I would like to see ThorFire and all light makers hide their “burst” mode, the Fenix HL30 does that so that you don’t have to cycle through it all the time, if you want the Turbo mode, you have to hold the switch down for a split second more to get it.
In my short tests I didn’t notice PWM, so I checked with a camera just now. It indeed does use PWM.
Thanks for the rootbeer!
2. The light you are drooling over the most and why you want to buy it so bad (and a picture of it if possible)
- My dream light is the upcoming Okluma TinyDC in Ti. Not a budget light (retail is $450). It basically is a revamped Mac Tri EDC from a new, responsive builder. Classy, classic, and fits 17mm circuits so I can put in my favorite Dr. Jones’ driver.
To Enter:
Comment with one or more of the following:1 Your favorite light that you own and why it is your favorite (and a picture of it if possible)
2 The light you are drooling over the most and why you want to buy it so bad (and a picture of it if possible)
3 A feature or spec that you wish manufacturers like Thorfire would include or not include on their future products
1) Too hard of a question to answer because it changes way too often after doing a new mod or buying a new light.
2) I’m drooling over the Lumintop BLF-SD75. I want to buy it because I want a BLF edition flashlight with MOAR lumens.
3) A large and meaty headed multi-cell flashlight that has at least a 95mm reflector so it can a super thrower with a SMO reflector. Or it can be a XHP lumen monster when a OP or multi faceted reflector. It can be in a traditional or multi 2S flashlight package or in a lantern package with a carrying handle. I like the idea of a lantern package better because you could fit more batteries inside of it and get more run time and the folks with small hands can hold it with ease.
Also it should have beautiful square cut threads and anodized finish like the Convoy and ThorFire C8’s has.
1. Olight S20. Compact, good UI, magnetic tail. Fits for almost every my need.
My favorite is the Eagle Eye X6 for outdoor use.
For Indore, I prefer my Nitecore EZ AA R5.
They are also the only two decent torches I own.
My other converted Home Depot lights and old < 50 lumen ancient LED lights now live on my shelf.
Thank you for the generous giveaway. I'll go with my favorite light. At the moment it's my Convoy S2. I do a lot of late night running and this light goes with me everywhere. It will run over 4A, but I keep a higher capacity cell in it, so it does right around 3A. It gets warm, but still manageable.
It has an AR lens and a smooth reflector. I recently put in an XPL HI and it is perfect for this light. The flood is great and the throw is more than I would expect out of something so small.
Anyone who doesn't currently have one of Convoy's S-series lights should really consider adding one to their collection. Let me zoom out a bit for a better view of this fine light.
Thank you for that last picture showing you weren’t holding the flashlight in your butt :Sp
+1
I was dreading the last picture :bigsmile:
I don't know... Could still be butt.
Hi mate, can this be lego’d with any other 18650 tube-lights that you are able to check?
Would be interested with Convoys (S2/S2+/other), Eagle Eyes (X6,A6) and the new Manker BLF A6.
Please include me in your generous giveaway:
Tie between the DQG AAA SS as it’s always on my EDC keychain and able to bite between my teeth for light (weight) hands-free carry.
And D25C Ti (2014) for the small pocketability/included belt carry with clever, easy mode selections. And Nitecore MH20 for the long-runtime of 18650, side switch with nice UI, but still small enough. Not too keen on the tint, but made up for by the on-board USB charging.
The new BLF X6 2nd Edition group-buy by Kronological. I love my X6R but the mixed-metals of these new GBs should make them a beautiful purchase.
I do like the convenience of built-in USB charging. As long as it is a quality circuit. I don’t like compromising the build or aesthetics of a light with rubber caps though, so the ideal is a nicely concealed USB like XTAR did.
All the best,
Hirsh
Thanks for the review and giveaway!
A “feature” that’s been on my mind and even gave me an “argh!” moment just yesterday is for single 18650 torches to be anti-roll, even without a pocket clip.
Design-wise, symmetry has a certain aesthetic beauty, but why not go out of the box and make something awesome that isn’t round and susceptible to roll away from me.
A lot of folks like the Convoy series. I am one of them.
Swapping parts around is one of the big attractions. Two sizes of battery tubes. Two reflector types. Colors. Lots of joy for the bux.
Less than $10 from RMM for a host that is super-easy to mod. The very definition of “where frugal meets with flashlight.”
This may shock you, but I actually don’t own an S2, S2+, or any A6.
I did check with my BLF X6, and it definitely does not LEGO. Although the body tubes/tailcaps look identical, they have different threading.
However, it LEGO’s perfectly with my convoy S8:
Thanks for the giveaway.
1.) My favorite light right now is my Tank007 E09. Although I do own a number of (other) extremely bright flashlights, the Tank E09 is so tiny that it is my EDC, and thus always in my pocket and available for immediate use. A small lightweight light is also preferred for camping. I also own a couple Fenix E01’s, but they are only one mode, and do not accept a 10440 battery.
Favorite light is a Shadow TC500 head on a TC350 body.
Lots of throw in a small package.
How about the Acebeam K60 for a light I want.
My favorite light is a Yezl Y3. I like it because it has 1100 lumens and a great throw.
My four sevens mini ML. Runs regulated and has a good low. No picture because I seem to have lost it. Should have attached it to my keys.
