Yes. Why change something that works. :)
Done.
interested here in 2x BLF engraved if they cost the same
thankkkkkssss mate
5 x without
Thanks for this GB _the_!
What is the UI of this light? (I was not in the last group buy). I have a good collection of small EDC's, with my own perfect emitters, but I'm not able to make my own UI. It would be great if 'they' would do a UI with fast PWM and a 1-3 lumen low low.
Please put me down for two. Engraving is fine if it is available and if not that is ok too.
Nice.
but is there a driver that fit this light in case i want to mod it?
UI is very simple: single mode with reverse clicky. I decided to keep it as simple as possible, so that it's easy to hand over the light to a non-flashaholic.
5 with BLF engraving Please.
Thanks!
Keith
My apologies...add 1 more for a third please
No need to apologize. List updated up to post #32.
*the*: zelee:Is it the same as before with 1 mode?
Nice.
I modded this light some time ago, you need a 10mm driver if I remember correctly.
RMM has some, there are also two possibilities from wight
[WIP] 10mm DD-only LFPAK33 driver
or if you like a challenge
[WIP] 10mm DD+single-7135 driver: double sided 10440 torture for Dual-PWM
Thanks for getting this all together. I’m in for two pieces.
One with BLF engraving.
One without.
I'll take 5 with engraving. Should make good stocking stuffers.
Though - if this takes as long as some of the other Group Buys, I may be speaking of Christmas 2016
Peetz
I would be down for six, that way the shipping is registered. I like the BLF engraving, sort of a spread the word thing that will keep on going….
Thanks…
Definitely want one, engraved. Thanks for doing this!
We have about 60 reserved in first three hours or so. I'd predict that this won't take that long.. :)
Let's continue with the same pace, and this will be over in less than 24h.
Put me down for one with engraving please.
Two with engraving.
If it’s single mode why don’t use a forward clicky instead?
I decided not to ask for any other changes than the emitter to keep the price down (and this GB fast enough)
