18350 Battery tubes for BLF A6, Eagle Eye A6 and X6, as well as codes for short Convoy S2+ tubes in Blue and Red!
Looks like NEW BARE tubes are at Banggood. HERE I am going to contact Customer service for a resend. Post here if you get a “new” one that fits…
Bare tubes available now! Code: 11a743
O-Rings for Short tubes available HERE
Code 30eed0 for $0.99
UPDATE 11/10
BLF or Eagle Eye tube (Select which type in window)
Code (non affiliated): 76986f Price $2.50
Extra, Extra!!!
Convoy S2+ Short tubes
Code (non affiliated): 9eb033
Extra Clips
Code BLF for 8% off
KeepPower 18350 or Nitecore 18350
Battery Code: e4f96d
Bare Tubes are coming, they have not been manufactured and I will update when they are done
New tubes have arrived, they look very, very good. The anodizing looks more like Eagle Eye or Convoy quality. The EE Tube threads are nice and square, the Manker A6 threads fit both new and first batch lights I have. The length is spot on and they work on all my BLF A6 lights. Looks like the tubes and codes will be ready this week!!! Code coming for the KeepPower 18350 as well…
BLF TUBE (NEW on top)
Head end (NEW on right)
Tail End (NEW on right)
Eagle eye tube (X6, A6) below (NEW on top)
Tail end (NEW on right)
BangGood’s NEW Brand of lights!!!
UPDATE 10/16 New (hopefully final) round of tubes to be shipped out for sample next week. After approval, only three days needed prior to the finalized tubes being ready for sale.
More battery updates:
My meter has been acting up when trying to measure amps, so I found a friend with a clamp on Ammeter and used about 5 inches of 12Ga copper multi strand wire. The results are below on a Spring bypass BLF A6. It has a V3 2B XP-L HI. It seems all the other A6’s I had have found new homes (more on order!), so this is as close as I can get.
Battery type——-A at start—A at stepdown—V rested battery-V after stepdown
SoShine 18350——–3.43————3.30—————4.20—————–4.09
Nitecore 18350——–4.10————3.78—————4.20—————–4.08
Efest Purple 18350—4.14————3.86—————4.21—————–4.05
KeepPower 18350—–4.23————4.09—————4.19—————–4.06
The SoShine is a good battery for the money, but the best in this small group is the KeepPower, though the others are not far behind. I have asked Neal for a discount on the KeepPower when we buy the tubes and will update when I hear back from him.
Just to clear up the GB and keep people from having to read the entire first post here, this is what the group buy is attempting to achieve:
SHORT 18350 body tubes for the BLF A6 and for Eagle Eye A6 and X6 Three tubes in all as listed below.
Two for the BLF A6:
one anodized (no comment to the side, the default tube)
one bare (BARE)
The last tube is:
Eagle Eye threads (EE) and is anodized only. It fits the EE A6 and X6 (BLF & regular) but NOT the X2.
The anodizing will be black for both and should be a match for the BLF A6 on both anodized tubes (may not be a perfect match to Eagle Eye anodizing)
Hope this helps and thanks for bringing up that this had gotten murky.
Post how many you want of what type, and thanks!
UPDATED PICS
Top to bottom
General pic of all four tubes, Head end to the right on all of them
EE full tube head end threads
EE short tube head end threads
BLF A6 short tube head end threads
BLF A6 full tube head end threads
EE full tube tail end threads
EE short tube tail end threads
BLF A6 short tube tail end threads
BLF A6 full tube tail end threads
UPDATE 09-29-2015
Imageshack is my hosting service and is down for some reason. I will post pics when I can I got the other tube (BLF A6) in from Bugsy36 and am very happy with the form, but the function is not good. It looks like the clip cut was not made deep enough, perhaps .005.010” deeper and it would work with all of my BLF A6’s.- It prevents 4 of my 5 A6 tail caps from screwing down enough to activate. Turns out, the thread lengths were wrong on the tail cap end of the BLF A6 tube, corrected and sent to Neal to pass to Manker
Two thumbs up and Rabbit approved!
I have notified Neal of this and he is verifying with Manker that they will correct this. The EE threaded tube I got had short threads on the head end, perhaps .020” as a piece of .020” copper wire in a ring fixed the issue.
