Devices will not take more current than they need, the only time the high current will be a problem is if you have a defect usb cable or the device you want to charge is defect. In most cases the 6A protection will prevent anything from happening, but there is a small possibility that the cable might melt or in some even more unlikely cases catch fire. The biggest risk will be if you uses thin cheap usb cables, they are easier to damage and will get hotter when overloaded/shorted.
If you are near the charger it is easy enough to stop if you see it or smell it: just pull the charger out of the mains socket.
Worth noting that BlitzWolf is owned by banggood. The blitzwolf trademark is listed as owned by Guangzhou Banggood Network.
But like many products, blitzwolf/bangood devices are likely manufactured by a 3rd party. On amazon you can find RavPower and iclever branded chargers with identical appearance and specs. Likely manufactured by the same company and also identical inside. Lots of reviews on amazon, including a few reporting units that were defective, died, or smoked and burned. RavPower offers 2 years warranty and free return shipping for 6 months.
Identical appearing product manufacture on the same factory does not mean identical quality. There is nothing preventing the factory sorting the finished product (or parts) in multiple bins, depending on tests.
I have seen identical looking units with significant performance differences, due to small differences in the construction. This is most likely due to different generation of the design and not as much depend on what factory made the unit.
I do not know what requirements Banggood has for their supplier, my review can only deal with the units I received.
Until now I have only received BlitzWolf products (3 different chargers) that have performed fairly good. If Banggood wants to use this brand for their premium products I approve of that (I will always approve a way to identify good products).
Of course I will, but I will not buy one just now, because I have usb chargers enough for the next 3 months. If anybody sends a charger to me it will usual be placed very near the top of the queue.
If you want me to consider it at a later date, when I have less in queue, please post in my usb request thread. I usual order from the request threads when my queue is getting low.
And I replied: And even when the charger is not the best, the review itself sure is H)
I was right , this is once again one of your thoroughly investigated reviews.
And the verdict on the charger is also quite good. I even feel safe enough to give it to my wife.
Maybe this question has been asked before in some other place
The US version has a swivel plug for the mains. Is this worse than the fixed plug on the EU version? I would think that over time there could be problems with dust or loss of continuity.
I would also suspect there is a risk for that, but I have seen it on a lot of equipment for US with folding plugs and until know I have not seen complains about bad connections.
The two fall-outs at about 47 minutes matches with when I moved the charger around to get the IR photos, i.e. the US mains plug and adapter combination did not maintain a stable connection.
I noticed a bit of high Vpp ripple (3-4x times) compared to their 5 port 40W charger. Guess components dimensioniong counts a lot. Also If i recall correctly that one actually had single port output fuses.
Well, over the years, I have had three or four of them fall apart. Only one of the four in a way that caused a direct short circuit.
Cheap plastic that dried out and cracked apart, or swivel connectors that fell apart letting the wires move.
Possibly the fire safety requirement to use better plastic has changed that.
Speaking of change over time:
It would be — fascinating — to see you repeat a test on new samples after some period of time, to see if items become more cheaply made.
Yes and that would also be interesting for the batteries I test. In both cases the main limitation is my time.
Sometimes I do check different brands, that looks alike and it can be very interesting to compare the results and construction. I have tested a couple of chargers with the same size and construction as the 5 port BlitzWolf, there are some performance difference between them.
