs
BTW the NCR18650BF are better then the NCR18650B
You can also get 3xNCR18650BF inside xiaomi 10000mah powerbank which after 10% off using Banggood mobile app costs only 10,8$. That is If you dont mind the extra aluminium casing, quality USB charging/discharging circuit and breaking apart solder tabs.
My 3400mAh Panasonics NCR18650B batteries (8 of them) arrived yesterday, first thing I did is charge them at 200mAh, with my Opus BT-C3100 v2.2
They charged up to 4.18V or 4.19V and each battery only took in 2000mAh of power.
Could the batteries already been somewhat charged from the factory?
Or do they need to be discharged and recharged a few times to be able to hold 3400mAh?
In terms of capacity there are 3600mAh capacity batteries available (Panasonic as well), although hardly for consumers. There are 3500mAh cells available (LG 18650MJ1).
For high drain batteries the NCR18650 where never the best in town.
But they are getting cheaper, so I still buy these.
NCR18650B are outdated. The have been succeded by NCR18650BF.
NCR18650GA, LG INR18650 MJ1 and Samsung INR18650-35E are currently the ‘best’ batteries.
All 3 are usually offered as ‘3500mAh’ cells.
GA and 35E are specified as 3450mAh ‘typical’ capacity, 3350mAh minimum.
MJ1 and are rated 3500mAh typical and 3400mAh minimum.
In reality, we can excpect them to be closer to minimum than to ‘typical’.
