The redo is finished except for the driver.
I have had these ideas for some time now and I finally got a started on building my first XHP-70 light. From reading about the other mods and builds here, it seems to me that the most difficult part of building one of these is coming up with a way to power the LED. The XHP-70 can be configured to run on 6V or 12V, I am choosing 12V 6V. Ideally I suppose, running a 6V configuration with a 2S configuration and a driver is ideal. 2S hosts are common and easy to come by. What is more difficult are the 2S3P hosts, and if more than 1 LED is used then 2S3P is definitely preferred for it’s capacity and run time.
EDIT: A 12V drill pack will only DD an XHP-70 at a little over an Amp when fully charged and will drop rapidly as the pack discharges. I am going to use the same 12V drill packs but with a buck driver. ImA4Wheelr has offered to help with this.
Building high current cell carriers is difficult and there can be all kinds of issues with contact resistance, springs etc. Besides, it’s just a lot of work. So I thought, why not use a cell pack that is already available, has to contact issues, springs etc. A 12V drill pack. The other advantage is that if one has the mating charger, charging is fast and easy. Also drill packs are already intended for very high current outputs, perfect for driving high power LED’s such as the XHP70 or MTG2. And I almost forgot, they are already protected from over discharging. They simply shut down.
The following is NOT intended to be a finished product but rather just some of my ideas on how to pull it off. There will probably be many changes before I finish, the first being that I will use+ Black ABS rather than White PVC
It just so happened that I was able to come across a good number of 12V 4AH Ridgid drill packs at a VERY good price. Normally a 6 cell, 3S2P pack, would sell for $69 each. These packs contain 6 Samsung 20R cells. Plenty of capacity to drive an XHP70 (or 3!) I, and others here, were able to pick these up at Home Depot for $18.02 for a 2 pack. That is just $9 per 6 cell pack. Because of that price, in my opinion, these just scream for use in a flashlight build.
Remember now, this is just a proof of concept build, it won’t be pretty.
The deal. Originally, buy one pack for $69 get 1 free. Here are the 2 for $18.02
For the host I will use the head of a Defiant 3D from Home Depot. I chose this because I already have some and they have a big head and a massive pill that takes a 20mm star.
What I need to do is mate this head to one of the 12V Ridgid packs. Also, I must be able to change out the Ridgid packs easily for charging. In other words, they must plug into the light just as they do when used in a tool.
Now pics of the redo.
As before I had to bore out the ABS tube for the drill pack.
Once it fit I then had to notch it for the locking clips.
Then I had to make a “socket” for the drill pack to plug into. The point of this build is use a power source that is already constructed and easily swapped out and recharged.
This 19 piece hole saw kit I got years ago comes in handy often. Having the ability to choose 19 different sizes comes in very handy and usually I can find a good match. I think what is an identical kit can be ordered online at Home Depot and shipped free to your nearest store. I got mine from one of those traveling tool shows, you know, where they pull into a motel or parking lot with an 18 wheeler and sell out of the back of the container.
I used clear Lexan so that after I cut out this disk I could see through it to know where to cut the holes for the copper plug connectors. That disk coming off the hole saw is a perfect fit!
I made 2 just in case…..
I used those cheap or even free Harbor Freight sissors as tin snips to cut the copper flashing to form the “plug” connectors.
To make sure that everything is aligned perfectly, to allow battery packs to be easily removed and inserted, I had to first plug the connector into to the battery pack and then slide it into the tube to be glued. Only that way could I be sure of perfect registration.
Assembled light with the 3 cell battery pack inserted
And the 6 cell pack, for double the run time
So now what to do with the battery tube, after all it is ABS plumbing pipe! After I cleaned off the print with some lacquer thinner, I tried free handing a well known logo. Besides, just having this on a light seems to increase it’s lumen output by a factor of 3!
For some reason it didn’t help, so I removed it and spent about 10 minutes at the buffing wheel.
Here it is with the double pack, 6 Samsung 20R’s inside. Not as pretty, but twice the fun!
As I mentioned earlier, all I have left to do is get and install a buck driver that can handle 12V in and put out a maximum of 7A to the emitter at 6V. For now this light is DD running an XHP70 on a sinkpad configured at 12V.
08/14/2015
Actually I finished this up a week or so ago.
All that was left to do was reconfigure the star to 6V and add a driver.
