Yeh, it’s great. I’m going to use 28AWG so i should be ok for pin 3.
I’ve stared at the images of this driver long enough to know where everything goes.
My boards just shipped out to me from OSHPark - should be a few days.
If only this version came in XP-L HI.
Plan on using an XPL HI V3 2B on the one I'll build up with PD68's new board, using an 85. I just used the same XPL HI in BLF X6 that got 1500 lumens and ~70 kcd throw (529 meters) - nice tint too. Expected I'd get the same here - maybe a little less based on the piggyback setup because might loose a little more amps - I'll see.
Want to add more features to the firmware since I got gobs of space now. Want to get some mode set choices in there, battery check, mode memory option, beacon, etc.
Just fyi... I'm working on enhancing my version of the e-switch/OFF time (e-switch and power switch support) firmware with configurable modes, a lock-out method, maybe couple more things. It will requires a 25/45/85. There will be 8 choices of mode sets, and mode memory ON/OFF, and option to go from lo->hi or hi->lo. So it's 32 combos all together.
Very nice. I’ve just been working on getting the light to switch off when the charging cable is connected as you have to have the tail switch on for it to charge. I’ve used a version of STAR_momentary which had temp monitoring on Pin3 which I’ve set to turn the light off when it detects the charger. I’ve also added a Beacon mode just because I like them. Extra long hold to activate. Currently working on an Attiny13A but which many other features disabled, I plan on using an Attiny25 for this light, giving me the extra space.
Ordered mine 9 days ago using ahirshy’s code and paid for faster shipping. Came today. Very nice little light. If you get one, remember to turn it on with tail switch, and then off with electronic switch, BEFORE plugging in the charging cable.
I’ve just made another order of boards with a slight tweek. Removed the 7135 chip and added batt indicator LED in its place.
I just feel that I should make it available and that all credit belongs to PD68
Looks good to me. I’m glad you had the foresight to put the LED on the bottom. I see your cam has tplace added to the silk. With my brd’s, you may find I have stuff on weird layers sometimes
Yeh didn’t really notice. Oh well I’ve already ordered them well see how they turn out.
I’m looking around for a current link for this but can’t find any. The link in the review comes up 404 error, and Amazon claims “currently unavailable”. Searches on GearBest and BangGood yield no results. Was this a limited time offer?
Lazy-R-us
Look'n bad.... I ordered 3 of these from BangGood between July and Sep in 3 different orders, last one ordered Sep 4th, got it Sep 14th.
This is really, really sad if they stopped making/selling this light - almost perfect. Couple of friends bought them too. I really thought of it as an improved X6.
God I hope they haven’s stopped I was after at least another 4 by the end of the month.
I just pm'ed Krono to see if he could contact Neal about this. I also pm'ed the "BangGood" BLF acct id - hope to find out somethig soon...
Yes - http://www.aliexpress.com/store/product/Eagle-Eyes-X6R-CREE-XM-L2-U2-1000LM-USB-Rechargeable-LED-Flashlight-self-defense-camping-light/1735126_32301365158.html. This Ali store was mentioned earlier - best deal around on them. I paid $24 at BangGood with a discount....
Hhhmmm, maybe I better order 1-2 now. Ali store says 992 available but I can't believe that - they sell one's, two's at a time, and total of 11 orders in the last 6 months. They must be quoting stock from the source (factory - or distributor), and who knows if that's legit and current.
I’ve been playing around with some other ideas for X6R builds. As it turns out I have a fondness for this light and want to build many different versions of it.
DISCLAIMER: I cannot guarantee any of this will actually work. Currently it’s all work in progress, anybody is welcome to try them. Also all credit for the boards must go to PD68 as he did all the initial work designing them.
Firstly a version with independent PWM channels for White and Red outputs. I have tweaked some firmware to fit as well. Starts on low white and short presses will increase, when at turbo short press will go back to low white. Med presses will go back from turbo all the way to low white then into the red modes, red on and then red beacon. To exit red modes long press will go back to low white or short presses will move back up to low white.
Firmware
Last we have a low batt indicator LED. Idea taken from the ToyKeeper’s Ferrero_Rocher firmware. This board only has one PWM out through the FET. The 7135 channel has been replaced with the indicator LED.
Firmware
Any news on availability? It’s out of stock on Ali and Banggood link gives 404.
Yikes, think I got one on order from the Ali store, shipped on 10/22. Tracking # shows shipped out of China today on 17track.net. USPS still knows nothing bout it.
This is bad if we can't get any more...
