HT-PE = counterfeit Cree XP-E (very likely if you compare 3 small holes around the dome)
Here are 2 SK68’s
The one on the left I got about a year ago and has a driver, no modes but it runs on AA or 14500
On the right is one of several my brother gave me 3 months ago. He got rid of them because they are DD and do not run on AA
On a 14500 the one on the left draws 1.6A and is twice as bright as the right one which draws 2.2A and is blueish
These new LED’s are the worst of the worst!
I am definitely retracting my comments! I did not realize that this problem is as bad as it is.
It looks like the discerning feature on the counterfeit XP-E emitter is the phosphor layer that extends beyond the edges of the die.
Also:
Open through-hole on corner of emitter base
Smooth surface of emitter base around dome, vs. rippled on genuine emitter
I’ve received several lights from recent eBay purchases that had “XP-E” emitters installed. Several of those were extremely blue-tinted, and performed poorly, even after being transplanted into a properly-driven P60 pill for testing vs. a known-good drop-in. I assume these are being shipped out in many of the sub-$5 lights we are seeing on eBay, and probably other sellers as well.
I’ll look at my salvaged emitters when I get some time to see if I can spot the fakes next to the good.
I’m surprised at how good these clones look, at least superficially. They don’t have the same level of cheapness I’ve come to expect from the budget fried-egg clones I’ve received in so many cheap lights.
Thanks for the photo Dchomak. ( photo added to OP) there are obvious differences in the XP-E and fake.
DX replied. They said they will talk to the manufacture and let me know the results. Let’s see what they are going to say.
Looks like most Cree lights are actually not Cree even if the Cree is printed on the flashlight body. They are not that bad but shouldn’t mislead people.
It appears that the moral standard is going down for these Chinese manufactures, especially in the flashlight area. (Well, the record, I am Chinese also :-)). How can someone claim the 18650 Li-Ion batteries have capacity 4000mah or more, but knew them are maybe 1000 mah or less? The AA/14500 flashlight claimed to be 600lm is actually less than 100 lm and flashlights that are actually about 300 to 400 lm to be 2000 to 3000 lm? I have never seen such shameless and outrageous claim in other product area. Well, maybe I just don’t know the reality today anyway .
What about this one?
This is one from cheap (less $3 from ebay) “Ultrafire S6” “CREE Q5”
Classic “Chevrolet Corvette” for sale:
800 HP, 0-60mph in 2.8 secs!
63mpg city/78mpg hwy
$25.99
(763 reviews)
Wow, very convincing too, only difference I see is: the small square in the corner should be a round dot. But my first guess would be that it is a Cree led anyway.
You are probably to young to remember the boombox and amplifier wars. Back then, you could buy a 1500 Watt Stereo system for $50!
There were terms like “Instantaneous Peak to Peak Power” etc.
Here is how the term “Instantaneous Peak to Peak Power” can be used (mathematically) to inflate power ratings.
Watts = E x I, but I = E/R so E x I can be expressed as E squared/ R
So say you had 100 volts AC across a 50 ohm resistor, the power would be 100x100/50 which calculates to 200 Watts.
But in AC voltage, the voltage varies as a Sine wave. That 100 Volts is an “RMS” value (sort of an average voltage) and actually hits peaks of about 1.4 times that. 140V at the peak. Now if you use THAT number to calculate the power you get 140x140/50 which NOW comes to 392 Watts!
But we are not done yet! AC voltage varies both plus and minus, so the difference from the peak plus voltage and the peak minus voltage is twice the 140, or 280 “peak to peak” Volts. Plug that number in and you now get 1568 WATTS
So, just by doing some math, they could now say 1568 Watts instead of what it actually is, 200 Watts.
Still not finished though. The term Instantaneous. The thought was that the output wave form could have spikes that peaked at over 140V, if only for an instant, so lets use that number. And on and on. So when the wattage was rated with the “Instantaneous Peak to Peak Power” method, they could use any number they wanted.
The lumens and mAh ratings from these guys follow a similar (dishonest) formula, I just never have bothered to try and figure it out.
And then there were the wattage ratings of speakers………………
For audio amplifiers, the easy check to verify actual max wattage was to check the current rating of the fuse…
Invariably, always less than the amplifier’s stated wattage would account for…
This is already going on for a while: I just checked an ultracheap 'dive light' that I bought ages ago, can't find it back but it was somewhere in 2014, this is the led:
Now side by side…
I can see that the core is smaller in the CREE, like EZ900 vs. EZ1000 in XR-E series.
It is also different as the wires are inserted into the core.
I was not too young to experience the time period that you mentioned. I was just not in the USA. (Probably as an electrician in a small town thanks to the cultural revolution initiated by Mao at that time. But that’s another story.)
As for the lumen and mAh justifications, I don’t think these people even bother to do that either. They just put the numbers on their product to catch people’s eyes and not many people will bother to check. Another thing I am puzzled about is: Even with such fake claims, where did they got so many positive reviews.
To another extreme, now I don’t trust any of the claims. That is why I would like to put my hands on some testing equipments that I can use to verify or dis-verify these claims. Battery capacities are easy. Lumens are more difficult.
Another discerning "feature" I've noticed is that most of the Cree LEDs silicone have a stippled or "orange peel" appearance on the flat part of the die. The RGBW Cree XM-Ls also have the stippled appearance like the XM-Ls. [After reading this, the next batch of LatticeBrights will probably also be stippled].
Interesting, i wonder how long the sellers have actually been sneaking these Cree fakes in under our noses before we finally caught on now to whats been happening.
The probably will now that they know we are on to them.
I opened another flashlight, i.e., one of those “2000L Zoomable CREE XML-T6 LED 18650 Flashlight” flooding the market. Sure enough, it is a LatticeBright version 2.0. I am starting wondering if any of these with the name of Ultrafire on them are real Crees or they are all LBs.
It is not that bad actually except for a little lower light output. They should just mark as LB rather than Cree.
Just checked some of lights.
Found few LB LEDs.
My comparison pics for the record:
LB/XM-L
XP-E/LB
i found what appears to be a fake xp-e in one of my sk68 clones yesterday. i bought one of the gearbest camo-sk68 a while ago, and that horrible bluish tint had to go, so i de-domed it.
when i compared it to a couple of my other xp-e sk68 i was surprised. the de-domed focused led had only a slightly smaller hotspot than one of the others. when i looked closer the led looked like a xp-e but with a smaller die.
i thought that maybe it’s a xp-c then? but it had three strips and two bond wires, just like the xp-e but with a smaller die.
so after reading this thread a bit more and looking at other fakes i suppose this is a fake cree led, since the phosphor seems to extend outside the die, and the dome isn’t clear like the cree.
the tint isn’t good, can fake cree be de-domed as well?