The driver was built by ImA4Wheelr and to that I am very grateful! He started out with an HX-1175b1 and installed special MCU and custom firmware! Now I have moonlite, low, …. all the way to bright and freaking bright. Turbo, aka Freaking Bright, steps down to just Bright, 5A
after a couple of minutes because of the heat that 7+ amps generate. He also heat sinked and potted the driver and made a copper ring that serves as a shelf for the driver to set on in the head of the light. Much thanks, he put in a huge effort on it for me.
Here are some pics of the driver.
And these before he potted it.
Like I said, it installs in the head of my light and a copper insert that acts as a shelf for it to sit on. Then the battery tube screws down onto the driver clamping it between the copper shelf and tube. Good heat transfer from the driver to the head! He tells me that keeping drivers cool is becoming a more important consideration as these lights get more and more powerful.
The beam shot 6V, 7A+
Compare this to my Sleeper Light finished just last night 12V, 5A
Cool! this really gets the creative juices pumping…
My Favorite Modded Lights: X6R, S8 , X2R , M6, SP03
Major Projects: Illuminated Tailcap, TripleDown/TripleStack Driver
Nice use of the drill pack
https://www.flickr.com/photos/akrylamid/
Very nice concept. Should look pretty decent in black ABS. What size diameter driver you would like ideally?
EDIT: Not a driver expert. The FET BLF drivers work with the zener diode mod or with a voltage regulator chip like Rufusbduck did to a 105c way back. Are you going to go momentary switch?
Yeah, momentary switch. I suppose any size driver will work, I just need to know exactly which one or which parts.
I think the zener mod is merely a simple, crude regulator for the MCU. With 12V in the zener shunts the power input to the MCU so that it is not over volted? Normally the zener mod is for 2S builds, but this is 3S. Will that zener have to work too hard with the 12V in? etc, etc.
What’s the fully charged voltage of the packs? The XPH 70 has a Vf of 12.5V @ 2.1A so to get 6A you’ll need a bit more voltage. Simplest might be an Zener modded FET driver from Mtnelectronics though a bit more than a 200ohm resistor might be in order. A buck driver needs a volt or two over Vf to deliver the goods so that would require a bigger battery(like 14.4V). With a decent switch you could probably skip the driver completely but it’s unlikely you would see 6A. For that you might need to go to an H6flex and 18V input.
Scott
!0 out of 10 for creativity and execution. I've been using this 5 amp driver with 3 26650's getting about 4.7 amps at the led with the led on a 6 volt star. If you want to run 12 volts at 5 amps that would be double the current (edit should be wattage) that I am. Wowsa.
http://www.lightmalls.com/5-2-12v-5000mah-dual-lithium-3-mode-led-circui...
djozz quotes, "it came with chinese lettering that is chinese to me".
Fully charged these packs are 12.6V but that would drop relatively fast. For some reason I thought 12.6 would greatly over driver this LED. I just searched for a graph of VF and current and can not find one. All I can find is 11.6V yields about 1A. If what you say is true then I am SOL, unless it is possible to use a driver to run at 6V. I don’t know it there is a driver that can run on 12V and drive at 6V
That’s good news, so there is a way to drive at 6V with a 12V pack.
First things first, I will do DD with a partially discharged pack and then try fully charged packs and see what I get. And all along up until now, I was worrying that DD and a 12V pack could blow the LED.
The second sticky in the first general forum thread LED Flashlight – General Info is Led’s & OTHER STUFF . Bookmark it.
Scott
The HX-1175b can drive a 6v emitter with 3s and 4S li-ions. RMM and others have had issues with it blowing 1S XM-L2's over like 5 amps.. I don't know if that is because it was bucking all way down to 3+ volts or if it continues to ripple at higher Vf's. I've driven 1S MT-G2's beyond 12 amps without issue, but we all know that MT-G2 is one tough hombre.
Did I read that right?
you have driven an MT-G2 over 12 amps with a single cell? aka 1S
did you use a boost driver to get the voltage up?
I guess it was an IMR/INR cell?
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
I think in this case the 1S refers to the led. The driver is buck and is fed by 3-4 series liion cells.
Scott
^ RBD has it right. 1S emitter driven by 3S or 4S cells. No boost ability. Sorry for the confusion.
The driver's flyback diode is only rated for 10 amps. So I recommend only driving up to that level. That would be equivalent to about 5 amps with the emitter in 12v configuration.
Could a hobby charger be used to charge up the packs you plan to use by just connecting the positive and negative terminals?
That enable adding a port and charging in light if you didn't want to pull the pack often You could just also solder the tabs for a real good connections. I'm asking because I have a couple of these battery packs too, but no pack speciific charger for them. I do have an Accucell 6 though.
Most of these types of packs have a tab for temperature sensor. It would be cool if that could connect to the hobby charger too. I'll give it a shot in a bit.
how about using this driver for the LED?
wasn’t entirely sure how much amps you need but a regulator like this should work?
“Have you forgotten about all those who called you a Bringer of Woe and hunted you like an animal?”
“Normal humans don’t go around killing people and burning towns!”
“Don’t worry. I’ll go with you! So you just follow me and no arguing, okay?”
^ That does seem like an interesting idea. Maybe 2 of them. One for each channel going to the Emitter. Could have external pots for them to control current.
Hobby Charger Update: The pack can be charged by a hobby charger just connecting the Pos and Neg terminals. All 3 banks fully charged to the exact same voltage. Don't know if that is due to internal balancing circuits or just luck due to new cells.
It appears that the center terminal between the Pos and Neg terminals is for the temperature sensor, but I'm not sure how to connect to my hobby charger since it has 3 wires (Red, Black, and White) for temperature monitoring.
The battery pack has some other terminals that I don't know the purpose of. No voltage measures at them.
It’s possible the eBay buck regulator is not current controlled. I. E. You can set the current and voltage for a given input voltage with the pots but if input voltage changes as with a draining battery, then both output current and output voltage might change. I don’t know for sure and they sure are cheap but you might consider testing one before building the guts of the light around it. It might work anyway but just not maintain regulation. Or I could be full of it, I often am.
Scott
I am waiting on solder paste to flow the emitter. I will then take some reading of current draws and post them here. It looks like I will have to rethink this setup somewhat (I figured I probably would)
I restarted this build from scratch, Using black ABS and eventually a buck driver.
I posted the changes in the OP. The light is finished except for installing the driver
Nice changes. Looks good.
PM'd you to work out the details on driver specs.
Nice build!
The Ultrafire name drawn on should give it and extra 20,000 lumens.
I think I sharted myself from laughing so hard !!
I was in a rush last night when I skimmed the new OP. Like the two above, the Ultrafire logo was just too funny. But I have to say, this shorty version of the light looks damn good. And, it appears to have a actual functioning anti roll feature with stable tail standing capability. I likey!
That's a wild build! Very nice looking light when it's done. Polishing the plastic really made it look good!
Well done.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
08/14/2015
I updated the end of the OP with info on the newly installed driver with pics and beam shot.
What a nice looking driver. Do you think ImA4Wheelr will do a group buy on them?
Both beams look good and it shows what the difference between 42 and 70 watts is.
Looks good dchoman! Was starting to think you permanently parked this project. Just when the suspense wasn't killing me anymore you pull me back in! Is the UI growing on you yet? The FW is JonnyC's Star Momentary modified by Tom E for strobe.
At 7amps, the driver doesn't need the heat sink augmentation. The heat sink augmentation is the large copper adapter disk and the 2 copper tabs covering the large fly-back diode and a portion of the current sense resistors. The Fujik is there more to protect the MCU and air wires from shorts and breaking. I augmented the heat sinking in case dchomak should ever decide to really soup this light up by adding more current sense resistors. I've taken this driver to 13 amps with MT-G2 and at those currents the augmentation is needed. Someday, I may have to short the resistor bank to see what happens with this driver.
In the future, however, we should have the ability for the Attiny25 to throttle the current back and forth as temperature of the light changes. Then, heat sinking the driver will be desired to have a faster response time.
I won’t be changing anything about this driver soon, it is perfect just the way it is. All lights should have a UI like this!
In fact when I was about to shoot the beam shot I used the moonlight mode to find the camera I had laid down in the grass as I was in total darkness at the time. Right now, this is my favorite light
I don’t know, YOU
askplead with himThis light throws a little better, but I don’t think it puts out that much less light. The law of diminishing returns, you know. Even though the reflector of this light is smaller, it throws better than the Sleeper. The effective reflector of the Sleeper is really a small section in the center. The rest of it is just the vestige of an old design for an incandescent.
Now I’ve got to put one of these XH-P’s in a larger reflector!
Yep. Thats what I was looking at the law of diminishing returns. Saying that the components will affect the result as well as we all know.
Just rambling now but I'm building more lights now at lesser currents to suit different needs as in testing without any measuring devices other than my eyes and a tree at about 100 meters away found that an XPG-2 at 2.2 amps in a tiny reflector will light up the tree as well as my original stock standard, never missed a beat Trustfire TR-3T6 that when new blew me away with how much light it through out into the stratosphere. How times have changed in a short period with the efficiency of new components.
