Jmpaul320 OTF Lumen Sphere Readings & throw measurements! | Candle Power Flashlight Forum! Seems the K60 driver is limited :_( , Vinh won’t boost it, because it won’t take it? Magnetic ring is a PITass, never again after my K40M. So the SD75 will be EASIER to take apart, with out damaging little magnetic thing’s and worse case if the SD75 can’t be boosted, the driver will be ripped out and a FETDD will be in? Then I’ll shave and polish the dome for a little more throw. I have a few XHP70’s that are pulling 10-11 amps, so will this one, so will this one! :bigsmile: I think that might just Smoke a stock K60? Which one has the bigger reflector again?
I cant wait to be able to afford one of these. First flashlight i have drooled over, and wanted at first sight. Looks very well thought out and well made. I only wish it had maybe one more in between output level maybe (4000/2000/500/100). I really like the battery carrier dual usb output ports and outside access to ports and can see charge level at a glance.
I do love what am seeing
the specs of the SD75 search light is amazing, I agree with BlackDragon; I do drool over this.
especially for the power bank feature.
its Cree XHP70 LED and 4000 lumen is real power I tell you
The rechargeable function that allows you to charge the search light in your car is a great feature for me because am always on the move, can’t wait to get my hands on them.
Obviously that someone help LUMINTOP to bump the thread but sadly he wasn’t not familiar with rules and did a bad way here. If necessary, I can delete this thread to avoid any bad influence. Pls advise
Well, if Lumintop has nothing to do with that shill, please hang on here, years ago l used to own a Lumintop light before and it was really good (unfortunately l can’t recall the model but it was a 1x18650 small thrower)
Edit: it was a T5 Hunter.
Just checked it out and surprisingly HKe still carries it: (where I bought it, btw)
Seeing the description of the evolution of the light I understand most of the changes, but why would you go from a smooth reflector to an orange peel reflector on a light designed for throw? That makes no sense to me!
