dampfakkus has a big advantage compared to me, they do not test at low currents and only test one cell! This means they can do their test in one or two day(s) and not one week as I need.
Can’t thank you enough for your thorough testing. That’s why I would never ask for a change in testing procedure - but I do second TomE’s motion for a tiny little shift in the queue.
I was not talking about dampfakkus.de, but the German flashlight forum. Just google battery name + “test” and you’ll find it.
Edit: I don’t see any rule forbidding links to other forums so here we are:
Samsung INR18650-35E
Panasonic/Sanyo NCR18650GA
Samsung INR18650-30Q
That is right here at BLF we aren’t scared of information from other forums
And here are the same links but auto translated to English
And i have to chime in on the request for HKJ to put these new cell at the top of the queue. The real original cells from Samsung, LG & Sanyo/Panasonic needs to be tested before the rewraps if they are available.
Here is another list of recent battery tests. I believe most of the tests are at higher currents.
Ok, got it. But following the links I don’t see graphs or charts, TLF seems to suppress pictures, so it’s not that useful.
Normally it doesn’t. Pictures appear even when I’m logged out. Must be some other problem.
Edit: apparently it actually does if you’re not registered (tried in incognito mode). Not nice. Sorry. You could of course register to TLF, it’s free and doesn’t hurt
Please test the AOSIBO IMR18650 60A 2600mAh cell, they claim incredible performance
I hope it is true, we can always use a stronger 18650 cell
They are curiously heavy for a 18650 at 50g, that is even heavier than the 3600mha Panasonic at 48,5g & most 2500-2600mha is around 44-45g. Maybe they really have found some new special component…….
These look interesting also
The same, but different wrapper?
http://www.szaosibo.com/product_view.asp?id=132
http://www.szaosibo.com/product_view.asp?id=136
30A cont, 60A “pulse”
I don’t think it is the same cell, to much is different.
Old 30A/60A cell
46g
18mm
New 60A cell
50g
18.3mm
Plus the + pole looks very different.
But who knows maybe they just have an extra layer of rewraps, that could account for the extra width & weight.
Please test the Vapex AA 2500mAh low self-discharge Rechargeable batteries
On order
I do only have a few NiMH in queue, but I do not know when I will test them (The test station is used for chargers at the moment).
Efest IMR 3000mAh.
I think… That all the 3Ah rated IMR batteries we are gonna see from now on should behave very similar to the 30Q
anyway…i do not know if HKJ has the necessary stuff to test 200/400A peak currents but it is now few months I’m intrigued by this
Hi!
If possible, could you review one of these: http://www.banggood.com/9V-800mah-USB-Lithium-Rechargeable-Battery-p-986563.html ?
I think it’s an interesting concept and 800mAh wouldn’t be too shabby for a 9v battery.
According to the reviews on the item @ banggood, you get about 300mha to 400mha depending on how low volt your 9v equipment works at. Not bad but it is not 800mha.
I ordered that battery a couple of days ago. I forget to turn off my dmm sometimes, draining batteries in vain. so I hope this battery will work in my dmm.
I’m still curious about red trustfire imr-batteries also.
Just seen you already have tested the 10180 battery for DQG SPY/HOBI
I’m curious because with my charger @50mA charging current , but also with the specific DQG charger for micro usb, i never pass the capacity is ridiculously low… And I mean ridiculously
Tested the blue and the white version… Both are pathetic in the same way.
I am thinking about added 9V batteries to my testing.
I have tested them, they are in the "ready to publish" queue, but I do not know when I will publish them.