As for the form factor… Lighter than the Convoy S2+ 18350. I have a digital kitchen scale, so the weight may not be on the nose, but the difference between them should be. I weighed them all without a battery:
56 grams for BLF A6 no clip
60 grams for Eagle Eye A6 no clip
70 grams for Convoy S2+ with screw on clip
70 grams for Convoy S2+ triple with aluminum spacer
All four types of 18350’s I have (Keeppower, Soshine, Efest and Nitecore) all weighed 21 grams each, so pretty close, but the BLF A6 is the lightest, even with a clip (+2 grams)
The stock BLF A6 with no clip was 70 grams, but like I said, cheap kitchen scale… so this is only a guideline.
The 18350 tubes on the EE and BLF A6 are a slight bit more “slim” feeling than the Convoy S2+ was, but that may be due to the slightly heavier Convoy tube “feeling” bigger.
The function issues are being addressed and when new samples come out, I will keep you posted. Pics will be up as soon as Imageshack is….
FORGOT TO ADD Neal sent a Nitecore and KeepPower 18350’s for me to test in the light for amps…
The results initially were off from my previous results with all the batteries. I am going to make a new set of leads tomorrow and re test them. It looks like the Nitecore may be the winner on draw, with the KeepPower slightly behind the Efest and the SoShine the budget option bringing up the rear with a good amount of amps for the price…
UPDATE 09-22-2015
Due to shipping mistakes, I have only the Eagle Eye thread tubes and Bugsy36 has the BLF A6 tubes…
We are swapping one tube each VIA USPS, so in a few days we will have some side by side comparisons.
Right now, the BLF A6 tubes work fine according to Bugsy36, but the EE do not. The front threads are about .5mm too short to make contact with the driver ring on my EE A6 reliably.
Neal is aware and working with the manufacturer on this issue for the Eagle Eye thread style tube… Easily remedied, but it is not acceptable for production.
Will keep you updated…
UPDATE 09-14-2015
Tubes are on the way to me for evaluation and further pics/tests of the different batteries. In the mean time, more Eye candy… EE style for those that were in on the X6 GB…
Update 09-12-2015
Spoke with Neal at BangGood, with all the clip issues and Bugsy36 taking feedback for a possible clip redesign we have decided to nix the extra clips for these tubes.
There were some initial concerns about the tube price being too high as well, so we have the price now of $4.00(US) for these tubes in either finish for the BLF A6 or the Ano EE X6 one… The batteries will cost more than the tubes it seems, so keep that in perspective as well!
I am looking into the EE threads between the X6/A6 and the X2 not being compatible. I do not have an X2 to compare it with, so if someone has both the X2 and either a X6 or A6, try it and let us know here… We are getting closer to this finishing and the initial run numbers for each type of tube will be sent soon, so sign up if you want some!!!
UPDATE 09-10-2015
Been a while for an update, thanks for hanging in with this. We are not low priority, just that there is other work that was spoken for ahead of us getting in the queue for this… Neal has forwarded these to me to post. I know he has sent back a couple of pre-production rounds when they did not meet his standards for what these should be. See if you can spot the surprise…
UPDATE 08-25-2015
Batteries ————————-Heads (one spring bypassed, the other stock)
Spring Bypass Head With Samsung 20R——- Stock Head With Samsung 20R
SoShine in Spring Bypass Head—————- SoShine in Stock Head
Efest in Spring Bypass Head —————— Efest in Stock Head
I got in an Efest 18350 from RMM’s Mountain Electronics, and a Pair of SoShine 18350’s I had ordered from FastTech a while before all this started. I ran them on my SE A6’s, both are 1A/CW if it matters. I also ran a Samsung 20R (also Mountain Electronics) for a control, as this is the highest drain battery I own, this was a control to show that the 18350’s were not pulling more.
_
Update 08-21-2015 OVER 300 now! I need your help with listing these tubes. If you are on the list, check it, any problems PM ME. If you want on the list, tell me the number of tubes total, and then the number of anodized and number of bare ones. If you are updating your wants, let me know the TOTAL first, then what you are adding. This will help a lot to keep the list straight. Examples below:
Example #1 (new, not on list)- I want 3 tubes total, 1 anodized, 2 bare.
