XHP50 Convoy M1 Build x2 18650
2x 18650 Panasonic NCR18650Bs gives me 4.5amp draw with standard DMM test leads.
will test with shorter leads later tonight.
pics:
Looks good, no comments, this will work very well :-)
Oh, just one question, will you solder the board to the pill?
I can never get the brass pill to hold solder…… ever. it’s irritating!!! I would much rather the driver be soldered to the pill then with a ring. as for the MCPCB to the brass it already is on the center. I never thought of doing it all the way til it’s over flowing.
Nice! Where did you get your M1 extension tube?
Nice build and good soldering. It should be a very good performer but the head would heat up very fast on high?
The build looks great, but what kept you from running two 18350’s in the stock light. Besides the ridiculously short run time, it would be a neat sleeper….
Try this flux—you’ll be able to solder an ice cube to a brass door knob
Lol I still can. Honestly I like it better without the tube and just two 350s.
“Solder an ice cube to a brass door knob” lmao. Brilliant.
Your builds are improving Mr Nobody. Very clean
Very nice build. Super clean… As for the above mentioned flux, I bought a few of them about a month ago and really like the stuff. This guy sells the “no clean” 951 as well as the 186 rosin based flux. Both are Kester.
Can I solder on aluminium surface with this flux?
Aluminum requires a different flux and solder alloy.
Very nice looking build, hope you can post some beamshots soon. Where did you get the extension tube for the M1???
Well, to solder the MCPCB to that pill you've probably got to use a torch or another big heat source because the entire pill, along with the MCPCB, has to be hot enough for the solder to reflow. It will be fine as long as you've got pressure on the MCPCB while in use.
I use Kester’s solder paste between mcpcb and pill and heat it on the stove, in my $1.50 aluminum fry pan I picked up at a garage sale. Reflow on it also. It’s low cut and small, made of aluminum, it cleans up well too.
Yep! I believe it’s the same. 5mmx5mm Cree XHP70 up to 4022 Lumens and XHP50 up to 2546 lumens - Multi-die leds.
I also am curious about the extension tube.
I ordered a extension tube ftom fastech. I hope it will fit my old C8 or M1. I was going to use 2 18350 in a M1 for the XHP50, but the batteries was a ltitle too long to fit.
the extension came from fast tech. I don’t remember which one I ordered. this light is now for sale in the for sale section of the forum.
