Yes that’s real. It has a proper spring on the driver. Unlike the crappy copper coloured one.
OMG, is everything I buy from Gearbest.com fake?? 5 S2+ is fake then, and 3 C8 will be fake then…and my other cases. Bad power banks and crappy batteries. Whats next…have I wasted $1000 on just fake products from Gearbest.com?
Haha lol, yes it looks like it. But your power banks were not fake they were genuine crap!
Marc
Additional findings from quick inspection w/o complete teardown:
- logo on both side of the tube.
- logo mis-aligned
- low grade smooth anodizing.
- no brass cap and black retaining ring at tail.
- comes with electronics/metal smell inside battery compartment (common for sub $8 lights).
Opening a ticket now. I have paid $141 for the flashlights, that now is most likely to be fake (the ones I’ve got is fake). And I have ordered at the same time as the other that has gotten fakes ones.
As soon as I have them, I will stat filing paypal claims, if they don’t settle this with a full refund by there self. And I have written in the ticket that I will not accept store credit, for all they sell is fake or crap, so I will not use anymore money on that store.
"Convoy" C8
My example has fairly tight-fitting threads , but although the rear threads are anodized , you can't lock it out .
On the plus side , the reflector is flawless , and the beam has a sharp hotspot .
Maybe this is some of the fallout left by the former Gearbest employee that ordered all the fake Convoy Red S2+? Maybe he ordered some fake Convoy C8 also? If this is the case, Gearbest needs to have a forensic accountant come in and look at every order that employee ordered from any supplier.
I have a bad feeling that this employee did far more purchases from rogue suppliers than just these two Convoy flashlights and has left Gearbest with a large headache.
With other stories of battery packs catching fire and these 2 counterfeit Convoys, that former employee might find himself sitting inside of a Chinese prison with a Chinese Bubba cellmate .
It’s a part of the culture over there. I got a friend that writes code for a living. One of the car radios/climate control designed for the USA big 3 had their boards manufactured in China. After the USA worker had the factory setup for the ISO standard and went back home, a factory manager changed things and suppliers so he could pocket a bunch of money. That ended up causing a product recall.
I’ve said it before and I’m saying it again. China is getting taken over by the Aliens (Ferengi) and we can only see them if we wear a pair of Roddy Piper sunglasses. Excuse me while I adjust my tinfoil hat.
+1.
But even though the anodizing on mine looks OK and I can always swap out the insides, the ill-fitting threads on mine makes it a non-starter for me.
The threads on mine are bad. They fit way but are very sharp. The first time I removed the head it ripped the o ring in half.
I’m glad the C8 that I bought on June 13th was a real one. It has a beautiful 4C tint, new pill-less design, nice square cut threads and matte finish.
I’m still waiting for the replacement Red S2+ to arrive. They supposedly sent it unregistered so I have no way to track it.
You know, you can add some pictures to posts, if you like that sort of thing :bigsmile:
Against a U2-3C from ME:
Nice
Even if you got a fake one for “fairly cheap” a few minor DIY hacks can make it run VERY VERY good…simple spring bypass (solder some 22 ga wire on the driver spring and the tail cap spring, make sure there is some good heat sink goop under the star (better yet replace the aluminum star with a copper sinkpad/noctigon) and then throw a very light amount of heatsink compound on the threads of the pill…that should make it run substantially better (not change the tint, will need new emitter)
Just a few tweaks goes a long way even on the cheapies…but unfortunately there are so many manufacturers and liars from China it’s best to get them from reputable dealers…ALL the Convoy’s I got from Simon were authentic and impeccably built…a few bucks more…sure…but the quality was top notch.
At this point I’m surprised that GB is still selling fake convoys after the S2+ incident. If they said “they weren’t aware of the fakes” that’s pure BS, there are more than enough proof already.
I think we should have a Sticky thread so people stop buying from GB until they have solved this issue.
Too many are falling for it already and even those with genuine convoys started to doubt about their lights, this is definitely not good for Simon, but I don’t see he has taken serious actions on this?
I am not sure if they continue to sell the fakes, but for the S2 I was offered a refund or a replacement. For the C8 they offered only a refund, as they did not have confidence in the stock.
Nice
I do have spare springs, drivers and LEDs, but the poor threads on the C8 makes it a lost cause.
I may try to rehabilitate the S2 for a beater light, if I can find a reliable way to ground a QLITE driver with the crappy aluminum pill and rings. Its emitter plate is also well glued into the pill.
At this point I’m surprised that GB is still selling fake convoys after the S2+ incident. If they said “they weren’t aware of the fakes” that’s pure BS, there are more than enough proof already. I think we should have a Sticky thread so people stop buying from GB until they have solved this issue. Too many are falling for it already and even those with genuine convoys started to doubt about their lights, this is definitely not good for Simon, but I don’t see he has taken serious actions on this?
Hey there! I give you 10$ store credit if you delete this post. (wink2x)
That documented somewhere?
Note the missing voltage divider resistors and mystery controller chip.
The PCB is a carbon copy of a real 105C, apart from the tracks around chip.
