Just remember, heating up the pad at the base of the spring is also heating up the switch. Pretty much as easy to kill the switch here as soldering directly to the switch.
Try removing the spring from the board, soldering the wire on in the middle, then run the wire up through the spring and solder the spring back on around the edges. Cut the wire a little long, coil it inside the spring slightly so it’s got easy room to compress, then solder the top end of the wire to the top of the spring. I like folding the wire over the very end of the spring then soldering it. Even if the solder lets go of the spring the wire will stay in place.
Btw, I stand by my method doing the spring bypass on the outside, it is a bit theoretical in my opinion that the solder joint at the base of the spring would break, it is stiff one piece with the base under the spring.
Style notwithstanding, what happens if the top lets go and the wire… still connected at the pad… touches the side of the pill? Direct short, of course. Once you’ve had this happen, you develop more of a safety conscience than a style.
Also, keep in mind, we are advising many people around the world here with unknown soldering skills. Err on the side of safety.
So does anyone make a short little quick-blow fuse with wire leads, that could serve as a spring bypass?
Seems like a thoughtful redesign of the whole switch notion could pay off considerably if there’s a way to separate the conductor from the spring in a way that would negate these low-likelihood, high-boom direct short possibilities.
Let’s say “potentially” safer, we want people to think on the side of safety while they’re modifying these lights, right? I mean, reckless abandon is well and good when with a consenting adult but sometimes thoughtful care and consideration are appropro…
Wait til you build your first small triple, it’s so exhilarating, scary, and just outright fun you’ll wonder what took you so long.
The first time I saw 12A in a smallish light, man, what a trip! Then I saw 16Amps, 17Amps, holy cow, I was afraid to turn it on! And now I have a quad Titanium X6 pulling 21.3A from a single cell, yeah, it’s just freakish and fun and mindblowing and dangerous and and and…
After a night's sleep I understand the safety concern of an outside spring bypass a bit better: I know I make solid solder joints but not everyone will make a good job of it, and you don't want to have it come loose. I think what TK says is a pretty good point: the driver spring of the BLF-A6 is not so long, so the gain of a bypass is a bit less so just leave it out. You can still do the tail spring bypass any way you want it because when it shorts there it is not a direct battery short but the light just switches on (in my case in moonlight :-) ), much less of an issue for something that will not often happen anyway.
Last night I did a spring bypass on both springs. Testing with a 25R freshly charged with 4.19v yielded 6.7a on my Fluke clamp meter…wow! Is anyone else seeing that many amps? Hopefully that poor little XPL can live at that power level.
The driver on this light is awesome;
Great UI
Nice moonlight
Lots of top-end output
Many thanks to everyone who worked on this project!
wow, that is more than anyone got yet, you must have had a very low voltage XP-L by chance. I have had XP-L leds that went to over 9A en ones that blew at 7A, so you may just be lucky with this one :-)
Hey Dale, since switching to your method of using my clamp meter to Measure amp draw, my readings have gone up, a lot. Here’s another point worth noting, I took the battery directly out of the BLF light after testing and placed it in the A6 I won in your giveaway, and amp draw dropped to around 5.4. Edit 6.1a
Likely to be an emitter binning difference, each step on the bins is approx a 20% gain in output. We did see some dramatic shifts in the equilibrium when Cree made the last changes and high amperage is not common anymore, while output can very well be the same.
At any rate, a 500-600 mA difference is fairly normal between 2 identically built lights. It’s always difficult to get em exactly the same.
I’ve also built a light, ran the tests, wrote down everything as it happened only to come back later and find new tests give different results. The cells lose capability with age and wear, the emitters break in differently, whatever causes it, it’s a fluctuating set of parameters that befuddles me on a regular basis.
I'm loosing faith in my 14 AWG DMM lead setup now, after hearing these crazy #'s... Wow! Is there any reliable way you have to measured tailcap amps on the same setup you used the clamp meter on?
I'm seeing the same as you Dale. Generally months later, #'s go down, not always though. My triple X6 that was ~4200 is now like 3900 or so, for example. Cells sure do lose it. I'm think'n I'm not smart bout storing them lower - I tend to keep my cells charged up, which is probably not helping.
I also wanted to state that while the differing tube lengths are a crappy ordeal esp. for any protected battery people (although springs on both ends helps) that the tube length in itself shouldn’t affect power through the light. The problem it seems is the length of the threads and/or how deep the caps are threaded. You’re running out of thread before the un-anodized portion of the tube is seated properly. Also be sure that your retaining rings are tight as they need connection to their respective boards! As I and DB have mentioned be sure your tube is not reversed (clip slot near tail). I am already guessing you are thorough enough to have checked that. Please be aware that some of my posts are for anyone reading in the future as well.
