Which C12 XPL-HI? Link?
here I believe ;
http://kaidomain.com/product/details.S024327
Nice light, still has good amount of spill.
Pulls just over 3 amps on good cell.
Thanks. C8 vs C12, which one should I get? Any opinions?
I think the C12 is uglier but has better heat dissipation .
I tried both the SMO and OP reflectors in the C8 and the beam pattern was cleaner on the OP as would be expected. The C12 has a different driver to the C8 but based on bikenber73’s comments it appears to be a 3.04A driver
I found the heat dissipation of the C8 quite good. I do agree the C12 is better on that point due to the larger fins near the head
Based on this review, I bought a KD C8. It works, not as bright as I imagined but works. However I had some mode switching issue.
For the flashlights that I got, their mode switching essentially works two ways. Either on-off-on will switch the mode. For some flashlights it needs to have two quick succession of on-offs to switch the mode. This C8 I received doesn’t work either way. It would stick on one mode and not switch in most cases. Sometimes, it will switch to the other mode then stuck there. This makes this C8 not convenient to use. Does anybody know what’s happening and how to fix that?
I contacted KD customer service but don’t know when they will get back to me because right now, it is Chinese National Day Holiday time.
Hi twinclouds. Can you provide a picture of the driver in your torch. Just unscrew the tube from the head to reveal the back of the driver. Otherwise if you do that and compare against the photos I includede to determin if the driver is a KD V2 or not. Also what brand and model of battery did you use in the torch?
The mode switching you describe isn’t consistent with what I found. The mode swicthing should be full press to turn on, then small taps/half presses to cycle through the modes. The driver memorises the last mode.
Thank you for your quick reply. I tried half push as well but they are still behave similarly. Sometimes it switches sometimes it don’t.
I use Panasonic (2000mah) taking from an old laptop and Trustfire 3000mah from DX. Both behave the same.
The photo of the driver is attached. Not sure if it is clear enough or not. (It didn’t show up so I provided the link.)
Thanks again.
Hi twinclouds, did you also try to do the half-press very quickly? From my experience some drivers require very quick tap on the switch in order to change mode, but they are mostly buck driver though.
I cant open and view the image
Thanks for your suggestion.
It sometimes works but not reliably.
The driver in your picture is clearly the KD V2. The solder pads are as per mine, so you have a 3 mode (Low - Medium and high)
It maybe the switch, driver or batteries used.
Ideally you work thorugh the issues to find out the cause. The switch can be checked via a test of the torch without the tailcap fitted. Use a heavy guage wire to short the -ve end of the battery and the torch tube end (non anodised end). If you can do this you can prove if the switch is faulty or not. Tap one end of the wire to mimic a quick tap on the switch to try and change modes. If the behaviour of the flashlight is the same as with the tail switch fitted you can cross of the switch being an issue.
Next I’d verify if the batteries are the cause. One of your batteries is a laptop pull and the other a Trustfire 3000mAH. How confident are you that both are good batteries for 3A constant current? I assume the Trustfire is protected. The protection may kick in for the high mode.
On high does your torch head feel very warm after 5 minutes?
I would also recommend to try some different batteries in the light as well. The batteries you mentioned are garbage and may not be holding proper voltage. I mention this because you stated it wasn’t as bright as you thought. The light may not even be using the highest mode due to voltage sag. Get yourself some current newer batteries and try one of them first. Also make sure the tailcap is tight, and the ring inside the tailcap holding the switch in is tight.
Candy from KD told me I should half press the quick release twice. It works much better but still not very reliable. Sometimes it changes mode not according to the sequence that supposed to be.
As for testing the flashlight and battery, I borrowed a new C8 from a friend and tried both on my home made IS. The current draw are the same about 2.4A. From the reading of my IS, KD only provide about 80 percent reading from the attached luxmeter of that from the Convoy C8. My IS is not calibrated but it is very good for relative comparison. Both uses the same battery and draw the same amount of current, so I cannot blame the low light output on battery. I am going to receive some LG HE4’s and will test more.
I think the reason why Rolz get higher lux reading is partly because the KD c8 has a much tighter hot light spot then C8. Of course it also possible I have a not so good driver. I will test the lux reading when get chance.
As for switching mode, the 4x7135 that I bought from KD works much more normal. It change mode after a short off and not after a long off. Both supposed to be KD V2 drivers.
I am really disappointing.
You did the tailcap test? Did you clean all the threads, where any parts screw together? Just wipe with tissue paper, see if you get black gunk off the threads. Aluminum does that over time, you need to do it sometimes.
Did you try adding a bit of conductive “bulb lubricant” or Nyogel or something on the threads? That often helps.
Add a dab of it on the ends of the springs as well.
Look hard at the places the spring(s) are soldered down — is it gray and cracked looking solder? Cold solder joints make intermittent contact sometimes.
All this and everything others suggested above are just routine for “budget” flashlights. Remember some are bargains, some are cheap, and most can be improved on by a litttle cleanup and maybe bit of work.
Don’t expect these things to be consistent as received. Every one is likely a bit different, and the sellers very rarely know what they’re selling.
This kind of intermittent behavior is really familiar.
I tried half push and release method. It works better but still not always consistent. I will try your suggests what I can.
I agree about your comments on cheap flash lights. If it is from ebay for about $6 - $7, I won’t complain. However, this flashlight has KD’s logo and sold by KD. They should know their own product better. Moreover, it is not that cheap. At least it cost more than my friend’s Convoy ($22 vs $18). I would expect a better quality one.
I received LG HE4 2500 mah batteries yesterday. I did some tests this morning. The current draws are about 3000ma for the KD C8 and about 2760ma from Convoy C8. When I tested the 1 meter hot spot direct Lux measurement as Rolz did, the results match his. Namely, the KD provide about 35000 lux and the Convoy gave me about 20000 lux. There are slightly difference between mine and his probably because product variation and/or accuracy of my meter (it is a very cheap one). However, when I using my IS to measure their output lumens, the reading are basically the same, at 20000 lux from the IS port. I would estimate the flashlight lumens are between 700 to 800. I thought KD C8 should provide more lumens since it has a better LED and draw more current, but it doesn’t. Of course, it could be because my IS is not ideal and does not handled both C8s equally well as they have different beam patterns as discussed below.
The reason why KD C8 gives much higher direct maximum Lux reading than Convoy C8 while their Lumens may not differ that much is because it has a much tighter hot spot. It should provide much larger throw distance.
As I said before, I really don’t like its behavior in mode switching. Even when it works, i.e., by quick double half push, it is not very reliable. Occasionally, it would skip one mode or not switch at all.
In conclusion, I would rank Convoy C8 (much) higher than KD C8 overall. In my opinion, it is only worth buying if you want a long throw distance as its tight hot spot can produce.
I know there is some comment to say it is difficult to change the flashlight mode. We had made an video to show how to change the flashlight mode on youtube.
The flashlight will turn on at Lo mode. Press twice to enable the mode change function. Then you can continue to press once in 3 seconds to change to next mode. If stay at any mode last above 3 seconds, then you need to press twice to active the mode change function again.
For any question, please feel free to contact us sales@kaidomain.com or me.
We would continue to improve our product. Thanks for you guys advice.
