HKJ
(HKJ)
August 19, 2015, 6:09pm
50
It is about the same.
Look at the "Display U" column with current=0 and the "Display A" column when I test with different currents.
Voltage will not be very precise when current is flowing, it will be something between voltage at the input and the output.
The one with the lowest resistance will usual be the winner (That is a very important parameter on these meters).
tempo
(tempo)
August 20, 2015, 9:26am
51
4xAA emergency powerbank wiv flashright:
http://www.ebay.com/itm/121274503719 (cheapest, in all colors)
http://www.amazon.com/dp/B00I0RA3XE (same one, in black)
http://www.amazon.com/dp/B00HCBHZV2 (seems to be from the same factory)
zelee
(zelee)
August 31, 2015, 9:53am
52
HKJ please test this Power Bank
cajampa
(cajampa)
August 31, 2015, 11:20am
53
+1
That one looks like the most advanced i have seen yet.
I hope it is a good one, 8x Sanyo 3500GA should be about as good match as anything out there i think to this powerbank.
Hi HKJ. Just saw this on GB and would like to have your review if possible Even if the answer is a negative, I want to thank you once again for all the great work you do.
http://www.gearbest.com/cables-adapter/pp_77158.html
and this one too.
http://www.gearbest.com/car-gadgets/pp_203508.html
Glenn7
(Glenn7)
September 3, 2015, 12:53pm
55
HKJ
(HKJ)
September 3, 2015, 5:04pm
56
I usual do not do car adapters, but I have ordered this one and also the other one.
HKJ
(HKJ)
September 3, 2015, 5:05pm
57
Interesting, if this ever get made it could be interesting to test it.
hank
(hank)
September 7, 2015, 6:35pm
59
HKJ
(HKJ)
September 7, 2015, 7:05pm
60
I will accept Quick Charge suggestions now, I succeeded in making a box that can trigger it.
I have ordered this one, now but it will be some time before I get around to test it.
thijsco19
(thijsco19)
September 7, 2015, 7:10pm
61
Not sure if I missed something but did you already test the blitzwolf 24W 4.8A 2x USB wall charger? (blitzwolf 24w - Buy blitzwolf 24w with free shipping | Banggood Shopping )
HKJ
(HKJ)
September 7, 2015, 7:15pm
62
I got it a few days ago and am working on it, but I do not have much time this week. I hope to publish the review in about two weeks.
thijsco19
(thijsco19)
September 7, 2015, 7:39pm
63
alright thanks for the heads up!
Can you share some initial impressions? (good or bad quality?)
HKJ
(HKJ)
September 7, 2015, 7:46pm
64
There is not much I can say yet.
hank
(hank)
September 7, 2015, 7:47pm
65
Another QuickCharge device: http://www.newegg.com/Product/Product.aspx?Item=9SIA5NV32V1437
[Qualcomm Certified]Aukey Quick Charge 2.0 54W 5 Ports USB Desktop Charging Station Wall Charger (AIPower 5V/7.2A+Quick Charge ...
DanielM
(DanielM)
September 7, 2015, 7:54pm
66
Is this like a US only thing?
HKJ
(HKJ)
September 7, 2015, 8:00pm
67
hank:
I am working on that one. I used it to check that my box could trigger the different voltages.
It will probably be some time before I publish the review, I do have many older reviews in queue.
No, try Amazon, both .de and .co.uk has it
L4M4
(L4M4)
September 16, 2015, 6:43pm
69
maybe nice travelchargers:
