Beamshots taken at the threshold of runway 30. (3000' x 40').
Contol shot
Car low beam
Car high beam
Searchlight with 100W halogen lamp - before mod. Useful range approx 1500' but dimly light.
Searchlight with 100W HID mod. Easily reaches 3000' and then some. Because the cheap camera doesnt have a manual shutter speed setting, it makes the incandescent beam shots look brighter than they actually are... and HID beam shots look less bright than they actually are. In person, the HID provided enough spill to clearly see the taxi ways and most of the homes that lined the runway. As 2100 had pointed out, the 100W's should provide some great spill... and that they do!
Wind sock before mod
Wind sock after mod. Not only does it blind the wind sock, it also lights up the bluff clear on the other side of the Snake River!
Again, if the camera didnt adjust automatically for the bright HID light, these pics would appear much, much brighter. I almost didnt post the beam shots because they do a lousy job of showing how bright this light really is. People have to squint if the light is shown inside of 100 yards.
Regarding the camera, it didn't actually adjust anything. At least both wind sock photos were 1s, f/3, ISO250. But the HID is still clearly brighter, see the mouse-over-trick below (mouse over for HID)
Thanks _the_. Looking at the properties of the raw files, I can see youre right. There must be something else in the camera that automatically balances the pics because these dont even come close to showing a good comparison. I guess I should start looking at better cameras again. Every time I buy a descent one, I wind up destroying it within a year. Same thing with expensive sunglasses. Buy the cheap stuff and they last for years... just my luck.
Hella offroad lights use H1 in their top of the line lights while their midrange lights use H3. Its ridiculous that they dont share just one standard. At least HID bulbs are cheap and use simple plug-in connectors. I may convert a set of incandescent offroad lights for my pickup truck next. I wonder how HID's would tolerate being turned on and off several times to prevent blinding oncoming traffic? I wonder what would blow out first - the ballast or the bulb? I drive in the country a lot at night and could definitely use a lot more light. So far Ive been lucky not to hit any large animals but Ive had several close calls.
Great work! Boy that's nice. I could see me getting myself in a lot of trouble with that thing. I had a Stanley HID3000 but it got stolen, so my truck is sadly underpowered in the light department.
I have been tempted to make a similar cigarette lighter socket powered lamp to keep in the car for a while. Nice job! I will keep an eye out for that host.
Thanks. They still havent coughed up your refund yet? Give DHL CS a call and explain to them that you need an immediate refund and cant wait any longer. Maybe they'll cut you a break. If you used paypal, I think they have the primary responsibility for insuring the delivery of your package.
If I find another host, I'll PM you. I like this one because its not a pure spot beam. It provides a descent amount of controlled flood with the 100W HID bulbs. Browsing the completed bids on ebay, they seem to be going for around $50... not bad considering the quality of the host. There were a few similar coleman variants and they all appear to use the same reflector and lens.
It reaches the top of the ridge with ease. Its only 350' high and 3000' away. If the reflector were more focused, it would put a massive spot out there. I much prefer this reflector since it still gives a good hotspot with descent spill... you see everything, not just what the hotspot is illuminating.
Good catch! I thought so too, but then there was that funny hot plastic smell I detected before I drilled the holes in the host. In the dark, I did note that when I turned off the 100W incandescent bulb, it dimmed quickly as the filament cooled. With the HID at turn-off, the entire quarts tube & envelope were glowing bright orange-hot for several seconds. Thats some pretty darn hot glass. I would guess that the surface temperatures (for at least this particular model HID) far exceed the 100W halogen it replaced. If the host were mounted on a car bumper moving through the air, I wouldnt be concerned because it takes a while to reach full operating temperature. I built this light with the intent that it could remain on as long as desired without worrying about a melt down. As a bonus, the host is threaded from the factory for a standard camera tripod, so I'll be using that option as well.
5Amp draw @ 12Volts = 60Watts consumed less losses your output to the globe will be around 50Watts unless it breaks the laws of physics there is no way your light is feeding a 100Watts to the globe, but still probably as bright as a 400 Watt incandescent globe.
A 35Watt HID consumes around 42Watts and output is about 3500 Lumens just guessing you may be seeing 5000 Lumens.
