【NEW】LUMINTOP SD75: Maybe The Best Brightest XHP70 LED Rechargeable Searchlight 4000 Lumens 652 Meters
He accidentally turned on caps lock and doesn’t know how to turn it off :bigsmile:
:smiley:
He he 8)
Would you please tell more about SD75 modding? How are you going to mod it so that it will smoke K60?
Also, why do you think the magnetic ring makes modding harder? (other than that you can't so easily change the driver to adjust the modes)
I'd love to have SD75 to see how it performs against K60 (both as stock and modded), but I'm way too low on funds at the moment. :(
Maybe Lumintop could send one to me for review? ;)
Hey, hey…get in line, bud.
Where’s this line at 8)
No matter where, you are at the end of it, LOL.
Send me one. I will give it a real honest review. Meh....
Then I will give it away once I jumper the resistors.
Jmpaul320 OTF Lumen Sphere Readings & throw measurements! | Candle Power Flashlight Forum! Seems the K60 driver is limited :_( , Vinh won’t boost it, because it won’t take it? Magnetic ring is a PITass, never again after my K40M. So the SD75 will be EASIER to take apart, with out damaging little magnetic thing’s and worse case if the SD75 can’t be boosted, the driver will be ripped out and a FETDD will be in? Then I’ll shave and polish the dome for a little more throw. I have a few XHP70’s that are pulling 10-11 amps, so will this one, so will this one! :slight_smile: :bigsmile: I think that might just Smoke a stock K60? Which one has the bigger reflector again? :wink:
K60 4000 Lumen? :_( Isn’t that MT-G2 territory? :bigsmile:
Just put the story about SD75 to explain the posters , hope that can make sense for your guys
I cant wait to be able to afford one of these. First flashlight i have drooled over, and wanted at first sight. Looks very well thought out and well made. I only wish it had maybe one more in between output level maybe (4000/2000/500/100). I really like the battery carrier dual usb output ports and outside access to ports and can see charge level at a glance.
I do love what am seeing
the specs of the SD75 search light is amazing, I agree with BlackDragon; I do drool over this.
especially for the power bank feature.
its Cree XHP70 LED and 4000 lumen is real power I tell you
The rechargeable function that allows you to charge the search light in your car is a great feature for me because am always on the move, can’t wait to get my hands on them.
Wow, who’s the shill?
seriously Lumintop???
-> i do NOT mark as Spam so Sb can look how that user is
maybe he already has an account here?
You have 3 guesses :smiley:
Yeah too obvious…
Probably the most obvious shilling I have ever seen.
3 posts in a row
each user joined today
each user has only 1 post
each username is very similar in format
each post has no substance
Looks legit. ;)
EDIT: Screenshot taken for posterity.
Those “3” members had a thread of the same light closed for shilling reasons in CPF.
