Long ago I ordered these boards before but they never arrived. A few weeks ago I ordered them again few days ago they arrived.
First try on a Supfire S1, I first took out the stock switch which is a different design, I had to add a ring in between the new switch and silicon cover, had to do that anyway because it was to be white plastic for the red led-light to get through, the tailcap was replaced by a transparant one, the pillar was shortened. The brass switch retaining ring is very thick in the Supfire S1, so I had to ream the inside quite a bit to get it clear from the center pad of the pd68 switch board. The new switch was this one, started with testing some resistor values, ended up with 5.6KOhm on the switch board, 680 Ohm bleeder on the driver. The new design board allowed two leds in parallel :-)
The careful observer will see that in this picture the leds are the wrong way around, they exploded during testing. Actually during testing I blew six of these tiny leds. That will not happen again because now I now know how to do it right.
For the bleeder resistor I drilled a shallow hole in between the batt+ pad and ground ring, so that the resistor was plane with the surface after soldering.
Neat result :-) . I am going to mod this light further (the head is still stock apart from the bleeder R), but this is a nice start. 4V, 6kOhm is 0.65mA, so a 550mA Efest should last about 34 days. I charge it more often than that so that's ok!
Thanks pd68 for the ideas and board, this is a nice little upgrade and a good excuse to fiddle around without having to start on the big hobby-projects that I dread starting, like the DIY contest entry. :sad:
Perhaps as a small improvement, the solder pads for the switch may better not go all the way to the edge but stop a tiny bit from the edge, then there's no chance for them to short against the side of the tail section
I had thought about that the last time I revised one. Ultimately I had never had a problem with them shorting so I left them all the way to the edge. Shouldn’t be too hard to change that though.
Also, the center pad I left the same size as on the 20mm board so it would be easy to fit a normal sized spring. Do you think I should make it smaller? Or was it juat problematic because of the larger retaining ring?
I’m going to order some of these fairly soon, planning to get a 18350 tube light with Nichia 219 with a good moon light mode and this tail light so its easily found.
Djozz, how were the pads size for soldering? They are smaller than on the larger board because I wanted to leave clearance in case the board had to be trimmed. Do you think that was a smart move, or would you have preferred bigger pads?
The pads for the smd thingies were fine for me, I do not think larger pads would make it that much easier. I do have a very fine pointy tip on my solder iron though..
And on second thoughts I think it does help if the center pad for the spring is a bit smaller, it is 11mm now, 10 or even 9mm would be better, most springs are less than 10mm.
Nice improvements! I have two of the last version left, when they are used I will order the new version :-)
Off topic: my girlfriend being away this evening, I finished the Supfire S1 mod:
*sloppy dedomed but fully working Nichia 219C 83CRI on Noctigon
*NanjgAK-47-A1 driver modded with FET (so direct drive) 5%-25%-100% with memory
*reshaped the led retaining ring for optimal focus and to stop blocking light
*tail spring bypassed, stock switch assembly replaced by small Omten on pd68's 17mm board (had to sand it back to 16.5mm to make it fit)
*and of course pd68's colour led tail mod :-)
It is doing 800lm at startup, 600lm after 30seconds. Light is high quality 4000K-ish. Throw is 9.3 kcd which is pretty good for a 18mm OP reflector. On high I have to step down after 30 seconds because it gets too hot to hold.
It was my second and last attempt at hot dedoming the 219C: after the dome broke off halfway I started breaking away and slicing with the scalpel until a thin but messy layer was leftover on the die, and then I cut away all the silicone on the sides, including the white stuff, leaving the gold-coloured underground exposed. It works fine though
I just ordered some blue smd 805 leds and now I was thinking of using one blue and one red led. The blue one would switch off under 3.2V, with the red one still going, sort of lowish voltage indication, as discussed before. I can easily hack that onto the existing board (will do that), but it can also be build in. This would need a extra resistor pad on the circuit board so that the two leds can have their own resistor. The long middle trace could be left there to keep the possibilty of the parallel leds, and just needs cutting if two separate led circuits are used.
How’s this Djozz?
Will work with the led’s in parallel by placing a single resistor on either of the “R” pads, or cut the trace down the middle and the two sides will function as separate circuits. I did the same with the 20mm, and also added the same improvements from the earlier 17mm board.
With this one you can even make some visible reverse polarity check, provided that the switch is off when inserting the battery: mounted one led in one direction, and a different colour in the other direction, if the battery is wrong it will show a different colour.
Hmm, actually the current setup has that already: battery wrong=leds do not light up.
Btw, would this trick with the bleeder resistor at the driver and larger resistor on the tail board provide enough power to use an e-switch on the tail without too much parasitic current?
