Problem is that there is no BLF AA boost driver yet, there have been talk about a BLF AA boost driver since 2011 but it is still not there. The latest talk is about an Attiny based one with BLF firmware. For a compact AA light you need a 15mm diameter driver.
You’re taking cheap lights TO china?
… I bet you’re the kinda guy who tries to put toothpaste back in the tube, too.
Yes, I don’t want to risk losing any of the lights I have. And if I take 6, I can dump them and bring back 6 better ones.
I will surely be bringing more back though. So long as the wife lets me
Toothpaste? What’s that
Monty
My old Fenix L2T is about at the end of its life. Would not mind a good replacement.
The BLF Starry Light was a good attempt.
The survey in the OP pretty much reflects what I’d want for an AA/14500 flashlight, except I would like hidden blinkies.
I pretty much agree with the OP survey too, except I am not too bothered about 14500 support.
I’m really surprised forward switch is most popular. I can’t think of any custom BLF lights tha use forward switches and we seem to do a lot of custom runs.
I like forward switch, I wish more budget lights used it.
That failed, IMO, because of switch/driver issues when switching to next mode gave no output and threads, that are made out of plastic on plastic body, wore out with very, very little use.
True story bro, thats how it is on mine. Bought two, one for me, one for friend, but not sure if he ever used one so cant report on his specimen.
Forward switch would be nice.
I wouldnt mind 14500 compatibility, extension tube for 2xAA is a must.
Cant we design not just its internals but the looks as well? I sort of dont like using clone of clone as a host and just engrave BLF logo on it.
In my experience with them, whenever there's more than one or two modes, a forward clicky is a nuisance.
Yes!
Rotating head lights are quite rare and what a coincidence, eagle light have one AA angle light http://www.gearbest.com/led-flashlights/pp_168409.html
Also interesing is the mini DQG AA http://www.banggood.com/DQG-CREE-XP-G2-R5-180LM-3Modes-EDC-LED-Flashlight-AA14500-p-970068.html
Either one with high CRI LED or better tint would be perfect.
I agree in that forward works better with a eswitch. I wonder why no budget lights use eswitch… how much does it add to the cost?
I have the DQG AA in Stainless Steel Neutral White form… Great light. Tiny… Very bright… Great tint… and also tough.
Not a big fan of the “twist off to turn on” approach though… Because it also switches off again if you twist it “too far”… so you have a small area of movement between on and off. This is alleviated a little by the head not having much “play” in it… not much chance of it switching modes accidentally while being held…
If it was a clicky, it would be much better (but obviously also probably 1-2cm longer).
It’s also a nightmare to mod… I wouldn’t even try it I don’t think… I let the Mrs have it (oo err), as it fits in her handbag quite well.
I think any future AA flashlight I would want to be able to easily mod - even if its just an emitter/reflector swap etc… To help future-proof it a little…
Umm… forward clicky and e-switch are two very different things. What exactly are you trying to say about forward working with e-switch? Do you mean two switches?
Yes, for example lights like Nitecore P12, Thrunite TN12, and Fenix PD35 use forward tail switch with side eswitch.
I’d like a budget light that used the A6 direct drive driver with SMO reflector, forward tailswitch, and side eswitch to blow away those other lights.
Okay, I’m still a newbie, so, what advantage do you get with a forward switch in the tail versus a reverse switch or no switch at all, on e-switch lights?
I wonder if Simon/Convoy would build a 1 X 14500 / 2 X AA light. I would like a well made, affordable, 2-3 mode, no blinkies, maybe an XPG2 or XPE2 light. Shadow made a cool looking Mini TC6 that I never got around to purchasing.
I recently got a Jetbeam WL-S1. My every day pocket carry is a Single AAA light but the Jetbeam is very versatile. It can use CR123a, RCR123, 16340, Alkaline or NiMH AA, 14500 (without carrying an extra battery tube) but what I use in it is a lithium ion that combines the diameter of a CR123a and the length of the AA, a 16500 purchased from eBay. With this battery and its larger head and reflector, it approaches the BLF A6 SE 18650 power and will still fit well in a loose pocket.
Now that is a great idea! Maybe we need a custom blf driver though:)
