If that’s the case then it should be possible to come up with a board that can be populated with borrowed components plus an Attiny. This should be fun.
Combining all the pics, one can see almost all the traces except for what is going on under the large diode. Appears that one trace is going under is from the Inductor/Capacitor to the bottom right leg of the boost chip there.
So MCU pads 1 or 4 can be used for VCC.
EDIT: I searched my driver stash, but could not find a driver like Post 2. I did a quick sketch of what the circuit appears to be based on the product pictures in the above links. I haven't tried to double check it or anything. Just a start.
EDIT2: Based on the purposes and positions of the boost chips pins, it appears to be a PAM2803.
EDIT3: Reading the discussions on the product pages, someone that appears to know what they are talking about says its a PAM2803. The data sheet says max input of 5v (min .9). So the potential applications are limited to low voltage, but it can be up to 90% efficient. Ordered some of the ones linked in Post 2 to play with. Also ordered this.
Following the datasheet of the PAM2803, the trace under the diode will surely be pin6 to Inductor/Bat+/Cout, as you drew it. In all probability pin4 (on/off), which you drew unconnected, will be connected with pin6 by a trace under the controller.
There are 2 points I find interesting.
First thing is that the MCU (the 8pin microcontroller) is not connected directly to GND, but to the other side of the current sense resistor (R150), which is the LED- of the controller (pin3) before the FET. Is there any reason for that?
Second thing are the 2 additional resistors (PWM to MCU-/pin3 (333) and LED+ to GND (180)). Could anyone explain what they are for?
As the controller of my Nanjg110-with-Attiny-and-FET blew up at first use with 2xAA, I’m still looking for answers why this happened. So I assume the mentioned details on the above driver might help avoiding current spikes. Ideas, anyone?. Thx.
^ You're very welcome. Thank you for helping me with Eagle in our PM's.
Thanks for the info on the likely tract to Pin 4. When I get the driver, I'll strip it down and post pics of the board.
I have many gaps in my electronics knowledge because I learn enough to accomplish a particular goal as I go along. Hopefullly, I'll eventually have a semi-rounded electronics knowledge base. I haven't learned how boost circuits work yet. So I have no substantive input on your observations and questions. All that is said so that folks take my statement with a grain of salt. Your assumption that the R150 may help in reducing the magnitude of spikes makes sense.
Regarding the 33kΩ that connects PWM to "ground", that is pretty typical in buck and linear drivers. I think it may be referred to as a pull down resistor as it pulls down residual charge between the MCU and FET in this case.
I think resistor "18D" is a EIA-96 code which translates to 150kΩ of resistance. It is not on the non-MCU driver that member Iraksat found. So maybe it helps the capacitor smooth voltage spikes or maybe speeds up voltage drop for mode changing. With such a high resistance value, it doesn't seem like it would to much to tame spikes. So it's more likely the latter or so other purpose.
Hopefully, someone knowledgeable with these types of circuits chimes in.
I got a few of these drivers but haven't had a chance to play with them yet. I'm hoping to be able to piggyback an attiny on them to get some good modes with hopefully little effort or cost! Yes, I know those are often lofty and unrealistic goals...
