I’m in for one as long as starting from lowest to highest, not M-L-H.
As djozz suggested it, higher current switch and higher PWM if possible. Hopefully the driver still suitable for 10440 if have some changing, thanks.
Rey, could it be possible to get it just as a host?
Please put me in for 1 if it is nichia.
I have the aluminium version with xpg r5 and the beam is cold which makes it (beam) looks dull and dim.
It has a stiff reverse clicky and changing mode is difficult. Half presses inadvertently becomes full presses which switches off the light.
It will be great if the switch can be upgraded.
Oh, and if an upsized AA version is available I will take 1 too.
Count me in exactly as it is!
I’m interested in one, but is the clip included? Also, I’d like the button to be smaller or the tailcap ears to be longer so that it could tailstand plus less like to turn on by mistake (with the button sticking out the way it is now)?
Is there any chance you could have some of these lights be based on the Tool, and some based on the Worm? I mean like the same exact lights internally, Nichia 219, L-M-H, etc. but one would be EDC clicky style and the other would be the keychain/smallest size style.
I don’t know if this would be possible, but I thought there might be a chance since you are ostensibly sourcing Lumintop parts already. You would be making dreams come true if you could do this!
Another vote for AA version……
There are already copper AAA available. So I'll be making the tool AAA, and Lumintop gave me promition to do this. Havn't checked if they can engave "ReyLight" instead of "Lumintop".
Can they do anything with the switch/button, to make it not stick out the end like does now?
In this picture, the button seems fine?
I think the pics in the OP show the tailcap button kind of sticking out past the “ears”. It just may not be visible in the pic above because of the angle of the shot?
The button of the Tool sticks out, good for clicking, bad for tailstanding. The button of my old Ultrafire A3 is recessed, which makes it hard to press in such a narrow light, but it tailstands.
I have a Tool. The button is perfect — easy to activate when you need it, has never activated accidentally. I think on a long narrow AAA tailstanding is never going to be great, so I’d rather sacrifice it for basic functionality.
+1 not really a tailstanding type light IMO.
Just curious. There are already copper AAA available > so you’re making a copper AAA?
Not a clicky copper AAA…
Well there was but lumintop no longer make the tool. Hence this GB to bring it back.
+1
Exterior, light is perfect. Don’t change a thing. Would like interior beefed up to accept 10440 though, and L-M-H.
They had a small run of this model. Now we are making it again, with custom specs.
I’m interested. As is.
I would like one of those
