Le_Zouave
(Le_Zouave)
July 29, 2015, 8:30am
38
HKJ
(HKJ)
July 29, 2015, 8:44am
39
The quick charge is probably using usb power delivery standard, but as long as I cannot use it there is not much point in reviewing adapters with it.
If anybody see some circuit boards than can be used to trigger it, please post a link to where I can get it.
joevik
(joevik)
August 10, 2015, 4:20pm
40
You could give this lenovo USB charger a go. Would be interesting to see how safe they are.
You can find it here
HKJ
(HKJ)
August 10, 2015, 6:03pm
41
I have ordered it, but it might be some time before I have a review ready.
joevik
(joevik)
August 10, 2015, 6:15pm
42
No worries mate. Thanks for sharing your work!
tempo
(tempo)
August 18, 2015, 2:48pm
43
Woody
(Woody)
August 18, 2015, 4:25pm
44
I’m confused whether they actually include batteries - it does say “Battery not including”, but also says “Built in18650 batteries can be replaced …”, so I suspect they aren’t included, which makes it a little expensive, compared to, say, the Xiaomi powerbank.
I also love the “Panasonic or Trustfire? It’s your choice”.
eriston
(eriston)
August 19, 2015, 3:47pm
45
HKJ
(HKJ)
August 19, 2015, 4:24pm
46
eriston
(eriston)
August 19, 2015, 4:31pm
47
Hmm, if they are similar they are not very accurate then :_(
HKJ
(HKJ)
August 19, 2015, 4:51pm
48
They are fairly accurate, what do you expect better?
eriston
(eriston)
August 19, 2015, 5:35pm
49
I may have misunderstood your tests, but I thought they were less accurate than this other one that you tested too:
USB meter: KCX-017
[image]
Official specifications:
Input voltage : 3V-7V
The input current : <3.5A
The display : voltage, current, discharge capacity ( total of 10 groups can be stored )
Current can be calibrated
I found this unit on Ebay at a dealer called missjun2010
How does it look
[image]
[image]
[image]
The button is used to select memory with:
One long click: Select next memory and clear it.
Double click: Enter view mode.
Click in view mode: Show next memor…
HKJ
(HKJ)
August 19, 2015, 6:09pm
50
It is about the same.
Look at the "Display U" column with current=0 and the "Display A" column when I test with different currents.
Voltage will not be very precise when current is flowing, it will be something between voltage at the input and the output.
The one with the lowest resistance will usual be the winner (That is a very important parameter on these meters).
tempo
(tempo)
August 20, 2015, 9:26am
51
4xAA emergency powerbank wiv flashright:
http://www.ebay.com/itm/121274503719 (cheapest, in all colors)
http://www.amazon.com/dp/B00I0RA3XE (same one, in black)
http://www.amazon.com/dp/B00HCBHZV2 (seems to be from the same factory)
zelee
(zelee)
August 31, 2015, 9:53am
52
HKJ please test this Power Bank
cajampa
(cajampa)
August 31, 2015, 11:20am
53
+1
That one looks like the most advanced i have seen yet.
I hope it is a good one, 8x Sanyo 3500GA should be about as good match as anything out there i think to this powerbank.
Hi HKJ. Just saw this on GB and would like to have your review if possible Even if the answer is a negative, I want to thank you once again for all the great work you do.
http://www.gearbest.com/cables-adapter/pp_77158.html
and this one too.
http://www.gearbest.com/car-gadgets/pp_203508.html
Glenn7
(Glenn7)
September 3, 2015, 12:53pm
55
HKJ
(HKJ)
September 3, 2015, 5:04pm
56
I usual do not do car adapters, but I have ordered this one and also the other one.
HKJ
(HKJ)
September 3, 2015, 5:05pm
57
Interesting, if this ever get made it could be interesting to test it.
