Ramping is one of the ui’s available for e-switch use. A resistor change can reduce the max current. See the into thread for the formula to choose the correct resistor value for a given max current.
I'm not sure if my post/answer about ramping is deleted,so I'll repeat (and definitely must refresh OP):
Ramping UI is removed in LD-2,instead of that,UI_2 in now "discrete ramping",so by holding switch you ramp up/down through existing discrete modes (moon,low,med,high),double press toggles mode between min/max,normal press is on/off (last mode from off),long press from off is for lowest mode from off.
what happened to the info thread? it doesn’t load at the moment:
Yep. noticed that too. The matrix is being wonky this morning!
Ledpower is working with SB to fix it
Price and minimum quantity drop!
Minimum order quantity for European Union countries is now 1 piece,and only 2 pieces for rest of the World.
Also more max. current set resistors choices now:5A,7A,8A,9A,10A or 12A
Added: STANNOL 0.7mm HS10 solder wire
2S-4S parts are currently out of stock!
Have you done any further testing with the remote board idea?
It's still in progress.
Thanks for dropping the MOQ
Moved to info thread:
[image] LD-2 [image] Parasitic resistance of common drivers Important note! Driver comes with both solder jumpers unsoldered(driver's bottom side,1cell or 2 cell operation),so user must solder one of them (1S or 2S,never both at the same time) for proper operation. More under 2S (2x) Li-ion cell operation for “6V” LEDs" section. Useful links: LD-2 prototypes testing by djozz and HKJ(great reviews as usual,thanks guys): https://budgetlightforum.com/t/-/33245 https://budgetlightforum.c…
Any thought of making 22mm driver’s?
Plenty of 22 mm adapters available. The production cost of this board might make it hard to keep affordable in several sizes.
2xLi-ion(“6V”) support parts 1.0$/set (for one driver) - CURRENTLY OUT OF STOCK!
I would like to ask when it will be available again?
Thanks!
1-2 weeks.
Order placed for 5 more drivers, 4 full resistor sets and 2 moonlights+tracking.
Thanks for making these drivers and lowering the min order amount, they are awesome so nice to not have a turbo timer !
2xLi-ion(“6V”,2S) support parts are back in stock,also I added options for 3S and 4S cells support.
Is it possible to order 1 or 2 of these to the UK fully setup to go with moonlight mode and 6V support, all soldering done?
Yes,min. order for EU is 1pc.
Update 15.12.2015.
*Added LD-M2.
*Shipping price is now separated,no minimum orders for EU,25$ minimum for rest of the World(excluding shipping).
