EAGLE EYE X6 XPL HI V21A 1200lunens LED flashlight Free shipping $22.13
I seem to be experiencing déjà vu. :bigsmile:
True 3.5A this time? $21.59 with free shipping seem to be a good deal.
Explosion-flashing
wait - what? :wink:
any info about the driver?
At 3.5A those will be ledlumens, not OTF
How hard would it be to put a quad under the hood of one of these? :smiley: I saw DB Custom’s quad-XP-L and thought, “I want one!”
I’m getting a BLF A6 and a BLF D80, the appeal to me is having another BLF-marked light. :slight_smile:
Do not label it “BLF” if you are not using a Copper MCPCB with direct thermal path. Did any BLF member from the X6 groupbuy ok this? You can call it a “special edition” but I personally do not want to see “BLF special edition” added to any inferior version (without an ok from the groupbuy organizers).
The BLF special edition used a Copper MCPCB with direct thermal path.
Soon when we see someone with a “BLF special edition” we will have to ask: Is that a real one or the “other” version?
And before someone brings it up, yes, I know we can’t stop some junkfire brand from using any name they want but it is different when it’s a company we have worked with.
OK, thanks for your advice. I will correct it
so its a faked “quality approved by BLF“ … :expressionless:
How much is xpl hi by the way compared to xml2?
Because it only sold in BLF, so use the BLF, is my thoughtless,sorry
it is no “blf special edition“ - so its a fake (as it is sold now)
we all would love a thread from EE to ask our favours
then they may offer how far they can go
then, maybe they sell a lot
Easy guys. EE is trying. If there is no copper and copper is wanted then all that is needed is to tell them that DTP copper is required. I am sure that EE will try and cooperate. All he has done is leave out Banggood and come here directly. There is room for everybody to make flashlights for us the way we want them to be made
Added edit:
If "BLF" was not on the tube and light was named "Special Edition" then it could also be advertised on the "other" forum but they too will only want with DTP copper for the emitter. The only other issue is Aliexpress. Many will buy from Aliexpress because they cannot use PayPal. If a vendor is chosen (hopefully Banggood because they do help sales) then there should be only one vendor to avoid counterfeit "EE Special Edition" lights like we saw in the past.
Eagle Eye logo is more then enough, you don't have to rely BLF logo to sell this light. Specs speak louder than words.
This circuit has joined temperature protection,also adopted the high thermal conductive substrate,I’ve tested a lot of samples,no problem
So that is DTP but aluminum instead of copper...correct? (Just so others understand)
… a sample to a valued member will increase sales :wink:
I assume not, but there are boards out there that are not DTP but do perform better than others. I tested a non-DTP board (the base was copper, but in my opinion that was not crucial for the performance) in a comparison test of six ledboards, that performed surprisingly well, at 3.5A the light output was only 2% less than the DTP-boards, only over 5A it really began to perform less than the DTP-boards. link
For example, if the traces on the ledboard are of higher thickness copper and close to the led they widen into a 'poor' over the board surface (this one could be that way), the heat can go sideways and cross the dielectric layer over a large surface, thus helping the shedding of the heat in a different way than a DTP does.
In practice, some of the BLF-dogma's appear to be more nuanced than we think.
I’d only be willing to buy one if I could pay with PayPal.
And, it really has to have the DTP Copper MCPCB.
The XP-L HI is what I am wanting for this light!
Thanks,
-Chuck
If you are not rest assured on aluminum substrate,I can use copper substrate,welcome to discuss
The role of the two screws is to stop running,if lock the substrate,it will be an affect on center positioning,that it is not reasonable.
