I’d only be willing to buy one if I could pay with PayPal.
And, it really has to have the DTP Copper MCPCB.
The XP-L HI is what I am wanting for this light!
Thanks,
-Chuck
Thanks,
-Chuck
If you are not rest assured on aluminum substrate,I can use copper substrate,welcome to discuss
The role of the two screws is to stop running,if lock the substrate,it will be an affect on center positioning,that it is not reasonable.
EE has some fairly good deals on their site. I nicely built C8 for 13.99. I would like to see some more lights with XPL-HI in them. Only because I have many of these already!
Thanks Again EE
Aluminum substrate is fine. What people are asking for is Direct Thermal Path. The center pad on the LED is the thermal pad. The corresponding thermal pad on the MCPCB needs to be able to conduct heat away effectively from the LED. A Direct Thermal Path MCPCB has no dialectric layer under the thermal pad. It has direct contact from the aluminum or copper substrate to the LED thermal pad. The LED+ and LED- pads have dialectric under them to insulate them electrically from the metal substrate. It is only the thermal pad which is better to not be insulated.
keith, I haven’t done this, but from reading about others doing so, it appears that it’s quite easy to do, if you’ve got a steady hand and decent soldering skills. You will need a spacer, though, since the quad optic is shorter in length than the original reflector. Nitro was selling copper spacers for a while, but I’m not sure what the current status is. You can ask DB Custom in a PM. He might be able to tell you what is currently available.
Aluminum MCPCB can be ok if it’s DTP. The important part is the Direct Thermal Path (DTP). The mcpcb in your picture does not appear to be DTP.
Here is a picture that might help better then words.
Might be able to make the spacer myself, soon. Gotta level the lathe and start playing with SOMETHING, a simple spacer should be a nice project.
SinkPAD makes a DTP Al mcpcb, so this Could have DTP, which may not be a bad thing. The instant access to strobe might could be changed to instant Turbo access? Sounds pretty cool to me.
Glad to see EE here making the effort.
BUT, as has been said… BLF Special Edition means quite a few members of BLF saw to it that it was indeed special, it’s not just a name.
But the mcpcb in EE’s picture appears to be non-DTP. If you enlarge the picture you can see the outline of three copper traces, positive, negative and a center copper pour which is found on non-DTP mcpcbs to spread the heat from the center thermal pad out horizontally, giving it more area to help get through the dielectric layer.
1. How fast it has to be the double tap in order to trigger strobe?
2. Will it be available in neutral tint?
3. Would it be possible, if many prospect buyers ask so, to have it withOUT strobe?
Thank you for taking the time to consider our requests.
its always you with the shipping problems…
Hi Shenzhen Jin Lang Electronic Technology, constant current circuit means there is no PWM at all? And is there warm white or neutral white tint option?
Features:
-constant current circuit
Paypal payment would be usefull.
In the last picture those screws look like they are not holding mcpcb or anything am I seeing wrong?
Looks that way to me too.
-Chuck
Screws seem to help centering mcpcb.
Bigger head screws might help.
He also has problems at the drive thru.
I wonder if that Eagle Eye C8 has a pill, if it does they should make a host available.
