Less protruding switch would be nice, otherwise I’ll take it!
I like it as it is. What will be the engraving? Will it be ReyLight?
I would like a higher current switch (see post #23), but would also like to change the UI:
*I prefer low-med-high instead of the stock med-low-high (but there's as many opinions as people on this subject)
*The pwm on the stock Tool is terribly low, that should go up to at least 4kHz.
*And of course the low should be lower, as usual.
And if the led would be the Nichia 219C that would be fantastic (I prefer the 4000K 83CRI, but I'm happy with 5000K 83CRI as well)
I posted my interest on the other board, but will also post here as I am very interested in this.
I’m in. For me a moonlight mode is a must have.
Nice, I will be in for at least one, probably two. I prefer warm/neutral tints, Nichia is always welcome.
The rubber switch, It could be metallic?
I would be interested in one IF it looks exactly like this…
If it’s changed from this, no thank you.
I’d like to buy one of these, how do I go about it?
Rey will add you to the list. Once we get enough for the good price and his version is ready he will provide us with the info. ;)
1+
I like it exatcly as is,no changes!
Maybe I should clarify that… I really like the build of the body, just the way it is
If the emitter/driver/performance were to be tweaked that would be fine with me.
Did I miss an estimated cost on these? All the group buys lately have done damage to the budget for sure, so I have to add that end cost will largely be a determining factor. Sorry, but this time that’s the way it is.
Nichia, copper, clicky. Perfect! I’d take three or four depending on price.
Also like the shape as pictured. Only ‘fix’ I would prefer is to lower the bulging rear-switch and make it a tail-stander.
Perhaps a matching metal flat switch?…
I like the tool look. Tail standing would be nice as would l-m-h levels.
I like the wasp waist in a small form, makes them easier to grip.
I’m in.
Low,med,high would be best.
Forward clicky to seal the deal!
METAL SWITCH PLEASEEEE
I’m for one or two. I would prefer metal switch
I’d like one:) Metal/copper switch?
To have a metal button they would have to completely redesign the tail and switch itself. It would not be feasable for such a limited run without a huge increase in price. Normally I prefer a metal switch aesthetically but in this light I actually prefer the existing design for looks and function. I think Lumintop knocked it out of the park with this design. It is everything a flashlight should look like, IMO. ;)
