BLF Designed Budget Thrower GB Question
Cross pollinate: https://budgetlightforum.com/t/-/35147
I think that I like this thread better.
The other light is too big for a pocket (as is this one), but at least this one does not pretend.
Thanks,
-Chuck
Agreed… if I wanted a pocket thrower, I’d mod a C8 or something.
I want a BIG head Monster Budget thrower. I’m talking 65mm or larger reflector diameter… 70-80mm is better.
I would like a blf trower . Personally i like the 3 x 18650.
It gives you more runtime so you dont need to swap battery’s every 2 minutes especially with a high amp led xD
Courui D01 is already a budget thrower and uses 3x 18650 in parallel for long run time. It has been modded lots of times successfully by different people. What I’d like to see, if a BLF Courui D01-SE is born, would be a FET +1 7135 driver with TK’s A6-SE firmware, a XPL High Intensity emitter, and better wiring throughout (tail-cap wiring is currently quite stupid) to keep the amps high to the emitter.
I’m already a big fan of my thrunite tn31, so a big headed flashlight is no problem for me. It’s kind of fun to bring out the big boy and watch everyone else’s jaw drop in awe.
^ +1 on Every David just said.
I already planned on a D01 anyhow… if I can pay a wee bit more and get a much improved light pre-modded to BLF preferences, all the better!
+1 but with 86mm reflector from kaidomain. That would be my Dream with a driven Hard XHP-70 i know it would not be very throwy with this LED but a Monster
Is there ANY that size? I’m thinking about the Maxtoch 2X
Its 68mm dia
Now I think the issue would be either to run a GB for light with the Acebeam K40 kinda build or the plunger styled lights…
What you have just described is EXACTLY what I want, David!
I have an Acebeam K40M and it needs a THROWY partner:-)
Thanks!
-Chuck
+2 :bigsmile:
Oh yeah, just remembered - the Courui D01 needs a better thermal path from the emitter. The thin pill/plate that is used in the stock light is not going to work for a hot-rod mod! Some guys have already in the past made and sold replacement pills for this light, so we at least know what we need already. :wink:
So, if we’re in agreement about the BLF Courui D01-SE group buy, who’s gonna be the one to get it going? 8)
Well, I for one like the way you’re thinking, so How About You, David?
Thank you very much!
-Chuck
Ha-Ha-Ha-Ha-Ha-Ha! :smiley:
Oh wait. You’re serious? :open_mouth:
Sorry, haven’t got the time. If I did have any spare time right now, I’d be working on my contest light. :frowning:
I have been wanting a GB for a Thrower. It seems the magic number for GBs is $20.00 to $30.00 how much can you exect this GB to be?
@DavidEF,
Actually I Was being serious.
Who more knowledgeable than you, a Man that understands the parameters ahead of time, and (with permission) the driver all sorted out beforehand?
There is Always a way to make more time (is a divorce all that bad?) - Just less of this and less of that in your life, but just think about all of the praise you will receive from the BLF community! - WE are Many, and will support you all the way! - That should be what’s really important to you. - Helping Others.
Hey! - We Love You Man!
I’m Totally Convinced that… You Are Da Man for This!
Just Roll with it man… :slight_smile:
-Chuck
:slight_smile:
I don’t remember if anyone else has suggested being able to lego X6 or A6 bodies and extensions but it might be nice.
:slight_smile:
BLF is you. Start a thread and make it happen.
