it is possible. as the LB clone of the XM-L2 looks very, very close to the original, but its likely not so bright, less efficient, and worse tint variations.
Yesterday I took some macro photos of a few known genuine XM-L2s...and the stippled texture isn't 100% consistent from batch to batch. Some of them are pretty smooth, and I know that they are genuine XM-L2s.
Good : My two LEDs might both be genuine after all.
Bad : If there is a lot of variation between batches it’s going to make it even harder to spot the fakes.
This is really obvious, and I’m not certain if this is a definitive characteristic, but I’ve not seen anyone mention it yet:
On my XM-L clones, I’ve noticed the obvious difference in the emitter base layer. While the LB clone is assembled in “Dome/Green/White” layers, the genuine Cree emitter is assembled “Dome/Green/Grey” (Or a darker greenish?) color.
I’ve also noticed that my XP-E clones are all assembled on a white base, but I don’t have a genuine XP-E to compare against. Pics on this thread seem to show genuine XP-Es with a white base, but I’ve not seen a good side view showing the difference.
Here’s another apparent counterfeit, which I find surprising! This time from an UltraFire 1226:
Not the greatest picture, but I can’t get closer until I actually remove the emitter from the light. See the squared bond wire junctions and smaller die size. This also has the smooth, green surface without the texture, and the white base I showed in the previous post.
This is strange, as this is still a very good throwing light, even with the presumed counterfeit emitter. This has a larger, and better reflector than my modded Uniquefire V2 semi-clone (my UF V2 has a slightly smaller reflector than the original V2). This counterfeit emitter in the 1226 gives me a hotspot that is similar in brightness to the V2 clone, which is driven at 3A and modded with an XP-L HI. My reference is via a white-wall comparison by eyes only, without any metering. The XP-L HI is a slightly warmer tint which may be tricking my eyes…
I assume this light will be a throw-monster when the emitter is replaced with a genuine high-bin XM-L2 (or XP-L/XP-G2) and has the current bumped up a bit… 8)
Still, the Lattice Bright emitters are surprisingly capable, as this light shows… If they wouldn’t blatantly copy their competitor’s design, and market as “Cree”, they would be reasonable budget alternative to the top-shelf Cree emitters… It’s not the LED I hate, it’s the unethical business practices.
Here are a few more photos to add some to the mix. In this case, the 100% genuine Cree XM-L2 U3 2A has very little stippling. All of these are real Cree LEDs.
I see what you mean about the variation in the stippling. Maybe my bargain drop-in was even more of a bargain than I bargained for. In terms of performance I can’t tell between the two.
Ouch that is disturbing.
So both the stippled texture on the die and the stippling/stippled coating on the silver base is inconsistent.
It appears that the only way right now to know if a led is real Cree is to look at the bond wire junctions, right?
Can definitely see the smaller die & square bond-wire pads on that one. Also good you noticed the base substrate color differences. (will add it to the OP photo list.
anyone know who made the dice?
just how many mfrs of led dice are there that make high power blue dice?
if the dice are cree(yes they sell just the die)then its a half truth.that means the clone makers are using cheap phosphor.or getting c or d grade dice and using cheap phosphor.
an interesting topic on the Counterfeit issue with buying on (e)bay posted by Muto here: Interesting article about refunds due from Ebay for Fake Items
it can relate to the thousands of flashlights sold with the “Cree” brand name which arrives with the fake LB or other LED in it sold through them.
Latticebright is definitely at fault. I’m no lawyer, but if you sell a burger that smells like a McDonald’s, looks like a McDonald’s, packed like a McDonald’s and especially you make a lot of profit out of it without the acknowledgement from McDonald, then you have already infringed the patent/copyright of McDonald even though your brand isn’t exactly the word “McDonald”.
Unless Latticebright did actually get the green light from CREE to produce these low quality craps, then it is a whole different story. For examples, as somebody has mentioned earlier in this thread, maybe Latticebright resells the grade B products from CREE that has CREE’s acknowledgement with it, or CREE decided to cut cost and they outsourced the LED production to some Chinese companies with the agreement to produce lower quality LEDs…
Has anybody ever measured output on the LB?
I ask because over the weekend I was at my brothers for his birthday. He had an SK68 with the LB in it and it was actually brighter than my XR-E. It did get a lot hotter though. I think it would be good if we could quantify these things and also see if there are wide variances from chip to chip.
The brightness has more to do with the driver current rather than the LED itself. To compare the two flashlights’ brightness you have to make sure both have the same driver current.
As for comparing the LEDs, I would guess Cree will be more bright but no necessary by much.
They do put out decent but do not work well driven hard, what sucks is the tint more than anything else.
Besides LED flashlights, my passion is Vintage Mini Bikes and in that field the Chinese successfully cloned the Honda GX200 engine quite a few years back.
And just like here in this field, everyone pointed out the flaws and shortcomings. But as time went on and the Go Cart guys (who really run these engines at a very high Rpms) figured out what changes needed to be made, the Chinese listened and delivered.
Now the Clones Rule and there is a cottage industry of aftermarket parts for the clones, more so than the Honda even.
The China guys actually then produced their own improved larger displacement which did not have a Honda equivalent and it is now top dog in the bracket. Some of the models have Hemi Heads, stock. Models rated at 6.5 hp will do over 9 hp with simple header and Airfilter/Jetting mods. And they are reliable.
All of which makes me wonder if Lattice Bright may eventually make their own line of LED’s, after all Cree reportedly doesn’t really want our market, their stuff just happens to get used for the application.
Gotta admit, LatticeBright did a fine job of cloning these things, look at how long it took for them to get found out.
I now see their emitters in lights I bought at least 9 months if not a year ago.
I thought at the time they were just cheap lousy tint Cree’s and I knew they didn’t do much better when driven harder. Still never killed one.
SO, has anyone De-Doomed a LatticeBright yet and if so, what were the results?
Later,
Keith