Example #2 (on the list already, adding more) I want 6 tubes total, I have two anodized and 1 Bare already, please add 2 more bare and 1 more anodized.
This helps and I know not everyone here speaks English as their first language, so if you have any questions on adding tube, feel free to PM me!
Update 08-14-2015 Over 200 tubes on the list! The BLF SE A6 is out! Make sure to get on the list for your SHORT TUBE for these lights….
UPDATE #2 Looks like the initial pricing will be $4.50 for one 18350 battery tube with an extra deep carry clip. The timeline for this will be AFTER the X6/K6 Group Buy is complete, so it could be a bit down the road. Sign up and lets show Manker what we can do for them when they do for us!
The clips will be removable for those that do not like them. My alternate method of putting a clip on a light is HERE
UPDATE 08-09-15 Bugsy36 will be talking to Manker about this tonight or tomorrow. The more signed up, the better our chances. We are working the issue to see if the threads are the same as on the BLF SE X6 in case you want a shorter X6 as well. NUTS, WILL NOT FIT THE PREVIOUS X6 GB light…. We are also going to ask for one 18350 tube WITH an extra clip per order. This way, no scratching up our tubes when we switch them out…
Bugsy36, the creator of the Group Buy for the Manker A6 and I exchanged emails about the chance for an 18350 sized body tube being created by Manker for the Group Buy A6 lights.
This would be made separate from the actual Group Buy light so there would be no delay in the almost completed Group Buy he has worked so hard to bring to this point. It is an add on for your light that you have already signed up for, NOT a new light.
I figured while he still has the ear of the very responsive manufacturer (Manker) that has done so much for the group buy, it might be a good time to ask for this. The way I look at this, it is about 30mm shorter body tube that allows you to reconfigure your light to a shorter, more EDC worthy light.
The downside is less runtime of course, but the ability to take 18350, 16340 or LiFePO4 17350 adds to the options… I am only guessing that this driver will not operate on a 3.0V Cr123, but if there are any testers here that could tell me if there are at least lower modes available, feel free to correct this.
I got the idea from my recent Convoy S2+ short host, when I found that the body tube from it would directly screw to my S2…. After I had transferred the driver and emitter to the other pill of course…
I have included some pics here to put it into perspective for those that have an A6 like light already, or those that will (shortly we all hope) begin to get the GB A6.
My stock A6 next to S2
A6 next to S2 with 18350 length body tube installed (same head and switch as first pic)
Parts laid out so you can see the difference in length between the battery tubes. The short tube is backwards though, just noticed this…
My mock-up and bad pic to see what it would look like fully knurled, not to shabby…
Once again, please just list here if you are interested, and I will start a list. There has been no talk to Manker about this yet, first we have to have sufficient interest to see if it is worth asking. I would figure over 200 would have to be requested to initiate manufacturing anyway.
Current unknowns: how long the clip would be on this “shorter” body. The deep carry part would be OK, and it “looks” like it would fit… I would request the shorter tube have the cutout for the clip as well, but it is unknown if it will fit/balance well.
We are going to run with it and ask that every tube has a spare clip, that way you can leave your clips installed and do not have to scratch it up when changing body tubes. This also gives you a spare clip should one break
Thanks again to the A6 team for their effort in making that Group Buy so incredible!
