Aargh! I hate those little blue ?’s
Yep.
What software are you using for design?
I wish I was there to watch this being made. I love the styling so far.
Anti roll, me like!
it is an old autocad…
actually there was a change of plans…i cut the reflectors on CNC… J)
I like that partly triangular head shape. It is more compact than leaving it round and it won’t roll off the table. It is also looking very neat.
Am I right that you used a mill, rather than the lathe with a four jaw chuck to make the offset round cuts for the reflectors?
Is the retainer milled as a separate piece or cut from the milled head?
hi, i am actually using home made CNC milling machine…
hi, the retainer is milled from separate piece because it has to have more material than walls of the body because it has to hold the glass, here are pics
i don’t know why the picturesare not always visible
what a beautiful light
Simply orsm. Unique and built on a home made nc machine to boot.
Pictures are all working now for me as well.
I get it now, looks great. Amazing you two have done machining those small reflectors.
Absolutely amazing craftsmanship!
the real challenge in this project was the combination of 3 reflectors and triple noctigon: it was harder to make this combination to work without short circuiting than the machining of the entire flashlight body… the 4 jumpers that are soldered in order to make the noctigon to be parallel current are simply too thick and the position of the soldering points of + and - cables are very close to LED’s…i solved the jumpers by simply milling them to reduce the height but the cables position was much harder resolve…pics are coming up…
Super nice clean build. Stunning Work!!! TL
