The pads for the smd thingies were fine for me, I do not think larger pads would make it that much easier. I do have a very fine pointy tip on my solder iron though..
And on second thoughts I think it does help if the center pad for the spring is a bit smaller, it is 11mm now, 10 or even 9mm would be better, most springs are less than 10mm.
Nice improvements! I have two of the last version left, when they are used I will order the new version :-)
Off topic: my girlfriend being away this evening, I finished the Supfire S1 mod:
*sloppy dedomed but fully working Nichia 219C 83CRI on Noctigon
*NanjgAK-47-A1 driver modded with FET (so direct drive) 5%-25%-100% with memory
*reshaped the led retaining ring for optimal focus and to stop blocking light
*tail spring bypassed, stock switch assembly replaced by small Omten on pd68's 17mm board (had to sand it back to 16.5mm to make it fit)
*and of course pd68's colour led tail mod :-)
It is doing 800lm at startup, 600lm after 30seconds. Light is high quality 4000K-ish. Throw is 9.3 kcd which is pretty good for a 18mm OP reflector. On high I have to step down after 30 seconds because it gets too hot to hold.
It was my second and last attempt at hot dedoming the 219C: after the dome broke off halfway I started breaking away and slicing with the scalpel until a thin but messy layer was leftover on the die, and then I cut away all the silicone on the sides, including the white stuff, leaving the gold-coloured underground exposed. It works fine though
I just ordered some blue smd 805 leds and now I was thinking of using one blue and one red led. The blue one would switch off under 3.2V, with the red one still going, sort of lowish voltage indication, as discussed before. I can easily hack that onto the existing board (will do that), but it can also be build in. This would need a extra resistor pad on the circuit board so that the two leds can have their own resistor. The long middle trace could be left there to keep the possibilty of the parallel leds, and just needs cutting if two separate led circuits are used.
How’s this Djozz?
Will work with the led’s in parallel by placing a single resistor on either of the “R” pads, or cut the trace down the middle and the two sides will function as separate circuits. I did the same with the 20mm, and also added the same improvements from the earlier 17mm board.
With this one you can even make some visible reverse polarity check, provided that the switch is off when inserting the battery: mounted one led in one direction, and a different colour in the other direction, if the battery is wrong it will show a different colour.
Hmm, actually the current setup has that already: battery wrong=leds do not light up.
Btw, would this trick with the bleeder resistor at the driver and larger resistor on the tail board provide enough power to use an e-switch on the tail without too much parasitic current?
You only have two paths from the tail to the front of the light, the tube and the battery itself. You can’t carry batt+, batt-, and the signal from an e-switch without running another wire. I have toyed with the idea of putting the whole driver and e-switch on the same PCB in the tail, but I think that would require some tiny 0603 parts to get it all to fit, and my Eagle skills aren’t anywhere close to that level yet.
I just wanted to order parts but it’s not clear for me what are the best parts.
Should I order 0603 LEDs or bigger ones? If I understand it correct the solder pads are big enough for 0805 but you used 0603. why?
I have found that: http://www.ebay.de/itm/121507128509
5colors 10 each white green blue red yellow
I will order some omten1217(or whatever FT ships now).
From cnqg some translucent caps which are linked in OP.
I have some 560ohm resistors in 1206 will these work or is smaller better?
I have 17mm rev2 on order but will also order the newest version with additional pads.
I used a 0603 LED the first time because it was what I had at the moment. It is designed for 0805 size. 0603 will work, but they are just harder to solder and easier to lose.
The Omten 1217 will work with the 20mm board, but it won’t fit on the 17mm. I usually use the Omten 1288.
You should be able to make a 1206 resistor work, the resistor pads are slightly larger than 0805 (but still not 1206 sized)
So I should order 0805 leds…that’s a valueable tip as I have to order things anyway.
I have one 1288 spare but cnqg is out of stock for some more so if anyone knows a good source I would be happy.
I will order the kohm set from fastech which is linked in the OP for the LED resistors which seem to be in this range, but the 560ohm is the bleeder resistor which is necessary I thaught…?
I got the 17mm rev2 boards today, all other parts are still on the way so I used a nichia 119, a 5.6kOhm resistor and made a spacer from some plasticsheet.
All together fitted in one of the “scrap” lights I had lying around with the standard gitd boot.
I didn’t need a bleeding resistor it worked with a standard nanjg(the 4*7135 variant). is this always the case? Is the bleeding resistor only for more brightness?
This is a very cool invention! It glows and is very easy to find in the dark.
On our common drivers the input capacitor basically does what the bleeder resistor would do. However, the lighted tail can cause problems for mode-memory on drivers that use an off-time capacitor. For your driver (which doesn’t use an OTC), all the bleeder would do is possibly make the tail a little brighter.
I’ve got a question on this regarding the resistors. Picked up the “value pack” from fasttech, and a good portion are not labeled in a way that I can read them.
For the bleeder resistor, assuming I need one, the closest resistor I could find is a 510k. What is stumping me is that I have some labeled 510k and some labeled 510r. What is the difference as it applies to this build?