Interest List
1. Kodachrome40
2. Djozz
3. Djozz
4. KeenGeorge
5. KeenGeorge
6. KeenGeorge
7. Werner
8. Muto
9. Muto (BARE)
10. Muto (EE)
11. DavidEF
12. DavidEF (EE)
13. Aslpg
14. Aslpg
15. Aslpg (EE)
16. SciFiFreak
17. SciFiFreak
18. Shimey
19. Shimey
20. Hell2pay
21. Hell2pay
22. Hell2pay
23. Hell2pay
24. Travis
25. Chuckhov
26. Chuckhov (EE)
27. Mhanlen
28. Saypat
29. Henk4U2
30. MRsDNF
31. cabfrank
32. cabfrank (EE)
33. M4D M4X
34. jealous57
35. Wrathbringer27
36. B42
37. Slow2Go
38. Slow2Go (BARE)
39. OscarM
40. OscarM (BARE)
41. ahirshy
42. ahirshy
43. Gunga (BARE)
44. rs4ever
45. Gunga (BARE)
46. ReManG
47. ReManG
48. ReManG
49. ReManG
50. ReManG
51. Sesgum
52. Halo
53. rs4ever
54. richnpc
55. netprince
56. netprince
57. compression
58. carmantl
59. Blueb8lls
60. Blueb8lls
61. Drgadgetstein
62. Drgadgetstein
63. rs4ever
64. rs4ever
65. J-dub74
66. Mattlward
67. Jubeldum
68. Kronological
69. KeepingItLight
70. KeepingItLight
71. bwl123
72. meti
73. Blinky1
74. Ray-o-light (EE)
75. Sivy
76. Electricjelly
77. Twin Towers
78. Twin Towers
79. TheBo
80. rs4ever
81. Billy X (EE)
82. Billy X
83. Finges
84. Finges
85. uqs1000
86. uqs1000
87. prisma
88. Paul321
89. KawiBoy1428
90. KawiBoy1428
91. keithd
92. keithd
93. zipelgas
94. zipelgas (BARE)
95. Charga
96. MikeyX
97. processengr
98. processengr
99. zebroo
100. Streamer
101. compression
102. compression
103. carmantl
104. Sarge930
105. Sarge930
106. rs4ever
107. Tas69
108. Tas69
109. Gj
110. Gj
111. MaxBeam
112. MaxBeam
113. MaxBeam
114. WieselflinkPro
115. AbraKedavra
116. DB Custom (BARE)
117. DB Custom (EE)
118. SeenTheLight
119. B42
120. Chouster
121. Burnsd
122. Burnsd
123. eroheam
124. Fireblade893
125. Bruno28
126. doubleone44 (BARE)
127. Tete
128. Tete (BARE)
129. ReManG
130. ReManG
131. ReManG
132. ReManG
133. ReManG
134. akoposilester
135. akoposilester
136. meteorxs
137. calmaja
138. nofear87
139. ger-slash
140. ger-slash
141. Ray-o-light
142. Ray-o-light
143. Tristanxoxo
144. Tristanxoxo
145. Tristanxoxo
146. Tristanxoxo
147. cbrake10
148. cbrake10
149. Xian
150. Xian
151. Kozy
152. Down South
153. Down South (BARE)
154. incavin
155. H-man
156. Warhawk-AVG
157. Slow2go
158. gorky
159. gorky
160. dthoang
161. D10ten
162. kommessy
163. one41
164. Jack-bkk
165. Jack-bkk
166. Jack-bkk
167. Jack-bkk (BARE)
168. Evilc
169. Chicken Drumstick
170. Chicken Drumstick
171. Stittville Ed
172. Wedlpine
173. Wedlpine
174. Wedlpine
175. Jerrod
176. Modulor
177. Angel Martinez
178. Angel Martinez
179. Will Manners
180. Dave101
181. Vulpes
182. BrJones (BARE)
183. BrJones
184. syracuse
185. myhken
186. myhken
187. myhken
188. myhken
189. myhken (BARE)
190. gleamer
191. gleamer
192. gleamer
193. gleamer
194. melven
195. Chazzy (BARE)
196. Aardvark
197. Maiden666
198. Boaz
199. Boaz
200. Boaz
201. Boaz
202. MG (EE)
203. MG (BARE)
204. MG (BARE)
205. ilovejesuschrist
206. ilovejesuschrist
207. ilovejesuschrist
208. prodal
209. bwl123
210. monanza
211. monanza
212. monanza
213. DBSS
214. DBSS
215. electricjelly
216. cajampa
217. Ormbett
218. BILL G
219. sungsmith
220. bigrick
221. bigrick
222. BorisBar
223. SmokinH
224. RollerboySE
225. ohaya
226. Shadowfax
227. THAO916
228. THAO916
229. Cul8r
230. Cul8r
231. Lilien
232. Siata94
233. Realista
234. allthumbs
235. rollerboySE
