Hey OL, if you don’t yet have belts arranged, send me direct links to what you need and I will take care of it.
Direct links so I don’t buy the wrong one’s.
It’s funny you say that. I have applied 9 times to Home Depot, 7 times to Lowe’s, etc., etc… I have applied to just about every job I figured I could do and some that I figured I couldn’t do, but there was only one two places so far, that were even interested. AT&T and I think they took me because I was a vet and they had a quota to fill. I mean, why would you take a 60 year old man and have him climb telephone poles, unless you were just fulfilling a quota. Unfortunately, I would have had to move to Dallas or Oklahoma and I just can’t do that. The other place was the local armored car place. I’m still waiting on them. I don’t hold much hope. The guy sounded all gung ho, but nothing to back up the words. Other than that, I have just been refused for all the rest. Personally I think it’s age and the fact that I was in management for most all of my life. Most places don’t want an ex manager in the hourly ranks, because we don’t take orders too well, LOL. Well, it’s true.
I've been working on getting the initial break in run done and have found a way to "make belts work", for long enough to get that done, but there's a couple of bearings that I think are bad. There's three sets of drive pulleys and one set is on shaft and used as just a means of getting power from the motor, to the drive gears and also to get the desired speeds. It is driven from the motor with a cogged belt and then uses a V belt to the drive. It was noisy from the git go, but it's just about howling now. I took it off and lubed down the shaft, but the bearings are most likely sealed. Dry and sealed. Anyhow, I made a video of it, so Grizzly could see and listen to it and that way they can't say it's "normal". Well, maybe they can, but the audio is pretty damming, so I hope they will warranty it and send a replacement.
It's one of those things. It's Chinese, it's relatively inexpensive, compared to expensive lathes, so it's bound to have that Chinese aura around it. It just has to have all the bugs worked out, before it will fly. I went back and tore down the Cross over and Compound again and I wet sanded with oil and 320 grit paper, all of the dovetails and flats. Now they are smooth and the cross over has just about 0 backlash, while the Compound is down to about 0.002". I found several things wrong inside them, but managed to work out all the kinks. As I say, it just takes time, to work out all the bugs.
First...Bearings....at the outset take whatever bearing they send you BUT remember that Chinese bearings are crap. What you really want are Japanese bearings. IF..and IF you can...pull the bearings (after speaking to Grizzly) and find a Miller bearing dealer and have them spec out the bearings - most likely by size. They may not be as expensive as you think. High speed and ceramics get expensive quick.
Next..
I get the age thing. I am sure many other people do here too. At the same time there ARE employers looking for the seasoned ones. HD and Lowes are two right off the bat BUT usually unless there are many stores there you usually do not get in as quickly unless the unthinkable happens. Those stores, and MOST hardware stores, want older young guys that have experience to be able to help the customer because they need it. They (seasoned employees) are the 3rd biggest marketing tool they have.
Your strength is your knowledge and experience. The 20 yr olds will always be faster than us, often stronger, BUT nowhere near as reliable because their interests have more pull than a John Deere LOL. I know nothing of the area you live in (sounds like a small town), nor do I know your work experience, BUT look for management, supervision, consulting, etc. Every profession needs them.
Furthermore..DO NOT state unemployed..NEVER EVER EVER. You can say you were "laid off and became self-employed but that full-time self-employment is not for you'. You are and have been self-employed you just never made big profits - yet! :)
So in the meantime...learn that new toy but don't get hurt. I think it was Rufus talking about little things to sell while getting practice with feeds and speeds of different materials and threading. While maybe monotonous they CAN make you a c-note here and there and they do add up. Then even do what Sinner and VOB have done by making little lights. Christmas IS coming!
Just remember the sign I had in my repair shop:
All Customers and friends must pay for services rendered.
We did a survey and found that only our friends did business with us and
since our customers are our friends and our friends are our customers
we must charge for our services in order to keep providing our services.
I don't know, but HD passed me by a bunch of times. When I go in there and see what they did hire, I think maybe their previous job, before HD, was holding up a sign at a corner.
Anyhow, I go to Dunbar Armored tomorrow. The guy told me I would interview, do the driving test and sign all the paperwork, so it seems I might have a job after all. Hope so. 30 hours a week, but it's much better than no hours a week.
congrats on all the new gear OL, you'll have a complete hoot learning how to use it all, then the world's your lobster :)
I'm not sure if you have a set and/ or if there's still cash in the kitty, but a decent wire drill set (1-60) is a very useful addition to a 29pc fractional drill set if you plan on tapping many holes. I sure wish I had one! Also a set of S&D drill bits is very handy if you need to open up a large hole and saves a ton of time compared with using a 1/2in drill and then using a boring bar the rest of the way. If you end up using much HSS for turning/ boring a medium and hard Arkansas stone (or a diamond hone) will put a lovely edge on your bits, especially for turning aluminium.
I never tire of using my lathe and it'll be even better once I get a treadmill motor and tach on it, then it'll have variable speed at a twist of a dial.
