This is driving me crazy. All I did was edit the LVP, OTC, and TT values in blf-a6. I’ve set AVRStudio to optimize for size, but now when I go to flash it still says it is too big. My hex file is 2,922 bytes.
Maybe someone else can try to compile it to see if it comes out smaller? What size am I shooting for?
k, take small steps. First try it with no edit changes whatsoever. Your target size for code is 1024, data is ?? - I forget, maybe 64 or 128?? You should see that final code size somewhere. The file size of the .HEX file isn't directly meaningful. You could edit the .HEX and see where the last records end - little trickier though.
@work - don't have latest 6.2 version installed here, or time to dnld projects, etc.
Good News! I think in the beginning, someone posted having probs with 6.0, so most people stuck with the older 5.x tools, but I quickly found the problem and fixed it - some compiler directive, or mnemonic that luxdrv had in it, I think.
Thinking of implementing a lock-out like this in my e-switch firmware for the 25/45/85. This is from a review on the Sunwayman C15A:
Lock out: The flashlight should be more than seven seconds off, press 1 click and maintain a second click (short flashing) the flashlight will be locked. To unlock, do the same.
Not sure if it's the best way, but I got a couple of side switch lights that don't have lock-out threaded connections, so something like this might just work. Richard's SupFire M2-Z is one example. Dunno bout that 7 second delay though - seems odd.
That's another way, just that if the button was stuck on, it would go to last mode? I really dunno what is better. I think the quick click to hold might not be so easily reproduced in a pocket or bag. I know my F6 had gone on in my pocket sometimes when I forget to lock it out.
You know that F6 is simply an awesome light! I got the Convoy (2nd version) and drilled a hole in an indent next to the switch and mounted a light pipe (tube) in there now. Works really well - on the nightstand it's a clear low green glow - bout perfect. Didn't know the light is the exact match/copy of the Sunwayman C15A (https://budgetlightforum.com/t/-/18681), just the C15A is a small tube for an AA/14500 cell. The C15A's switch looks better. Actually I might buy one from ILLUMN if I can get a good deal - they've been great before. He's got them marked down to $33 now (illumn.com/sunwayman-c15a), hoping the F6 driver will fit, and swap the LED. I have a T5-5D3 LED in my F6 and it's just a perfect milky white, at least to these ol eyes. I want to add a 2nd light pipe towards the rear, in another indent - it would be closer to the color LED's and should be even brighter. This light works so well with a SANYO GA cell - not as quickly burning hot as with a higher amp cell.
I only just how had a chance to look over your BLFA6 UI. That is really great. It adds a whole new dimension to the open source pool for sure. I can hardly wait to start playing around with it.
TK, I was still puzzled by the much lower than advertised PWM frequencies we see (and hear) on the BLF A6 and re-flashed Nanjg drivers.
I get 13 kHz - 14 kHz, as opposed to the expected 18.75 kHz.
The delay_loop_2 function that is supposed to take 4 CPU cycles is also way off, as you probably noticed.
I stumbled across this document:
There is also this in 17.3 of the data sheet:
It seems the specified 10% clock accuracy is only valid if using the default 9.6 MHz internal oscillator (and at 25 C and at 3 Vcc).
Maybe I am just late to the party, otherwise I hope this bit of info is helpful.
A fix, without getting into the user calibration procedure, would be to manually write the 4.8 MHz calibration data (it is there, just not used) to the calibration register.
Personally I decided to run at 9.6/8, phase-correct PWM only (2.352 KHz). Any higher and the PWM signal turns ugly on an oscilloscope. Probably not a good option if you want to avoid noise with a high-current driver. Also slightly higher MCU power consumption.
PS. Your s7.c firmware got me started in this. Thank you !
Thanks for this thread and the work. I was wondering if you might include Tido’s work in the repository (or maybe it’s there and I missed it), the BLF-VLD:
This probably explains why the attiny25 appears to run so much faster than the attiny13. And why selfbuilt measured “15 kHz circuit noise” instead of 19 kHz. I expected the tiny25 to be 166% as fast, but I measured about 210% instead, perhaps because the 13 is running slower than expected. I suppose I should probably figure out how to activate the attiny13’s 4.8 MHz calibration data…
As for 9.6 MHz / 8 (2.3 kHz PWM), it’s not used because faster clock speeds use more power… and because I find 2.3 kHz PWM both loud and obnoxiously slow. Anything under 10 kHz is hard for me to not see, so I try to keep the pulses fast enough that they’re a little beyond the human perceptual range.
BTW, how do you measure the PWM speed? Above ~3 kHz I can’t usually get a loud enough signal to measure it with a microphone. I’ve been tempted to try an optical sensor instead, maybe wiring up an LED in reverse, shining a light at it, and sending its output to a nice DMM, the DMM might be able to measure voltage pulse speeds… but I haven’t tried it.
I've used a scope in the past to measure high PWM's, just needed help from guys here @work to set it up. Great though seeing the exact waveforms, sliding the markers to get a precise measurement - pretty cool.
For the 25/45/85's, I'm really liking the 8 Mhz operation - the timing for every driver/MCU I tried has been dead-on accurate with no calibration -- 90 secs turbo timeout is accurate to within a second, and even that slop is probably me using my stopwatch.
I know it must be using more power than the 4.8 Mhz 13A, but thinking it's pretty insignificant in terms of LED ON and standy mode power - dunno the detials though.