236. Vulpes (EE)
237. Phatster
238. Jabe1
239. LEDCODER
240. LEDCODER
241. Duke
242. Duke
243. Bastarrdo
244. XJojoX
245. Nachteule323
246. cajampa (BARE)
247. Nitetime
248. amraspalantir
249. Tommswpa
250. Tommswpa
251. Tommswpa
252. Ray-o-light (EE)
253. HighCaliber
254. HighCaliber
255. HighCaliber
256. Frankie Baby
257. Frankie Baby
258. Frankie Baby
259. Haro
260. Lionheart_2281 (BARE)
261. Sonofspectrum
262. Vene67 (BARE)
263. Maiden666
264. Maiden666
265. jack83
266. Wrathbringer27 (BARE)
267. keengeorge (BARE)
268. brno602
269. monanza (BARE)
270. monanza (BARE)
271. monanza (BARE)
272. Charga
273. Charga (BARE)
274. Gunga
275. jack83
276. jack83 (BARE)
277. J-dub74 (BARE)
278. KloepperKnifeWorks
279. KloepperKnifeWorks
280. KloepperKnifeWorks
281. colliedoggy
282. Cliwilnew
283. Cliwilnew (BARE)
284. gonein12
285. weekeda
286. Cyberescudo
287. tru3s1lv3r
288. argolite
289. apt323
290. apt323
291. Lampenheinz
292. Lampenheinz
293. Steve42
294. Kawiboy1428 (BARE)
295. Kawiboy1428 (BARE)
296. HighCaliber (BARE)
297. HighCaliber (BARE)
298. HighCaliber (BARE)
299. nofear87
300. Jack-bkk (BARE)
301. Jack-bkk (BARE)
302. ReAvenger
303. ReAvenger (BARE)
304. ahirshy (BARE)
305. ahirshy (BARE)
306. stanley-beamish (BARE)
307. stanley-beamish
308. keengeorge (BARE)
309. keengeorge (BARE)
310. vinte77
311. Paul321
312. aslpg (BARE)
313. ToyKeeper (BARE)
314. ykb (BARE)
315. ykb
316. xjsnake
317. xjsnake
318. carmantl
319. carmantl
320. djozz (BARE)
321. bugsy (BARE)
322. bugsy
323. wildthing
324. wildthing
325. wildthing
326. wildthing
327. netprince (BARE)
328. Gleamer (EE)
329. Gleamer (EE)
330. rebelbayou
331. mikeyx (BARE)
332. broken9191
333. RonMuller
334. ger-slash (BARE)
335. fishlite5
336. thslw8jg
337. thslw8jg
338. thslw8jg
339. realtree
340. realtree (BARE)
341. thslw8jg
342. manxbuggy1
343. manxbuggy1
344. tarver
345. sungsmith
346. sungsmith (BARE)
347. Tixx
348. WieselflinkPro (EE)
349. WieselflinkPro (EE)
350. Henk4U2 (EE)
351. Djozz (EE)
352. Ahirshy (EE)
353. Cula
354. Calmaja (EE)
355. aslpg (EE)
356. Muto (EE)
357. chouster (EE)
358. chouster (EE)
359. chouster (EE)
360. chouster (EE)
361. zebroo (EE)
362. OscarM (EE)
363. Hank (EE)
364. Hank (EE)
365. Monanza (EE)
366. Monanza (EE)
367. rebelbayou
368. Nguyen (EE)
369. Bugsy (EE)
370. Finnishflashlight
371. Kawiboy1428 (EE)
372. Ohaya (BARE)
373. Mozart.f
374. puccio1969
375. Frankie Baby
376. Frankie Baby (BARE)
377. Frankie Baby (EE)
378. Frankie Baby (EE)
379. syracuse (EE)
380. Prisma
381. Prisma (EE)
382. Prisma (EE)
383. Johnlate
384. dthoang
385. Evilc
386. Patchman
387. Nitro
388. Nitro
389. Joat (EE)
390. fonfan
391. fonfan (BARE)
392. sesgum (EE)
393. Chazzy (EE)
394. Lazy-R-Us
395. Cabfrank
396. Cabfrank (EE)
397. Cabfrank (EE)
398. Tom E
399. Tom E (EE)
400. Tom E (EE)
401. CrashOne
402. Blueb8lls (EE)
403. Blueb8lls (EE)
404. KiwiKane
405. KiwiKane (BARE)
406. ale9g
407. 1dash1
408. mike lest (EE)
409. mike lest
410. saypat
411. jingleberry
412. jingleberry (BARE)
413. Jingleberry (EE)
414. cajampa (EE)
415. cajampa (EE)
416. cajampa (EE)
417. Andybibbville
418. Fatboy
419. SmokinH (BARE)
420. SmokinH (EE)
421. lumiere
422. lumiere (BARE)
423. nfetterly
424. nfetterly (BARE)
425. Neilyboy
426. Neilyboy
427. JeffN
428. KiwiKane (EE)
429. pooptoast
