KronoReview: Eagle Eye X6R
254 posts / 0 new
will34
will34's picture
Last seen: 18 hours 7 min ago
EE is just one of the many brands that work with ODM companies, they usually release a couple products and then re-appear as a different brand. This is a very common way for chinese companies to evade taxes/legal matters.
Tom E
Tom E's picture
Last seen: 23 hours 42 min ago
Yes, seems like that's what's happening. Some brands do not want to be found, others, like Convoy, have a strong long term presence. But Simon w/Convoy, really tries to add value (drivers, LED options, etc.) and offer great support. His lights, or should say hosts, can be found around under different brands. Roche/Rocher for example, seems to overlap, and in the case of the F6, he took it over. Really surprised we haven't found the X6 or X6R under a different brand, at least I dunno of any.
pilotdog68
pilotdog68's picture
Any idea if the stock driver would work with an Attiny13 with familiar firmware? An mcu swap would be even easier than a driver swap
Intracloud
Last seen: 11 months 4 days ago
It flashes two times once a minute, but does NOT shut off. I dont think it is of any point to go lower. The battery goes to recycling.
Tom E
Tom E's picture
Stock MCU is a PIC - different pin outs, you can see it in the pics I posted in post #70. Could try air wiring up an Atmel, but I dunno enough about that circuit. It's been done before though by BLFers with other drivers. This light deserves a FET based driver though.
pilotdog68
Tom, are you using an e-switch firmware and just leaving the tail switch on all the time? I want to use Star dual-switch on a driver swap, but I’m assuming that would mean the light would have to be “on” while charging.
Tom E
Tom E's picture
The tailswitch in this case acts as a lockout. When I carry the light in a bag/pocket, I turn it off on the tailswitch to avoid accidental e-switch activiation. However, as soon as I get a chance, I'll be updating the firmware/MCU to a ATtiny25 with my new firmware that supports an e-switch and power switch functionality. You can fully operate it on the tail switch with NOINIT, memory, etc., but also the e-switch is fully working like my standard e-switch firmware - Best of Both. I think the LD-1/LD-2 drivers work this way as well.
 This X6R is perfect for this ATtiny25 upgrade (see http://budgetlightforum.com/node/41067). I needed more code space to get the combined e-switch and Star_NOINIT working - think it took 1070 bytes currently, where a 13A is limited to 1024 bytes. Also want to get the 25's temp sensor iimplemented, but didn't start on that yet. The ATtiny25's I have are a simple drop-in replacement for a 13A, but the 45's and 85's are a wider footprint, and require either to clip the pins or bend them to fit on a typical 13A driver board. Wight's 22mm FET+1 driver though can mount a 45 or 85 direct without bending pins.
pilotdog68
but even with the larger Attiny, you would still need the “soft” ‘off’, otherwise the light will be shining during charging, right?
I wanted to give one of these to my grandfather. I wanted it to be very simple, without any long presses or double clicks: 2modes, on/off with the tail switch, low/high with the side switch, that’s it. But since the tail switch has to be ‘on’ to complete the circuit, the light would have to be shining during charging. that’s not optimal.
Tom E
Tom E's picture
Hhmm. I see what you mean, but if I were you, I would add an e-switch OFF mode: OFF-low-hi, all with single clicks only - no long presses or dbl-clicks needed, as you would like, and solves the charging problem, and more flexible but still easy UI (you can also turn the light OFF on the side switch).
You could do an e-switch piggyback driver to get this functionality, or try to experiment with an MCU replacement - might not be easy or simple - different components than our standard ones (3 legged ones), so might need some serious reverse engineering - probably beyond my scope.
Cheap route would be a 105C or QLite driver with e-switch firmware programmed for the modes - rip off the stock piggyback, replace with this one.
I have a whole different plan with a more robust UI.
pilotdog68
I might do press and hold 2-3sec for the soft off. I don’t want cycling through off to be a nuisance, and press and hold should be much easier than double click. Maybe there’s a way to have the MCU detect when the charger is connected? that’d probably take a lot more work with the code though.
I’ve decided not to mess with an MCU swap, i’ll just drop in a Nanjg
Tom E
Tom E's picture
The way this light is designed is that the charging circuit is completely separate from the driver - no ability to check/monitor. That's good from the perspective of modding it with a driver replacement and keeping the charge circuit in tact. Only thing I'm not sure of is if the battery is dis-connected or not present, is the charger providing power to the driver/LED. That could be a bad thing if it did for a DD FET driver, not sure.
But, if you are charging and the MCU is alive and sleeping, then theoretically you could monitor the voltage via the LVP resistors and blink charge status or something, independent of the color LED indicators displayed at the switch. Hhmm - I'd have to explore this a little more.
Ohhh - I'm still think'n easier for a non-techy to click thru OFF-lo-hi, then to toggle lo-hi on one switch, then use another switch for ON/OFF. It's different if the switches are right there next to each other, but switching hand/hold positions to turn the light OFF for example, I found to be a pain, but that's me Smile, others may find it easier.
Update: Just realized I got the light with me @work, and sure enough it will work using my FET+1 driver mod with no battery when the USB is connected! That's pretty cool. Looks like 4th and 5th mode (2 highest) are about the same output - the wall adapter I'm using is rated for 1A max output, and that's what it looks like I'm getting.
pyro1son
pyro1son's picture
Last seen: 10 months 1 week ago
Any chance we’re going to get a board designed for this using the 3 vias? I’m hoping to design one, but having no idea about Eagle PCB it may be a while before I get to that stage.
