The bubbly base as well as the circle hole rather than square hole suggest that they are genuine. Now, I don’t really know what I’m talking about. This is just repeating what I read earlier in this thread.
Do the bond-wires pads look round or square? for some reason the die size looks smaller than a genuine Cree XM-L, its difficult to say from those photos even though the pad coating looks stippled like a real Cree XM-L. You may need to try to compare them to any higher quality light you have with a genuine Cree XM-L.
I just made a new picture of a XM-L colour (neutral white die) for comparison (this one is bought from IOS a year ago, so it sure is real), and your XML colour leds looks extremely like the real deal except for the bits sticking to the side on the silver background that are not present in my led. Is this just a Cree variation or is that a indication of fake? At least it looks like your leds looks more like Cree than like Latticebright:
Cree:
The orientation of the bond wires looks different in the Latticebright and the substrate is visibly whiter:
I found some more counterfeit Cree emitters in my lights:
First, everyone’s favorite “Super Light”:
Fake XP-E emitter: Note the off-center die surface. The die is square, the offset is just due to the angle. Sorry about the dust…
I was one of the few to receive the $4 “XM-L” dive light when one of the retailers accidentally (?) listed the item at the wrong price earlier this spring. The light was a poor performer with very CW emitters, but the low output was attributed to the low drive current. One of these lights suffered a catastrophic leakage failure ( :zipper_mouth_face: ) and was set aside for spare parts. I checked the emitters last night, and found that they were counterfeit XM-Ls.
Pictured here, the left hand emitter is the counterfeit. Notice the smaller die size, sharp, crisp edges, well defined lines, and lighter green smooth PCB:
Here is a closeup of each emitter; fake is on top, genuine Cree on the bottom. Here you can see the bond wires and junctions more clearly:
Goog comparison photos Keltex. it seems the biggest noticible differences are the smaller die, smoother dome/coating, and coloration of the fakes from the real Cree XM-L.
Bummer. Just checked my Super Light and yep, it’s fake.
Lousy photo but you can clearly see the square dot in the top left hand corner, which should be round.
The galling part is the huge ‘CREE’ engraving on the side of the light. |(
sadly but true, these sellers and manufacturers have no honor or care for slapping brand names, exaggerated false claims, and even slapping “CREE” on stars & lights with the cheap fake emitters that are dimmer, far less efficient, suck more amps, and give a zombie purple tint that are going backwards to the days of the horrible shower-head 5mm led lights of 10 years ago with the efficiency of an old incan light.
its a direction these fraudulent manufacturers & sellers are going, and will make it so much more difficult for us to buy a good budget light with a real brand name emitter and not something that is pure crap like these new latticebright fakes.
I find it strange that the grid lines on these are so crisp and clean. I wonder if they are 100% cosmetic to make the LB look like the Cree?
It wouldn’t be nearly as bad if they weren’t modeled/marketed as Cree: they aren’t great emitters, but they are still acceptable as a budget alternative to Cree. If not for the illicit/unethical business practices, I wouldn’t mind keeping these for some budget builds.