430. pooptoast
431. dts71
432. juaquin
433. skol
434. skol (BARE)
435. HarleyQuin (EE)
436. HarleyQuin (BARE)
437. chutieunhi
438. chutieunhi
439. chutieunhi (BARE)
440. mundele
441. Neileyboy
442. Andybibbville (BARE)
443. Andybibbville (BARE)
444. pyro1son (EE)
445. pyro1son (EE)
446. 1dash1 (BARE)
447. archimedes
448. archimedes (BARE)
449. Fredylee
450. Cloggy
451. Cloggy (BARE)
452. DBCustom (EE)
453. DBCustom (EE)
454. juruvi
455. norcalnative2014 (BARE)
456. JaredM (BARE)
457. tissen
458. Geo1952
459. Geo1952
460. higbvuyb
461. emarkd
462. emarkd (BARE)
463. Ewen
464. Ewen (EE) Thru post 726
465. WieselflinkPro (EE)
466. WieselflinkPro (BARE)
467. Tixx
468. Tixx
469. centaurus3200
470. Werner (EE)
471. qwopzxnm
472. qwopzxnm (BARE)
473. rvr
474. rvr (BARE)
475. Cbfake10 (EE)
476. Cbrake10 (EE)
477. KramKram (BARE)
478. Mhanlen (EE)
479. khas (EE)
480. khas (EE)
481. cabfrank (BARE)
482. ToastOnFire
483. keengeorge (EE)
484. keengeorge (EE)
485. keengeorge (EE)
486. cavesprings (BARE)
487. cavesprings
488. hoax101
489. Slayer2003 (BARE)
490. cvaty
491. akhyar (BARE)
492. gehrmo
493. thx1138
494. thx1138
495. RTM
496. cccpull
497. Hestbech
498. shan6oob
499. Dba
500. Herb Tarlek Thru post 838
501. radioshaq
502. BorisBar
503.
I think this is a great idea. I’ll be interested in one.
Nice initiative!
I would buy two, assuming that they will be only a few dollars each.
No prices yet, I cannot think that they would cost too much, but everyone has a limit. I would shoot for $5 right now if you forced me to throw out a number. The anodizing would be the same as the original BLF SE A6 of course.
Nothing spoken to the manufacturer Manker yet, so if this looks like 200 pieces would be easy to get, I will initiate that and get a price.
I think you should check with manker asap to see if it’s possible at all, and if so what their MOQ is. I would hate to see everyone get let down after a big build-up.
At $5 - $7 shipped I’d be interested. No biggy if it can’t happen though. But I’d be in for sure if you could get it for that price.
Good Day ReManG,
I would be interested in at least 3 (depending on price).
Thank you Very Much,
George
Edit:
I suggest you shift this thread to the Group Buys subforum.
In.
I am in the process of doing just this…
Done, and thank you for that catch, I must have clicked past it…. NOW in Group Buys for everyone’s pleasure…
I’d do 3 if at $5 or less.
Only problem that may likely happen is the color may not match perfect to the other complete BLF A6 Flashlights.
Different batches, different lots.
Some members get hissy over colormatch issues, so it probably should be listed as “you get what you get, no crying paypal dispute after the fact”
Later,
Keith
I’d be interested in at least two!
Yes, it would be the same as the A6, but with anodizing, it is hard to hold the same color. It would have to be close, but not perfect. There would of course be a “what you get, is what you get for color” clause. Good point Muto
I’m interested in the three tubes.
I’m interested in 2.
interested in two
Please include me for 4 x 18350 body tubes!
Acknowledged that a color match can’t be guaranteed.
Hope that the price and interest make it possible!
Thanks, ReManG!
I’d like one :slight_smile:
I’ll take 2!
Bless You Kind Sir!
-Chuck
