I left in the stock switch, it did not say Omten but looked decent enough, was that a wrong assumption?
These type of FET drivers hardly produce heat, they can float in air if you want.
And I still find it surprising that what I test or make up in the middle of a city in a country that never really gets dark, appears to be actually useful for folks who properly make use of flashlights :-)
In your thread MRsDNF did review of 1504 switch in post 51.
I don't see any problem with it although I do re solder contacts to make sure it sticks good.
In fact I got one batch of omten switches from IO store that looked absolutely the same as UF's but they did not have any omten markings on front or rear.
Maybe you would have even better performance with genuine omten?
The ones I burned up were running at 5A. They would handle it for a little while but ultimately would fail. There were some that didn’t fail and only 2-3 that did fail, but to err on the side of caution I just replaced them.
Where did you bought your genuine omten or kan switches? Can you link some to people. I saw on FT https://www.fasttech.com/products/1135000 but I am affraid to risk. TomE said this:
I don't know what to do since I did ordered from IOS and they came without any markings. Never did complaint to IO about that. And switches are working fine. But this kind of threads, and switch reviews makes you think what have you actually bought...
Or maybe some of you guys tried to fit forward clicky to UF brothers?
@Djozz: I measured the UF1504 at approx 430 as well and I do have a couple of spare switches lying around.
I’ll see if I can replace it myself and then measure the throw again.
The realitive low amp draw could also be down to a high Vf led……
Just an update for my measured output of my best performing 1504’s now that I’ve got a calibration that should have me close to the same measurements as djozz’s Mobilux A. With the stainless collars it’s 518-520kcd. Without the collars they’re coming in at 434kcd.
That’s with dedomed direct drive XP-G2 S3 3C’s, a dedomed direct drive XP-L V6 3C is about 270kcd.
A 1405 with a dedomed XP-G2 S4 2B at 5A makes 588kcd. :bigsmile:
Nice i almost wished i hadn’t read this……now i feel a very strong urge to pick up a 1405 & buy one of Richard high Amp buck drivers…….almost 600kcd :bigsmile:
I just have to ask is that 588kcd from a light without a collar? I hope it is, but if not please check what you get with one because it should do about 100kcd extra on to of that 588kcd
Ok, that is too bad but good anyway :), 50-70kcd extra from the 5A driver in the 1405 over the 1504 isn’t enough to make me want to build it, because i don’t have access to a collar anyway to make it interesting
