At least 4 units.
thanks,
At least 4 units.
thanks,
Sorry Rey, gotta pull out on this one.
It’s not anything at all to do with the light or the modes or any of that. I think you’re doing a splendid job.
I’m just too broke to fix.
Great looking host
Are we going to be good on using 10440? Sorry if I missed this if it was addressed.
I'm not trying to sway anyones opinion but I'd personally like a 1 lumen low , second mode to be high and third to be medium because that's kind of how i use lights .
minimum if I can get away with it ..high to see what I need quickly and then throttled back to med if i need some runtime .
kind of like the thrunite Ti
I also like the large jump from low to high because it impresses... not just others but me too .
like the eagletac 2012 d25a ti on a 14500 .....30 lumens than 600 . maeks me smile every time I change modes ..if it had a 150 lumen medium and a 3/4 lumen moon it would be sweet.
For all those people who dislike a moon / low /med /high /turbo ..i think being just one extra click away from max. wouldn't bother them as much ...i think it's the extra 4 clicks that bug them .
After playing with a xeno es1 for quite a while that has med/low high ..30/1/170 lumens .
I have to say i really think what people call an olight mode sequence is really kinda dumb .
Binnaca breath spray cap makes for a nice little short diffuser with a flat top for these lights. since they can't tailstand ...with this they can stand on their heads .Fits perfectly .tint is a bit cool white and has a minty taste .
Also a cute little mini traffic wand in red ..also stands on it's head (sorta) probably kills a lot of light to..but it looks cool .
* top to a Krazy glue pen
The blf-a6’s med-press to go from moon to turbo was actually called “impress mode” at first. I wanted to be able to show off a triple Cypreus’ full output range to muggles, without interfering with regular use. And then it turned out to be really handy for other things, like quickly checking something far away, so I kept it.
I’d like one only if the amps can be increased. 700 plus lumens would be nice!
You would need about 3 Amps. So an IMR may give you 5 minutes runtime.
Good luck with that.
5 mins is all I need. I’ll run it on med most of the time and just blast it in turbo when it’s show off time.
I am interested
As is, it is perfect.
Two units.
…and that would be exactly 4 minutes and 30 seconds longer than you would be able to hold it……
I'm liking this as-is, the Tool look. I'd be interested in one, might have others interested. The modes sound good to me. Even at $30, it's a great deal.
I’m in for at least 2.
I’m interested!
I almost bought the Maratac Copper via Massdrop recently, but I really don’t want yet another twisty. This one, well, uh, YEAH!
So, how does this work. Are we getting notified when it’s ready or available? or we have to pay a deposit before production starts?
Driver is under production. Will update once I got noted.
Cool! Are you going to do a drop on this as well just like the Maratac CU CR123?
In for 1.
I'm making a custom one, so the MAP does not work for me.