Pastebin                                      &nbs
Tom E
Tom E's picture
For myself, not really interested - doesn't save much time, not much added value. I'd rather have my choice of drivers. If it was involved, tight on space, and required a driver switch mount for example, than maybe yes, like what was done for the Roche/Convoy F6 - that came out really, really nice.
Two of my favorite lights right now are this X6R and the F6: quality, functionality and modifi-ability ... Well you know what I mean Smile.
Edit: Oh boy: http://budgetlightforum.com/node/41392, might be a good time to get in a discount order with BG for another X6R... Adega (Hengyu Electronics Co) may be the real manufacturer, but I only see BamgGood and AliExpress selling the X6R at a decent price, and BG's discount is definitely the best.
Discount code of 'bbbc2c' still working - $24 for either tint, just ordering another.
pyro1son
pyro1son's picture
Oh you bad man. I’ve just ordered one now!
Pastebin                                      &nbs
pilotdog68
Ok Tom, what if we airwired a line from the raw 5v input to the MCU pin that measures for LVP, then set the firmware so that it turns the led off (sleep) when it senses the higher voltage. That way the light turns off when the charger is connected, and turns back on when you unplug? I feel that code shouldn’t take much room because we already have all the parts for measuring voltage.
MaleNurse
MaleNurse wrote:
My copy also flashed and dimmed down as soon as it hit 2.8 volts. I let it keep running for a while (at low). I aborted the test when the battery voltage read 2,68 volts. (2.71v after the battery had rested for 15 minutes). Does this light not shut off at all…?
I asked and have had it confirmed that the stock X6R does indeed not have a shut-off voltage. It will slowly draw current all the way until the battery is drained. Ok for emergency use, but not quite so ok in terms of safety.
Guess batteries with low voltage protection would be recommended for this light.
Tom E
Tom E's picture
I don't know enough about electronics/circuit design, but I think you might need the voltage to come in to 2 resistors, like we do now with the battery monitoring. See: http://www.epemag.com/lib/free_projects/lab_equipment/0200%20-%20Voltage%20Monitor.pdf, as a reference project. I really dunno though.
pilotdog68
Btw, our new Eagle Eye friend has a great deal on the X6R, even cheaper on the mobile app
http://www.aliexpress.com/item/Eagle-Eyes-X6R-CREE-XM-L2-U2-1000LM-USB-Rechargeable-LED-Flashlight-self-defense-camping-light/32301365158.html
Tom E
Tom E's picture
Wow, that is a great deal on the X6R... They have pretty good deals on the other Eagle Eye's as well, including a X6 with an XP-L HI, A6 hosts, etc. Not many pieces sold of anything though - pretty new store, Mr. Eagle eye... Smile
Here is a better ref: https://learn.sparkfun.com/tutorials/voltage-dividers. You can plug in our values for R1 and R2 and see what you get. I believe if you have a 5V source coming in, you need to scale it down to match against the 1.1v reference source.
For our use for LVP now, we want to measure 3V against a 1.1v ref source, so, we use 19000 ohm R1, and 4700 ohm R2, so resulting voltage is 0.59v, which is just a little over 1/2 of 1.1v, correlating to an A-D value of about 130, but have to subtract out voltage for the what the diode takes, so we use a value of 120-125 or so.
To detect the 5V source's presence, maybe a direct wire would work, and maybe it will read 0 or 255 if present, dunno.
pilotdog68
If it read 255, wouldn’t that be perfect? It doesn’t need a precise reading, just needs to be able to tell charger vs no charger.
If I test it, 5v direct to that pin isn’t gonna fry it, is it?
pyro1son
pyro1son's picture
Could we not really assign star 3 to any input to that pin would turn off the output?
Pastebin                                      &nbs
pilotdog68
Have our firmwares used all the pins or do we still have one left Empty?
Tom E
Tom E's picture
Might be one pin free. Dunno bout the 5V going direct in, true, might be a problem, but 5V is within the normal range for these MCU's. I'm kinda learning as we go Smile.
pilotdog68
Blf-a6 is one of the most advanced firmwares, and it indeed has a a pin assigned to “star 3” as our fellow member already pointed out. Air wire straight from 5v input with a limiting resistor inline, then set the FW to PWM=0 whenever signal is detected on Star 3. Any reason why that won’t work?
pyro1son
pyro1son's picture
My thoughts exactly
Pastebin                                      &nbs
pilotdog68
I just ordered my X6R yesterday, but I’ll try our theory when it gets here.
pyro1son
pyro1son's picture
I ordered one last week keep up upto date I want to try this out as well. Thinking about using ATTiny45 for this build, thoughts?
Pastebin                                      &nbs
marcl
Last seen: 1 year 3 weeks ago
Eagleeye=Rayus light.
Eagles may soar, but weasels don't get sucked into jet engines!
pilotdog68
Go for it!
My build is for my grandfather and will be a very, very simple UI. So i’ll be using the 13.
Tom E
Tom E's picture
These ATTiny's have 8 pins: RESET, GND, VCC, then the remaining 5 pins are all I/O. Of the 5 pins, 2 can be used for PWM's.
So of the 5:
- PWM out (to FET or 7135's)
- secondary PWM out (if using a FET+1 driver) or available
- LVP in via the voltage divider circuit
- e-switch in
- available (or possible OTC with an e-switch, maybe?)
So for an X6R with e-switch, you could have 2 pins, 1 pin, or none available -- all depending, but none is highly unlikely, only if you use a FET+1 with OTC.
The RESET pin can be used for I/O but once you do that, you can't re-program with our usual $5 USB dongle - needs a special setup to clear it.
