4 please, all engraved.
1pcs with BLF engraved
It has standard aluminum MCPCB.
Is it the same as before with 1 mode?
Yes. Why change something that works. :)
Done.
interested here in 2x BLF engraved if they cost the same
thankkkkkssss mate
5 x without
Thanks for this GB _the_!
What is the UI of this light? (I was not in the last group buy). I have a good collection of small EDC's, with my own perfect emitters, but I'm not able to make my own UI. It would be great if 'they' would do a UI with fast PWM and a 1-3 lumen low low.
Please put me down for two. Engraving is fine if it is available and if not that is ok too.
Nice.
but is there a driver that fit this light in case i want to mod it?
UI is very simple: single mode with reverse clicky. I decided to keep it as simple as possible, so that it's easy to hand over the light to a non-flashaholic.
5 with BLF engraving Please.
Thanks!
Keith
My apologies...add 1 more for a third please
No need to apologize. List updated up to post #32.
*the*: zelee:Is it the same as before with 1 mode?
Nice.
I modded this light some time ago, you need a 10mm driver if I remember correctly.
RMM has some, there are also two possibilities from wight
[WIP] 10mm DD-only LFPAK33 driver
or if you like a challenge
[WIP] 10mm DD+single-7135 driver: double sided 10440 torture for Dual-PWM
Thanks for getting this all together. I’m in for two pieces.
One with BLF engraving.
One without.
I'll take 5 with engraving. Should make good stocking stuffers.
Though - if this takes as long as some of the other Group Buys, I may be speaking of Christmas 2016
Peetz
I would be down for six, that way the shipping is registered. I like the BLF engraving, sort of a spread the word thing that will keep on going….
Thanks…
Definitely want one, engraved. Thanks for doing this!
